Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 11 / iPhone 11 Pro / iPhone 11 Pro Max
Old 08-19-2021, 05:23   #1 (permalink)
Member: 2979043
Sonork: 100.1684641
IPhone 11 restore(writing filesystem) fail @ error -1100
I have iPhone 11 it was disabled due to forgotten password. I checked the iCloud status everything is clean, FMI itís off. The iphone was working just fine before attempting the restoration. I downloaded iOS 14.7.1 which is the latest iOS and attempted to restore using 3utool ..during the restoration it would fail at 40% of writing a filesystem at error -1100 couple of times .. I did research online based on this issue .. I couldnít not find any solution. I used iTunes too to attempt to restore with it ..it also fails at -1100 .. what could be the problem and has anyone ever had the same issue and get it fixed ?
What is surprising me is that the iphone was working just fine before restoring it just started to have some issues when attempting to restore it ..now it is stuck on DFU mode.
Any anyone who can help or advice me on what to do please.
Old 08-19-2021, 06:35   #2 (permalink)
gayansuranga's Avatar
Member: 230004
Thanks Meter: 174
try to flash it disconnecting front sensors but if it really somthing to do with file system it will not help
Old 08-20-2021, 12:12   #3 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 160
you will need to open the phone to check hardware inside also maybe batery is not charged while you were restoring it..worst is maybe nand has problem
Old 09-29-2021, 19:54   #4 (permalink)
Member: 264595
Thanks Meter: 49
ram IC is broken.. needs to be replaced ..
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.10532 seconds with 7 queries
