[01-08-20] GSMShield Box Qualcomm v1.8 - Eid Ul Adha Mubarak GSMShield Qualcomm v1.8 Simple, Yet Powerful Supported Qualcomm Chipsets with AutoDetection: - MSM8909 - MSM8x10 - MSM8x26 - MSM8916 - MSM8917 - MSM8920 - MSM8929 - MSM8936 - MSM8937 - MSM8952 - MSM8953 - MSM8960 - MSM8974 - MSM8976 - MSM8992 - MSM8994 - MSM8996 - MSM8998 - SDM6xx - SDM7xx - SDM8xx Supported Features: - Automatic Selection of programmer - Option to select custom programmer - Automatic Memory Type Detection - Device Identification Function - Read Factory Firmware - Write Factory Firmware - Support Multi Program Firmware Read/Write - Safe Flashing for Security Data Protection - Reset FRP in Flashing Process - Read/Write/Erase Any Partition - Backup/Restore/Erase Security - Reset FRP - Format Userdata - Safe Format Userdata - Supports Both IMEI Repair - Reset Vivo User Lock without Data Loss - Read QCN Data - Write QCN Data - Support for UFS Memory Devices - Xiaomi Mi Account Reset - Xiaomi Mi Account Relock Fix - Xiaomi Factory Reset in sideload - Xiaomi Device Service using Auth Server - Vivo Reset Settings without dataloss - Enable/Disable ScreenLocks for Xiaomi - Xiaomi Reset EFS in EDL/Sideload/Fastboot Mode - ZTE Reboot to EDL Mode from DFU/FTM Mode - Enable/Disable ScreenLocks for Xiaomi - Read Pattern Lock (Android 5.1) - Remove Screen Locks (Un-Encrypted Userdata) - Disable Screen Locks (Encrypted Userdata) Added: Alcatel - 5056I LYF - Water F1 (LS-5505) YooMee - L451E Wiko - Pulp 4G - Rainbow Lite 4G - View Prime - View 2 Pro - Wim YU - Yuphoria (YU5010A) ZTE - Blade A320 Added Vivo Format/FRP Method - This method should ONLY be used on Vivo Secured Phones - If normal method does not work, you can use this method - You can select this method from Format Dropdown List Added Diagnostic Mode Security Repair - Simply tick Only DIAG Mode to skip EDL mode operations - If it does not work, you must use normal method (EDL+DIAG) Added Xiaomi RSA Protected IMEI Repair - Should work on all RSA Protected Xiaomi Devices - You must have working QCN, or Read from Device first Fixed Issues with Open/Save File Dialogs Internal Loaders Updated Official Wesite Download Installer |
please upload the installer to mediafire that here won't let me access |
the best Update Added Xiaomi RSA Protected IMEI Repair Should work on all RSA Protected Xiaomi Devices You must have working QCN, or Read from Device first |
the best Update ........ |
Eid Ul Adha Mubarak All GSMShield Users : Thank you very much sir, happy Eid from us too. Thank you for giving good support to all of us users. Best Regard Unlockinfo |
Eid ul Adha MUBARAK Good update gsmshild.. |
Eid ul Adha MUBARAK ❤️ |
Thanks team am so grateful for this update New, simple yet strong and powerful team |
Model : Xiaomi Redmi Note 7 Process : Reset Mi Account Looking for Device Connected in EDL Mode...No Device Found Use Volume Key/EDL Cable or TP for EDL Mode. Port : Qualcomm HS-USB QDLoader 9008 (COM14) Connecting to Device on COM14....OK Getting Hardware Details...OK Hw_ID : E1C0080000000000 [8996] Hash_H : A7B8B82545A98ECA23D6E9105FB46456 Hash_L : 8D1B5828264903441BDEF0CD57E3C370 Switching to Firehose...OK Selecting Internal Programmer...Match [1] Found Loading Programmer...OK Sending Programmer [ODk5Nl8wMjIuZWxm].....OK Ping Target...OK Identifying Storage Type...OK Target : MSM8996 Memory : eMMC Size : INVALID GPT ENTRY Payload Data : From_Target: 65536 [4096], To_Target: 131072 Sector Size : 512 Reading Partition Info...OK SYSTEM partition is missing! Required data not found.Failed Process Failed GSMShield Qualcomm 1.8 |
please, put the option to activate the diagnostic port through root |
Please add network unlock button for alcatel and zte devices |
Any ideal to remove frp in infocus vzh for with qualcomn chip msn8917 |
thnx again team for new update |
excellent ... good update |
please place the option to extract UPDATE.APP from Huawei Qualcomm please |
