![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002 Location: NCK Team Projects
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 98,591 ![]() | [26/01/2023] Gsm Shield Box MTK v2.5 Released ![]() Added - Read Simlock Info for MT6739, MT6761, MT6763, MT6765, MT6768, MT6771, MT6775, MT6779 CPU. Code: -- This solution use default MTK Simlock algorithm used by mostly brands what use MTK CPU. --- Exe will display locks info and unlock code if phone have stored unlock code. ---- Many Motorola, Nokia, Huawei, Lenovo Models usually store Sim unlock code also. ----- Some brands or models can have modified security and will not support this function. Code: -- This solution use default MTK Simlock algorithm used by mostly brands what use MTK CPU. --- For now, is supported for direct unlock only phones with 32 bits Simlock scheme. ---- 64 bits Simlock is supported only for read info. Added Change / Repair IMEI for phones with MT67XX CPU in flash mode and SP meta mode. -- Some models can have meta mode disabled, in this phones SP Meta repair cannot work. Code: Supported cpu with this new update for IMEI Change(repair). MT6739 MT6761 MT6763 MT6765 MT6768 MT6771 MT6775 MT6779 possible Motorola is NOT supported. Added auto bypass security if user will select generic CPU from settings (not need to select manually). Improved read info in meta mode, and meta mode functions. Improved IMEI Repair in flash mode or phones MT6739, MT6761, MT6765, MT6768, MT6771, MT6775, MT6779 CPU. Improved read info in meta mode, and meta mode functions. Added auto bypass security if user will select generic CPU from settings (not need to select manually). Official Website: GSM Shield Box Download From Support Area OR Gdrive https://drive.google.com/file/d/1ZVb...ew?usp=sharing Password for setup: NckTeam Last edited by Fast Unlocking; 12-22-2023 at 06:53. |
The Following 9 Users Say Thank You to Fast Unlocking For This Useful Post: |
![]() | #6 (permalink) |
Member: 94675 Status: Offline Sonork: 100.8888 QQ3161545070 Thanks Meter: 98,591 ![]() | Download From Support Area OR Gdrive https://drive.google.com/file/d/1ZVb...ew?usp=sharing Password for setup: NckTeam PS. next time use english |
The Following User Says Thank You to Fast Unlocking For This Useful Post: |
![]() | #7 (permalink) |
Junior Member ![]() Join Date: Aug 2021 Location: Russian, Voronezh, GRM
Member: 2993891 Status: Offline Thanks Meter: 6 | mt6877/mt6877t not supported... This cpu is not supported for this opperation. Exploit has been not executed. Posible unsupported phone. Please add support for new MTK processors ![]() |
