08-19-2021, 05:25 | #152 (permalink) |
Junior Member Join Date: Aug 2021 Location: Russian, Voronezh, GRM
Member: 2993891 Status: Offline Thanks Meter: 3 | Successfully flashed and removed the Google account on the Lenovo x304l tablet (GSMShield Qualcomm 2.7) the image does not allow you to attach it... |
The Following User Says Thank You to =GRM= For This Useful Post: |
08-26-2021, 20:47 | #153 (permalink) |
Banned Join Date: Mar 2019 Location: Gsm-Boss Age: 46
Member: 2902804 Status: Offline Sonork: 100.1660513 Thanks Meter: 928 | Xiaomi Redmi Note 8 FRP GsmShield Xiaomi Redmi Note 8 FRP GsmShield |
The Following 2 Users Say Thank You to Gsm-Boss. For This Useful Post: |
09-06-2021, 17:35 | #154 (permalink) |
Member: 2993891 Status: Offline Thanks Meter: 3 | Successfully removed the Google account on the Doogee N20 (GsmShield_MTK_2.2) p.s. The forum still does not allow me to attach images and logs to the message. |
09-08-2021, 00:26 | #155 (permalink) |
Member: 2993891 Status: Offline Thanks Meter: 3 | Successfully removed screen lock Some android functions don't work, but the main thing is that now we can get to the content and save data from the phone! Model : Xiaomi Redmi Note 7 Process : Disable Locks Looking for Device Connected in EDL Mode...No Device Found Use Volume Key/EDL Cable or TP for EDL Mode. Port : Qualcomm HS-USB QDLoader 9008 (COM11) Connecting to Device on COM11.... Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Selecting Internal Programmer...Match [1] Found Loading Programmer...OK Sending Programmer [ODk5Nl8wMjIuZWxm].....OK Ping Target...OK Auth Enabled Device! Xiaomi Auth Service Required! Lets try with Free Auth...Success Identifying Storage Type...OK Target : MSM8996 Memory : eMMC Size : 32 GB PH_Part : 1 [0x03A3E000] Payload Data : From_Target: 65536 [4096], To_Target: 131072 Sector Size : 512 Reading Partition Info...OK Reading Device Information...OK CPU Abi : arm64-v8a,armeabi-v7a,armeabi Software Ver. : Android10 Build Date : Mon Jan 18 18:53:38 WIB 2021 Android Ver. : 10 Security Patch : 2021-01-01 USERDATA : Encrypted Disabling Android Locks...OK Process Finished GSMShield Qualcomm 2.7 |
09-23-2021, 17:31 | #156 (permalink) |
Junior Member Join Date: Dec 2019 Location: maputo
Member: 2941618 Status: Offline Thanks Meter: 4 | sucessfully reset lg g4 Device : LG H815P Task : Format FS Port : COM81 : LGE Mobile USB Serial Port (COM81) Opening Port...OK Reading Information...OK Model : LG-H815P PID : BS14S160211000002 IMEI : 359871063459276 Firmware : H81520f Factory Ver. : LGH815PAT-00-V20f-ZAF-XX-OCT-19-2016+0 LAF Ver. : 1.1 Chipset : msm8992 Operator : GLOBAL Country : COM Memory ID : 032G74 Capacity : 29,12 GB Battery : 35% Storage : eMMC Sector : 512 Reading Partition Table...OK Formatting [userdata]...OK Formatting [encrypt]...OK Rebooting Device...OK Process Finished Elapsed Time: 00:06 GSMShield LG v1.0 |
The Following User Says Thank You to beto yriizz For This Useful Post: |
10-17-2021, 17:45 | #157 (permalink) |
Member: 2993891 Status: Offline Thanks Meter: 3 | GSMShield Qualcomm 2.8 Xiaomi Redmi Note 10 - Reset FRP DONE! Code: Process : Format / FRP Looking for Device Connected in EDL Mode...Found Opening [COM11]...OK Init Handshake Sequence...OK Hardware ID : E1500900 [SM6150] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE1D25A7B0472DD7 Initializing Protocol...OK Selecting Internal Programmer...Match [1] Found Loading Programmer...OK Sending Programmer [U002MTUwLmVsZm==].....OK Ping Target...OK Build Date : Dec 18 2019 @ 16:36:51 Chip Serial : 122912758 (0x7537ff6) Auth Enabled Device! Xiaomi Auth Service Required! Lets try with Free Auth...Success Identifying Storage Type...OK Target : SM6150 Memory : UFS Size : 64 GB PH_Part : 6 [0x00DD4000] [0x00000800] [0x00000800] [0x00008000] [0x00100000] [0x00008000] Payload Data : From_Target: 65536 [65536], To_Target: 16384 Sector Size : 4096 Reading Partition Info...OK Reading Device Information...Failed Resetting FRP Lock Data...OK Process Finished GSMShield Qualcomm 2.8 Last edited by Fast Unlocking; 10-18-2021 at 07:18. |
12-09-2021, 16:25 | #160 (permalink) |
Member: 2941618 Status: Offline Thanks Meter: 4 | FERO A5003 HANG ON LOGO FIX DONE BY GSM SHIELD Phone Storage: EMMC EXE: GsmShield Spreadtrum 1.7 SELECTED: SC7731E_EMMC_WIKO ACTION: Format Userdata If phone will stuck on logo, perform factory reset from diag mode tab. Start Detect phone. Phone must be off with battery inside. Long press "VOL -" key while inserting usb cable. Keep key untill boot complete. Detected: SPRD U2S Diag (COM11) Sending loader, keep boot key untill loader start. Loader OK: Spreadtrum Boot Block version 1.1 Changing bautrate OK. Send Second Loader. New flash metod detected. UID: T1MB57_21_17_55 Manufacturer: Fero Hardware: k120_v1.1.0 Hardware version: SC7731e_2_IRD_K_V1.1.0 Build product name: A5003 Build description: k120-user 8.1.0 OPM2.171019.012 1534487267 release-keys Product name: A5003 Board: A5003 Build Id: OPM2.171019.012 Build version: K120AG_8.1_FER_TZ_BR1_04 Model: A5003 Android Release: 8.1.0 Android Version: OPM2.171019.012 release-keys Security patch: 2018-07-05 This phone have frp partition. [misc]Format OK. [userdata]Format OK. [can take 0-10 sec]Wait untill phone restart. Log saved: C:\GSMShield\spreadtrum_module\Saved_Logs\k120_v1. 1.0_OPM2.171019.012release-keys_format_userdata_emmc.txt Total Time: 00:00:23 Done. |
05-17-2022, 09:52 | #165 (permalink) |
Freak Poster Join Date: Apr 2007 Location: ZANZIBAR
Member: 496694 Status: Offline Thanks Meter: 95 | samsung a30 frp bypass done. Device : A305F Operation : Reset FRP - New MTP Method Searching for Phone...Found Hw ID : USB\VID_04E8&PID_6860&REV_0400&Modem Port: : COM60 : SAMSUNG Mobile USB Modem #16 Idntifying Device Mode...No Device Detected Could not check, ignoring! Reading Information...OK Model: IMEI: : CTIVATE=0,0,0AT Searching for Device...Found Brand : samsung Model : SM-A305F Product : a30 Device : a30 Andriod Ver. : 11 Patch Level : 2021-04-01 PDA : A305FDDU6CUE1 Bootloader : A305FDDU6CUE1 Build ID : RP1A.200720.012.A305FDDU6CUE1 Build Date : Mon May 3 16:35:10 KST 2021 Checking Root Status...OK Root : No Root Resetting FRP Lock...OK Finished Succesfully. Elapsed Time: 01:07 GSMShield Samsung 1.2 |
The Following User Says Thank You to sasfido For This Useful Post: |
