02-16-2023, 14:50 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Vivo Y81i vivo 1812 Format Done Easily By Gsm Shield Box Selected 0-By CPU:AUTO Exe version: GSMSHIELD MTK 2.5 Phone must be off with battery inside. Battery must be charged Please insert USB cable now... Keep "VOL-" button untill inserting USB cable. For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable. For some phones need to keep "VOL+" button untill inserting USB cable. Detected(14) : MediaTek USB Port (COM14) [14] \\?\usb#vid_0e8d&pid_0003#5&cf6f6ce&1&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} CPU: MT6761 CPU code: 717 Target config: e5 *********************** Secure boot enabled: true Need serial link authorization: false Need download agent authorization: true SWJTAG enabled: true EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false Root cert required: false Memory read authorization: true Memory write authorization: true Cmd 0xC8 blocked: true *********************** Executing exploit, do not disconnect phone Exploit has been executed successfully. [3b600]Dumping phone preloader. Preloader: C:\GSMShield\MTK_Gsmshield_Backup_Folder\preloader _backup\preloader_k61v1_64_bsp.bin Waiting for handle to become active...... Reseived active handle repply from phone...... Booting phone Detected(14) : MediaTek USB Port (COM14) [14] \\?\usb#vid_0e8d&pid_0003#5&cf6f6ce&1&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Boot mode: Brom Phone detected...Please wait BBCHIP: 6761 200 ca01 Using Algo 1. Helio MT6761 phone detected, swithing to helio api Helio enabled DRAM in First Da: FALSE Sending loader..... BBCHIP MT6761 [1]Storage EMMC Block size: 512 EMMC FW VERSION: 00:00:00:00:00:00:00:00 EMMC CID: 90014A48414734 : 000000000000000000 EMMC UA SIZE: 0x3ab400000 BOOT STYLE: EMMC BOOT FULL LENGTH: 0x3ac000000 [14.688 GB] Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected(20) : MediaTek DA USB VCOM (Android) (COM20) [20] \\?\usb#vid_0e8d&pid_2001#5&cf6f6ce&1&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} Detecting format adress....wait! Starting generic userdata format...! Partition: cache begin: 0x115800000 length: 0x10000000 Partition: userdata begin: 0x125800000 length: 0x2820fbe00 Phone can start slow at first power on If phone stuck on logo, perform wipe from recovery. First start can take up to 5 min on some phones. [helio]Wait untill phone will start charging. [0]All done. |
The Following User Says Thank You to amn32 For This Useful Post: |
