Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSM Shield Box
Old 11-13-2021, 13:55   #1 (permalink)
..::GMSR::..'s Avatar
Member: 1444462
Thanks Meter: 1,337
Vodacom kicka 5 plus 4g network lock removed done by gsm shield
VODACOM KICKA 5 PLUS 4G NETWORK LOCK REMOVED DONE BY GSM SHIELD
http://www.youtube.com/watch?v=UgxOJu27JgU
The Following 2 Users Say Thank You to ..::GMSR::.. For This Useful Post:
Old 11-15-2021, 11:04   #2 (permalink)
Member: 2990879
Sonork: www.sonork.com
Thanks Meter: 6
Thank you, please add more explanations
Old 11-13-2023, 15:55   #3 (permalink)
onz
onz's Avatar
Member: 2012334
Sonork: 100.1658100
Thanks Meter: 777
in meta mode i get this error
 Selected model: 0-By CPU  AUTO
 Action: Unlock
 Phone must be off with battery inside.
 Battery must be charged
 Please insert USB cable now...
 For some phones need to keep "VOL-" button untill inserting USB cable.
 For some phones need to keep "VOL+ and VOL-" button untill inserting USB cable.
 For some phones need to keep "VOL+" button untill inserting USB cable.
 Detected(30) : MediaTek USB Port (COM30)
 [30] \\?\usb#vid_0e8d&pid_0003#5&27a2fbd8&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 Starting META mode, wait...
 [Secured Model]Not supported by exe, aborting
 If model is listed, please select correct model
 [0]All done.
in flash mode i get this error
 Action: Unlock
 Keep "VOL-" button untill inserting USB cable.
 CPU: MT6761 CPU code: 717 Target config: e7
 Secure boot enabled: true
 Need serial link authorization: true
 Need download agent authorization: true
 SWJTAG enabled: true
 EPP_PARAM at 0x600 after EMMC_BOOT/SDMMC_BOOT: false
 Root cert required: false
 Memory read authorization: true
 Memory write authorization: true
 Cmd 0xC8 blocked: true
 Executing exploit, do not disconnect phone
 Exploit has been executed successfully.
 [3ae00]Dumping phone preloader.
 Preloader: C:\ProgramData\Android_MTK_Backup_Folder\preloader_backup\preloader_rio_go.bin
 Waiting for handle to become active......
 Reseived active handle repply from phone......
 Booting phone
 Boot mode: Brom
 Phone detected...Please wait
 BBCHIP: 6761 200 ca01
 Using Algo 1.
 Helio MT6761 phone detected, swithing to helio api
 Helio enabled DRAM in First Da: FALSE
 Sending loader.....
 BBCHIP MT6761
 [1]Storage EMMC
 Block size: 512
 EMMC FW VERSION: 00:00:00:00:00:00:00:00
 EMMC CID: F4012241524A31 : 000000000000000000
 EMMC UA SIZE: 0x748000000
 BOOT STYLE: EMMC BOOT
 FULL LENGTH: 0x748c00000      [29.137 GB]
 Status: USB_HIGH_SPEED
 Detecting high speed port, wait......
 If driver not installed, install high speed port driver.
 If not need high speed port, disable it.
 After repeat opperation.
 Detected(130) : MediaTek DA USB VCOM (Android) (COM130)
 [130] \\?\usb#vid_0e8d&pid_2001#5&27a2fbd8&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
 [0]IMEI not found in nvram file.
 Phone have OTP partition.
 MODEL FROM PROINFO: T431Q-2AVCZA12-3
 SECRO FROM PROINFO: EKW8QZN0DC00
 OTP IMEI: 353337720474294
 Modem version: MOLY.LR12A.R3.MP.V219.10.P2
 [Helio]Reading security, wait...
 [Helio]Unlock is not supported for this model
 [helio]Wait untill phone will start charging.
 [0]All done.
can you pliz explain how you did it
Page generated in 0.14673 seconds with 8 queries
