07-06-2020, 13:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: earth
Member: 1591394 Status: Offline Thanks Meter: 552 | dra-l21 cant boot 14:40:42 - Initializing.. 14:40:45 - Token ID : 130B1B13051B032A 14:40:45 - Serial : 00002305 14:40:46 - 1 - Power off Phone.. 14:40:46 - 2 - Remove Install Battery if Needed.. 14:40:46 - 3 - Connect Usb Cable to Powered off Phone.. 14:40:46 - Waiting for Device Interface.. 14:40:49 - Interface Found : COM3 : MediaTek USB Port (COM3) 14:40:49 - Drivers : MediaTek Inc. 14:40:49 - Description : MediaTek USB Port 14:40:49 - Checking Device Interface.. 14:40:49 - Device Ack Found.. 14:40:50 - Chip : N/A -> FD06990000 14:40:50 - Error : Auto Detection Failed! 14:40:50 - Hint : Manually Select Cpu From List! 14:40:50 - Finished! in all posible way, in meta he not read info, cpu is on list is not supported ? |
07-07-2020, 04:34 | #3 (permalink) |
Member: 1591394 Status: Offline Thanks Meter: 552 | 05:33:02 - Initializing.. 05:33:06 - Token ID : 130B1B13051B032A 05:33:06 - Serial : 00002305 05:33:06 - 1 - Power off Phone.. 05:33:06 - 2 - Remove Install Battery if Needed.. 05:33:06 - 3 - Connect Usb Cable to Powered off Phone.. 05:33:06 - Waiting for Device Interface.. 05:33:11 - Interface Found : COM9 : MediaTek PreLoader USB VCOM (Android) (COM9) 05:33:11 - Drivers : MediaTek Inc. 05:33:11 - Description : MediaTek PreLoader USB VCOM (Android) 05:33:12 - Checking Device Interface.. 05:33:12 - Error : Phone not found.. 05:33:12 - Finished! 05:33:55 - Initializing.. 05:34:00 - Token ID : 130B1B13051B032A 05:34:00 - Serial : 00002305 05:34:00 - 1 - Power off Phone.. 05:34:00 - 2 - Remove Install Battery if Needed.. 05:34:00 - 3 - Connect Usb Cable to Powered off Phone.. 05:34:00 - Waiting for Device Interface.. 05:34:03 - Interface Found : COM8 : MediaTek USB Port (COM8) 05:34:03 - Drivers : MediaTek Inc. 05:34:03 - Description : MediaTek USB Port 05:34:03 - Checking Device Interface.. 05:34:04 - Device Ack Found.. 05:34:05 - Chip : N/A -> FD06990000 05:34:05 - Error : Auto Detection Failed! 05:34:05 - Hint : Manually Select Cpu From List! 05:34:05 - Finished! |
