01-04-2022, 13:51 | #1 (permalink) |
Major Poster Join Date: Nov 2018
Member: 2875935 Status: Offline Thanks Meter: 3 | JAT-L29 Flash Problem 13:48:26 - Creating Device Service.. [LibUsb] 13:48:26 - Hint : How to Connect ? 13:48:26 - Brom Mode : Press Vol and Connect Usb Cable 13:48:26 - Preloader Mode : Connect Usb Cable to Powered off Phone.. 13:48:26 - Waiting for Device Interface.. 13:49:18 - Device Found : \\?\usb#vid_0e8d&pid_2000#5&2a2b26f7&0&4# 13:49:18 - Mode : [Preloader] COM35 - MediaTek PreLoader USB VCOM (Android) (COM35) 13:49:18 - Drivers : MediaTek Inc.,usb2ser.sys [9-11-2014] [3.0.1437.1] 13:49:19 - Checking Device Interface.. 13:49:19 - Error : Phone not found.. 13:49:19 - Finished! |
01-07-2022, 10:47 | #5 (permalink) |
Member: 2875935 Status: Offline Thanks Meter: 3 | 13:48:25 - Installing Device Drivers.. 13:48:26 - Creating Device Service.. [LibUsb] 13:48:26 - Hint : How to Connect ? 13:48:26 - Brom Mode : Press Vol and Connect Usb Cable 13:48:26 - Preloader Mode : Connect Usb Cable to Powered off Phone.. 13:48:26 - Waiting for Device Interface.. 13:49:18 - Device Found : \\?\usb#vid_0e8d&pid_2000#5&2a2b26f7&0&4# 13:49:18 - Mode : [Preloader] COM35 - MediaTek PreLoader USB VCOM (Android) (COM35) 13:49:18 - Drivers : MediaTek Inc.,usb2ser.sys [9-11-2014] [3.0.1437.1] 13:49:19 - Checking Device Interface.. 13:49:19 - Error : Phone not found.. 13:49:19 - Finished! 5.3 version |
01-07-2022, 12:34 | #6 (permalink) |
Member: 2875935 Status: Offline Thanks Meter: 3 | 12:33:12 - Waiting for Device Interface.. 12:33:30 - Device Found : \\?\usb#vid_0e8d&pid_0003#6&265d47d&0&5# 12:33:30 - Mode : [BootRom] COM7 - MediaTek USB Port (COM7) 12:33:30 - Drivers : MediaTek Inc.,usb2ser.sys [1-22-2015] [3.0.1504.0] 12:33:30 - Checking Device Interface.. 12:33:31 - Device Ack Found.. 12:33:32 - HW ID : [0766] [8A00-CA00-0000] [000000E5] 12:33:32 - Secure Boot Device : True 12:33:32 - SL Authorization : False 12:33:32 - DA Authorization : True 12:33:32 - [SwJtag : True] [EPP : False] [Root Cert : False] 12:33:32 - [M_Read Auth : True] [M_Write Auth : True] [Cmd_C8 : True] 12:33:32 - Disabling Watchdog Timer.. 12:33:32 - Cpu : MT6765 12:33:32 - Disabling Protection.. 12:33:32 - Opening Device Drivers Interface.. 12:33:32 - Response : 0xA1A2A3A4 - 251996 12:33:33 - Loading Files... 12:33:33 - Checking Device Configuration.. Please Wait 12:33:33 - Da File : MTK_AllInOne_DA1.bin 12:33:33 - Flashing Method : Normal Flashing 12:33:33 - Checking File 0 [preloader].. ok 12:33:33 - Checking File 11 [spmfw].. ok 12:33:33 - Checking File 12 [scp1].. ok 12:33:33 - Checking File 13 [sspm_1].. ok 12:33:33 - Checking File 26 [lk].. ok 12:33:33 - Checking File 27 [tee1].. ok 12:33:33 - Checking File 35 [dtbo].. ok 12:33:33 - Chip : MT6765 12:33:33 - Storage : EMMC 12:33:33 - High-Speed Port is Disabled... 12:33:33 - Flashing Method : Normal Flashing 12:33:33 - Starting Flash Task... 12:33:35 - Checking Download-Agent.. 12:33:35 - Error : Files Missing [Reinstall Setup] 12:33:35 - Finished! |
01-07-2022, 13:01 | #7 (permalink) |
Member: 2875935 Status: Offline Thanks Meter: 3 | 13:00:21 - Drivers : MediaTek Inc.,usb2ser.sys [1-22-2015] [3.0.1504.0] 13:00:22 - Checking Device Interface.. 13:00:22 - Device Ack Found.. 13:00:23 - Chip : MT6765 [Helio P35/G35] 13:00:23 - HW ID : [FD07660000] [8A00-CA00-0000] [000000E5] 13:00:23 - MEID : D3365E29361E8C247DE95517C938DF3B 13:00:24 - BL Version : FE [03] 13:00:24 - Secure Boot Device : True 13:00:24 - SL Authorization : False 13:00:24 - DA Authorization : True 13:00:24 - [SwJtag : True] [EPP : False] [Root Cert : False] 13:00:24 - [M_Read Auth : True] [M_Write Auth : True] [Cmd_C8 : True] 13:00:25 - Disabling Watchdog Timer.. 13:00:25 - Cpu : MT6765 13:00:25 - Disabling Protection.. 13:00:25 - Opening Device Drivers Interface.. 13:00:25 - Response : 0xA1A2A3A4 - 251996 13:00:25 - Waiting for Device Interface.. 13:00:25 - Device Found : \\?\usb#vid_0e8d&pid_0003#6&265d47d&0&5# 13:00:25 - Mode : [BootRom] COM7 - MediaTek USB Port (COM7) 13:00:25 - Drivers : MediaTek Inc.,usb2ser.sys [1-22-2015] [3.0.1504.0] 13:00:25 - Selected : Huawei - JAT-L29 - MT6765 13:00:25 - BL Version : FE [03] |
01-08-2022, 11:29 | #9 (permalink) |
Member: 2875935 Status: Offline Thanks Meter: 3 | 11:28:52 - Drivers : MediaTek Inc.,usb2ser.sys [9-11-2014] [3.0.1437.1] 11:28:52 - Checking Device Interface.. 11:28:53 - Device Ack Found.. 11:28:54 - HW ID : [0766] [8A00-CA00-0000] [000000E5] 11:28:54 - Secure Boot Device : True 11:28:54 - SL Authorization : False 11:28:54 - DA Authorization : True 11:28:54 - [SwJtag : True] [EPP : False] [Root Cert : False] 11:28:54 - [M_Read Auth : True] [M_Write Auth : True] [Cmd_C8 : True] 11:28:54 - Disabling Watchdog Timer.. 11:28:54 - Cpu : MT6765 11:28:54 - Disabling Protection.. 11:28:54 - Opening Device Drivers Interface.. 11:28:54 - Response : 0xA1A2A3A4 - 253936 11:28:54 - Loading Files... 11:28:54 - Checking Device Configuration.. Please Wait 11:28:55 - Da File : MTK_AllInOne_DA1.bin 11:28:55 - Flashing Method : Normal Flashing 11:28:55 - Checking File 0 [preloader].. ok 11:28:55 - Checking File 11 [spmfw].. ok 11:28:55 - Checking File 12 [scp1].. ok 11:28:55 - Checking File 13 [sspm_1].. ok 11:28:55 - Checking File 26 [lk].. ok 11:28:55 - Checking File 27 [tee1].. ok 11:28:55 - Checking File 35 [dtbo].. ok 11:28:55 - Chip : MT6765 11:28:55 - Storage : EMMC 11:28:55 - High-Speed Port is Disabled... 11:28:55 - Flashing Method : Normal Flashing 11:28:55 - Starting Flash Task... 11:28:57 - Checking Download-Agent.. 11:28:57 - Error : Files Missing [Reinstall Setup] 11:28:57 - Finished! |
01-10-2022, 12:18 | #11 (permalink) |
Member: 2875935 Status: Offline Thanks Meter: 3 | 12:17:27 - [SwJtag : True] [EPP : False] [Root Cert : False] 12:17:27 - [M_Read Auth : True] [M_Write Auth : True] [Cmd_C8 : True] 12:17:27 - Disabling Watchdog Timer.. 12:17:27 - Cpu : MT6765 12:17:27 - Disabling Protection.. 12:17:27 - Opening Device Drivers Interface.. 12:17:27 - Response : 0xA1A2A3A4 - -369098744 12:17:27 - Hint: Please Manually Select Model or Preloader for this Phone.. 12:17:27 - Loading Files... 12:17:28 - Checking Device Configuration.. Please Wait 12:17:28 - Da File : MTK_AllInOne_DA1.bin 12:17:28 - Flashing Method : Normal Flashing 12:17:28 - Checking File 0 [preloader].. ok 12:17:28 - Checking File 11 [spmfw].. ok 12:17:28 - Checking File 12 [scp1].. ok 12:17:28 - Checking File 13 [sspm_1].. ok 12:17:28 - Checking File 15 [oeminfo].. ok 12:17:28 - Checking File 17 [log].. ok 12:17:28 - Checking File 21 [efuse].. ok 12:17:28 - Checking File 22 [cache].. ok 12:17:28 - Checking File 23 [recovery_vbmeta].. ok 12:17:28 - Checking File 24 [erecovery_vbmeta].. ok 12:17:28 - Checking File 25 [vbmeta].. ok 12:17:28 - Checking File 26 [lk].. ok 12:17:28 - Checking File 27 [tee1].. ok 12:17:28 - Checking File 28 [md1img].. ok 12:17:28 - Checking File 29 [recovery_ramdisk].. ok 12:17:28 - Checking File 30 [recovery_vendor].. ok 12:17:28 - Checking File 31 [erecovery_kernel].. ok 12:17:28 - Checking File 32 [erecovery_ramdisk].. ok 12:17:28 - Checking File 33 [erecovery_vendor].. ok 12:17:28 - Checking File 35 [dtbo].. ok 12:17:28 - Checking File 36 [boot].. ok 12:17:28 - Checking File 37 [eng_vendor].. ok 12:17:28 - Checking File 38 [eng_system].. ok 12:17:28 - Checking File 41 [odm].. ok 12:17:28 - Checking File 42 [vendor].. ok 12:17:28 - Checking File 43 [cust].. ok 12:17:28 - Checking File 44 [product].. ok 12:17:28 - Checking File 45 [system].. ok 12:17:28 - Checking File 46 [version].. ok 12:17:28 - Checking File 47 [preload].. ok 12:17:28 - Chip : MT6765 12:17:28 - Storage : EMMC 12:17:28 - Using High-Speed Port... 12:17:28 - Flashing Method : Normal Flashing 12:17:28 - Starting Flash Task... 12:17:28 - Finished! Jat-l29 dead |
