Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Magico Box Team > iBox
Old 06-03-2020, 07:00   #1 (permalink)
MagicoTeam's Avatar
Member: 2916325
Thanks Meter: 1,375
Post iBox/iRepair Box Tutorial Video| How to unbind 6s/6sp/7/7p/8/8p/x WiFi No solder Nand
iBox mini/iRepair Box
Features:
  • Support for Win7/8/10 systems
  • Support for iPhone 6/6P/6S/6SP/7/7P/8/8P/X
  • Upgrade models freely
  • Upgrade software automatically
  • Support One-Click Unpack WiFi Data of NAND for 6S/6SP/7/7P/8/8P/X
  • No Need to Remove NAND for 6/6P/6S/6SP/7/7P/8/8P/X when removing and changing IC kits
  • Support to 6/6P/6S/6SP/7/7P/8/8P/X read and write the iPhone Serial number, Bluetooth/Wifi code, Model, Country, Camera, and all other SYSCFG data without disassembling
  • One-click into the DFU ( Development Firmware Upgrade), that is, the iPhone firmware forced lifting mode
  • can change the bottom data of Nand HDD chip directly Without Removal chip from mother board , supports All displays like 7P and 8P DTP screen and C11
http://www.youtube.com/watch?v=xsqqkIofK4M
The Following 17 Users Say Thank You to MagicoTeam For This Useful Post:
Old 06-03-2020, 07:27   #2 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 170
Originally Posted by MagicoTeam View Post
iRepair Box
Features:
Add nand format option....
The Following 5 Users Say Thank You to oktay50000 For This Useful Post:
Old 06-03-2020, 09:54   #3 (permalink)
ngocdiemmobile's Avatar
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 167
where is soft dowload
Old 06-03-2020, 10:30   #4 (permalink)
Member: 1725884
Thanks Meter: 288
good work what about repair error 4013 and format HDD for old and new models is it supported?
The Following 2 Users Say Thank You to abo anas zayan For This Useful Post:
Old 06-03-2020, 10:33   #5 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 170
https://forum.gsmhosting.com/vbb/f10...-link-2843092/
The Following User Says Thank You to oktay50000 For This Useful Post:
Old 06-03-2020, 11:04   #6 (permalink)
algerienbox's Avatar
Member: 591880
Thanks Meter: 560
that mean if i change Sn can i bypass Icloud and have network ??
The Following 2 Users Say Thank You to algerienbox For This Useful Post:
Old 06-03-2020, 14:57   #7 (permalink)
Member: 1418143
Thanks Meter: 352
site is in chinesse .
Old 06-03-2020, 15:02   #8 (permalink)
Member: 2951726
Sonork: 12345678
Thanks Meter: 2
Need help buy
The product is good. You can read more where to buy.
here to buy :
http://www.magico-team.com/index.php...3d5df4242ec3f/
Old 06-03-2020, 15:15   #9 (permalink)
killme12's Avatar
Member: 682054
Sonork: 100.1602688
Thanks Meter: 138
What bout Ipads is it supported ...........................
Old 06-03-2020, 17:58   #10 (permalink)
hitibiti's Avatar
Member: 24023
Sonork: 100.61317
Thanks Meter: 2,626
yes you can check supported ipad and iphone here :
https://forum.gsmhosting.com/vbb/13936501-post1.html
The Following User Says Thank You to hitibiti For This Useful Post:
Old 06-03-2020, 20:41   #11 (permalink)
oktay50000's Avatar
Member: 678886
Sonork: 100.1661586
Thanks Meter: 170
Ipad not supported yet
Old 06-03-2020, 22:07   #12 (permalink)
Member: 1418242
Thanks Meter: 48
No won't work as Imei and sn need to match. Imei is burned to bb and can't be changed with this tool. it writes those data to SysCfg which is part of nand.So if you just change s/n etc you simply won't be able to activate the idevice...
This tool is very useful if you change wifi chips, but won't help with icloud locked devices for now.
The Following 2 Users Say Thank You to questler For This Useful Post:
Old 06-03-2020, 22:39   #13 (permalink)
bilm25's Avatar
Member: 78657
Thanks Meter: 71
can format the nand ?
Old 06-03-2020, 22:51   #14 (permalink)
Member: 1418242
Thanks Meter: 48
As far as I understand the description from @magicoteam this isn't possible as this tool can "only" change the data in bottom nand.
The Following User Says Thank You to questler For This Useful Post:
Old 06-04-2020, 02:09   #15 (permalink)
Member: 621698
Thanks Meter: 400
iRepair box is ok if you will just repair bottom nand or repair bluetooth ( gray out ) but for iCloud or SN or imei change this tool is not for you
Once I get many job for bluetooth repair ( for ip6 - ip x ) then I will buy it at the moment I never had one at my shop at all for this models
If this tool can do imei repair, S/N repair, and remove icloud via software. Magico team will make millions ( triple digits ) of $$$,$$$,$$$
The Following 2 Users Say Thank You to mymiela0419 For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.19749 seconds with 7 queries
