Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Magico Box Team > Magico Diag Tool
Old 02-09-2021, 13:28   #1 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 115
iPad 7 MDM need help
Hello team
Can you assist me how to remove MDM from iPad 7?
I have one with such a a problem. I bought the bypass at other site, but I wanted to remove forever the MDM, by changing the serial.
I bought the serial sets at my favourite site but there are not A10 or A12 WIFI sets to buy, so I bought A8 set of WIFI-Bluetooth infos and when they come normally they came as always iPad 4 Generations like this below:
IPAD (4TH GENERATION)
Serial Number DLXJXXXXXX86
Find My iPhone OFF
So I suspect that these infos may not be appropriate for the model that I have in hand:
ipad 7th generation
>>> Reading hard disk information
    SN    : DMQCXXXXXXXXM
    Mod#  : MW742
    Area  : FD/A
    Colour: black
    WIFI  : 7C:AB:60:E5:F0:67
    BMac  : 7C:AB:60:EB:35:68
    EMac  : 7C:AB:60:ED:63:6C
    MLB   : DMP02377CT7LT8WAZ
    Model : A2197
    NvSn  : F5802163ZXXXXXXXGABB
    NSrN  : 0706091C1400C095CC61A8FD00000000
    LCM   : FN101940MA9L87VBFW4AN6B904DY901840FNXL9DHAUBD1BAA2XXXXXXXXXXXXXXXXXFYX
    Batt  : D86021515YSLMKNCV
    BCMS  : F6D0213188THXG4AS
    FCMS  : DNM021235ENG2DP5U
    MtSN  : FX802150E70L91PAL320
    Hard drive capacity: 31 GB
>>> operations are done...
or do I need to change something else apart from the serial and wifi and bluetooth address?
Because when I changed only serial and wifi and bluetooth with the bought sets then Unable to activate iPad appeared on the screen
Thanks
Old 02-12-2021, 07:36   #2 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,815
hello
after write sn wifi bt restore your ipad wait to done
The Following User Says Thank You to ernie78™ For This Useful Post:
Old 02-24-2021, 18:35   #3 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 115
Originally Posted by ernie78™ View Post
hello
With A8 infos you think it will be activated ?
I was not able to activate it
Regards
Old 02-24-2021, 19:00   #4 (permalink)
Member: 2612403
Sonork: 100.1575170
Thanks Meter: 115
Yes really working, I didn't restore after writing those , thanks ernie78™
Old 03-01-2021, 08:26   #5 (permalink)
MagicoTeam's Avatar
Member: 2916325
Thanks Meter: 1,383
air2/mini4/2017, iP server problem, can not be activated now, you can try bypass
Page generated in 0.11785 seconds with 8 queries
