GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Magico Diag Tool (https://forum.gsmhosting.com/vbb/f1095/)
-   -   Magico Diag Tool software supported phones and features (https://forum.gsmhosting.com/vbb/f1095/magico-diag-tool-software-supported-phones-features-2892294/)
MagicoTeam 08-27-2020 04:59
Magico Diag Tool Features:
Non-removal Prgrammer For iPhone/iPad without disassembling. Magico Diag Tool can read and write Nand flash for iPhone/iPad without disaembling.
Connect the lightning connector of Magico Diag Tool to your iPhone/iPad (enter DFU mode manually) and the USB connector of Magico Diag Tool to your device charger, power bank, or PC USB port. After 5~10 seconds, your iPhone/iPad will enter Engineering Mode (also called Purple-screen Mode) automatically.
Supported models:
iPhone SE
iPhone 6
iPhone 6P
iPhone 6S
iPhone 6SP
iPhone 7
iPhone 7P
iPhone 8
iPhone 8P
iPhone X
iPad Mini4(A1538,A1550)
iPad 5 (A1822)
iPad 6 (A1893)
iPad Air2(A1566,A1567)
iPad Pro (10.5)(A1701,A1709)
iPad Pro2(12.9) (A1670,A1671,A1821)
iPad 7(2019)(A2197,A2198,A2199,A2200)
1.WiFi Replacement
For 6S/6SP/7/7P/8/8P/X, the WiFi IC can be replaced directly without removing Nand,connect iPhone to Magico Diag Tool to unbind WiFi.
2.Motherboard Replacement
No need to remove Nand flash from motherboard, Nand SYSCFG data can be read/written directly from Magico Diag Tool
3.Expand Nand storage
Backup the Nand data by Magico Diag Tool,assemble the iPhone/iPad after replacing the Nand flash,and then use Magico Diag Tool to write the Nand data directly.Magico Diag Tool Support iPhone&iPad expansion of NAND capacity from 16GB to 64GB/128GB/256GB(Need to prepare a new 64GB/128GB/256G NAND chip).
4.Modify SYSCFG DATA
Q:What Data does the NAND chip SYSCFG DATA include? A: The NAND DATA includes: SN,Model,Area,Colour,WiFi,Bluetooth address,Emac,MLB,Model,NvSn,NSrN,LCM,Batt,BCMS,FCM S,MtSN DATA.
5.Replace iPhone&iPad Broken HDD with New HDD
Disassemble the broken hard drive off from your motherboard and assemble a good one on. Flash your device and then you can use 3utools to check for your phone’s IMEI. Pay to check the SN,Bluetooth, and WiFi information for your iPhone by using your iPhone IMEI.
6.Solve the problem that the 7P/8P DTP LCD does not work(not Touch ) after replacing the C11 LCD.
Magico Diag Tool can change the“bottom data” data of NAND HDD clip directly without removal clip from mother board,supports all displays like 7P and 8P DTP screen and C11 screen.
7.Repair iPhone/iPad HDD/NAND with Errors
Repair NAND with error codes for partial error during flash (e.g. error code 6, 9, 14, 21, 40,4013, 4014, etc.) but with no physical damage.
8.Unlock iPad
Connect the iPad to Magico Diag Tool,write the new data:SN/BT/WiFi(without iCloud data)to Nand,Restore the iPad, and activate it . you can program the iPhone/iPad Nand flash without removing.
9.About update
More iPhone/iPad models will be supported in the future.Upgrade software online.To make our software better for you, we bring updates regularly. Every update of our software includes improvements for stability and bugfixes.
If you have any feedback or run into issues, come find us at our live support, we are happy to help you.
http://www.youtube.com/watch?v=IwHoYkIe-lE
BIBLE 08-27-2020 10:36
any authorised reseller in nepal
thomp4pal 02-19-2021 09:15
how can i Pay to check the SN,Bluetooth, and WiFi information, who offer this service?
kashi_ucb 02-19-2021 15:12
Go AliExpress you will Find there
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.07977 seconds with 6 queries
