Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2019 Location: CHINA
Member: 2916325 Status: Offline Thanks Meter: 1,241 | ![]() Non-removal Prgrammer For iPhone/iPad without disassembling. Magico Diag Tool can read and write Nand flash for iPhone/iPad without disaembling. Connect the lightning connector of Magico Diag Tool to your iPhone/iPad (enter DFU mode manually) and the USB connector of Magico Diag Tool to your device charger, power bank, or PC USB port. After 5~10 seconds, your iPhone/iPad will enter Engineering Mode (also called Purple-screen Mode) automatically. Supported models: iPhone SE iPhone 6 iPhone 6P iPhone 6S iPhone 6SP iPhone 7 iPhone 7P iPhone 8 iPhone 8P iPhone X iPad Mini4(A1538,A1550) iPad 5 (A1822) iPad 6 (A1893) iPad Air2(A1566,A1567) iPad Pro (10.5)(A1701,A1709) iPad Pro2(12.9) (A1670,A1671,A1821) iPad 7(2019)(A2197,A2198,A2199,A2200) 1.WiFi Replacement For 6S/6SP/7/7P/8/8P/X, the WiFi IC can be replaced directly without removing Nand,connect iPhone to Magico Diag Tool to unbind WiFi. 2.Motherboard Replacement No need to remove Nand flash from motherboard, Nand SYSCFG data can be read/written directly from Magico Diag Tool 3.Expand Nand storage Backup the Nand data by Magico Diag Tool,assemble the iPhone/iPad after replacing the Nand flash,and then use Magico Diag Tool to write the Nand data directly.Magico Diag Tool Support iPhone&iPad expansion of NAND capacity from 16GB to 64GB/128GB/256GB(Need to prepare a new 64GB/128GB/256G NAND chip). 4.Modify SYSCFG DATA Q:What Data does the NAND chip SYSCFG DATA include? A: The NAND DATA includes: SN,Model,Area,Colour,WiFi,Bluetooth address,Emac,MLB,Model,NvSn,NSrN,LCM,Batt,BCMS,FCM S,MtSN DATA. 5.Replace iPhone&iPad Broken HDD with New HDD Disassemble the broken hard drive off from your motherboard and assemble a good one on. Flash your device and then you can use 3utools to check for your phone’s IMEI. Pay to check the SN,Bluetooth, and WiFi information for your iPhone by using your iPhone IMEI. 6.Solve the problem that the 7P/8P DTP LCD does not work(not Touch ) after replacing the C11 LCD. Magico Diag Tool can change the“bottom data” data of NAND HDD clip directly without removal clip from mother board,supports all displays like 7P and 8P DTP screen and C11 screen. 7.Repair iPhone/iPad HDD/NAND with Errors Repair NAND with error codes for partial error during flash (e.g. error code 6, 9, 14, 21, 40,4013, 4014, etc.) but with no physical damage. 8.Unlock iPad Connect the iPad to Magico Diag Tool,write the new data:SN/BT/WiFi(without iCloud data)to Nand,Restore the iPad, and activate it . you can program the iPhone/iPad Nand flash without removing. 9.About update More iPhone/iPad models will be supported in the future.Upgrade software online.To make our software better for you, we bring updates regularly. Every update of our software includes improvements for stability and bugfixes. If you have any feedback or run into issues, come find us at our live support, we are happy to help you. Last edited by MagicoTeam; 08-27-2020 at 05:05. |
The Following 3 Users Say Thank You to MagicoTeam For This Useful Post: |
