Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > AMT-dongle
Old 10-13-2021, 15:32   #1 (permalink)
Member: 2729868
Thanks Meter: 7
Honor 8a jat-al00 id done but still active
Waiting for bootrom usb device... ok
BootMode : BootRom[COM3]
USBDriver : wdm_usb:ver:10.0.19041.1202:06/21/2006
● Chipset MT6765 {8A00_CA00}(Helio P35)
BRom::SecLib:000000E5{SBC:Yes:SLA:NoAA:Yes}
● BR_MEID:0x752DFC036BA0726C50473D6D8B9ABC33
● SOCID:0x3AA087FDA68E44434873A768C387FF10
● SOCID:0xE4514935A2E1774FA297CEEA289FEC67
Sending certificate file...
Sending usb control data...
Dumping Bloader info from sram...
Sending download agent...
Executing download agent...
Wiat for 1st DA sync cahr...
Successfully received DA sync cahr
Setup device enviroment...
Setup device parametres...
Successfully received 1nd DA sync signal
Start init ext_ram...
Booting DA and get RamInfo...
● SRAM Type:None(Size:224.00KB)
● DRAM Type:GENERAL_DRAM(Size:3.00GB)
Sync with DA...
● Storage eMMC
===== wait for DA H/W detection report =====
● CID 90014A68423861503E0142A719ACC683
● eMMCID hB8aP>
● Boot1 4.00MB
● Boot1 4.00MB
● Rpmb 16.00MB
● Userarea 29.12GB
Removing Huawei ID...
RPMB Key data block found at {0x00000003}
Remove Huawei ID succes
Rebooting device... Done
operation finished in : [00:min:28:sec]
Log file saved to :
Old 10-14-2021, 07:37   #2 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
Sync with DA...
● Storage eMMC
● eMMCID hB8aP>
● Boot1 4.00MB
● Boot1 4.00MB
● Rpmb 16.00MB
● Userarea 29.12GB
Log file saved to :
Hello, there are two ways to do it, I don't know which one you have done,
1. You check by model and search huawei for the model.
2. section one click and tick remove huawei id that I think what you will have done.
The other way to do it the same as in section 1 and then we go to the huawei box or section, you can give read info and so you can know what firmware you have in case you have to downgrade security, then remove huawei id and finally fix huawei id data, post complete logs and screenshots and if you have found it satisfactory.
In the event that you will not have to downgrade security and then it will let you do the baypass.
The Following 2 Users Say Thank You to Franky_36 For This Useful Post:
Old 10-15-2021, 20:01   #3 (permalink)
Member: 2729868
Thanks Meter: 7
DONE SUCCESSFULLY USING SECOND METHOD
Downloading BootRom Da data...
BootRom successfully connected!
Receiving boot Information...
ChipID : MT6765
Storage : EMMC
UA Size : 29.12 GB
DRAM : 3.00 GB
SRAM : 512.00 KB
Boot1 : 4.00 MB
Boot2 : 4.00 MB
Rpmb : 16.00 MB
RNID : 216DDD5D5A921A4972418F1B54CEF32B
Emmc Cid : 90014A68423861503E0142A719ACC683
Emmc Oem : hB8aP>
Emmc Vid : SKHYNIX
Reading PMT Information ...
PMT Read OK [Type:64Bit] [Part Count:50]
EMI Info : preloader_k62v1_64_mexico_V35
CUST : JAT-AL00-CUST 9.1.0.106(C00)
PRELOAD : JAT-AL00-PRELOAD 9.0.1.2(C00R2)
SYSTEM : JAT-LGRP1-CHN 9.1.0.246
Removing Huawei ID ... OK
wait until phone power on
set password screenlock
reboot your phone and do Fix Huawei ID
Rebooting phone ... OK
The Following User Says Thank You to humbo For This Useful Post:
Old 10-16-2021, 06:36   #4 (permalink)
Franky_36's Avatar
Member: 2665389
Thanks Meter: 2,342
ChipID : MT6765
Storage : EMMC
UA Size : 29.12 GB
DRAM : 3.00 GB
SRAM : 512.00 KB
Boot1 : 4.00 MB
Boot2 : 4.00 MB
Rpmb : 16.00 MB
Emmc Oem : hB8aP>
Emmc Vid : SKHYNIX
Hello, I am very glad that the explanation has served you, thanks for the contribution, greetings.
The Following User Says Thank You to Franky_36 For This Useful Post:
Page generated in 0.13714 seconds with 8 queries
