04-19-2021, 11:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | mi a2 lite frp reset done Code: Application Started : 2021-04-19 00:01:56 Smart Card Serial Number : 0400E92B BROM_v7.2016.00_2021/01/19 23:33:38 META_v10.2036.00.03_2020/12/26 18:39:40 Flash Instructions 1. Choose correct flash files. 2. Device must be at Qualcomm HS-USB Qloader 9008. 3. Check Flash EMMC Check Box if choose RAW DATA File. eMMC Test Instructions 1. Check eMMC after check Adv Option. Format Partition 1. Format Desire Partition after check Adv Option. Unlock Instructions 1. Device must be at Qualcomm HS-USB Qloader 9008. 2. Choose your Unlock Method. 3. Do Operations. Waiting for qcom 9008 port... OK BootMode : qDloader[COM256] Checking device unlock job... OK Connecting port to operate... OK preparing data... Identify Qualcomm Protocol... OK Chipset type 32 bit chipset Handshaking device via port... OK Sending download agent... FAILED (TARGET DEVICE IS UNEXCEPTEDLY REMOVED) Waiting for qcom 9008 port... OK BootMode : qDloader[COM256] Checking device unlock job... OK Connecting port to operate... OK Loading custom dl agent... OK Identify Qualcomm Protocol... OK Chipset type 32 bit chipset Handshaking device via port... OK Sending download agent... OK Configuring fh settings... OK Memory type eMMC Checking partitions data... OK Parsing partitions data... OK Sector size 512 Bytes Userarea size 29820 MB Total partitions 61 partitions Loading partitions information... FAILED (SYSTEM PARTITION NOT FOUND) Identifing corresponded partition... OK Removing frp lock... OK Rebooting device... OK Time Elapsed 00:00:00 |
