09-23-2021, 18:25 | #4 (permalink) |
Registered User Join Date: Aug 2005 Location: Sri lanka Age: 43
Member: 171336 Status: Offline Thanks Meter: 61 | Application Started : 2021-09-23 22:53:30 Smart Card Serial Number : 0400DEC8 BROM_v7.2016.00_2021/01/19 23:03:38 META_v10.2036.00.03_2020/12/26 18:09:40 Flash Instructions 1. Choose correct flash files. 2. Device must be at Qualcomm HS-USB Qloader 9008. 3. Check Flash EMMC Check Box if choose RAW DATA File. eMMC Test Instructions 1. Check eMMC after check Adv Option. Format Partition 1. Format Desire Partition after check Adv Option. Unlock Instructions 1. Device must be at Qualcomm HS-USB Qloader 9008. 2. Choose your Unlock Method. 3. Do Operations. Waiting for qcom 9008 port... OK BootMode : qDloader[COM14] Checking device unlock job... OK Connecting port to operate... OK Loading custom dl agent... OK Identify Qualcomm Protocol... OK Chipset type 32 bit chipset Handshaking device via port... OK Sending download agent... this is massage |
09-23-2021, 18:37 | #5 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
09-23-2021, 18:43 | #6 (permalink) |
Member: 171336 Status: Offline Thanks Meter: 61 | Application Started : 2021-09-23 23:11:32 Smart Card Serial Number : 0400DEC8 BROM_v7.2016.00_2021/01/19 23:03:38 META_vc:\amt-dongle\amt\metacore.dll_C:\AMT-Dongle\AMT\MetaCore.dll Flash Instructions 1. Choose correct flash files. 2. Device must be at Qualcomm HS-USB Qloader 9008. 3. Check Flash EMMC Check Box if choose RAW DATA File. eMMC Test Instructions 1. Check eMMC after check Adv Option. Format Partition 1. Format Desire Partition after check Adv Option. Unlock Instructions 1. Device must be at Qualcomm HS-USB Qloader 9008. 2. Choose your Unlock Method. 3. Do Operations. Waiting for qcom 9008 port... OK BootMode : qDloader[COM14] Checking device unlock job... OK Connecting port to operate... OK Loading custom dl agent... OK Identify Qualcomm Protocol... FAILED (UNIDENTIFIED TYPE) when i select custom loader |
09-23-2021, 23:57 | #7 (permalink) | |
BR | |
09-24-2021, 03:17 | #10 (permalink) |
Member: 171336 Status: Offline Thanks Meter: 61 | same error little information on phone model cph2127 android version 10 baseband version Q_V1_P14_Q_V1_P14 kernal 4.18.95 Master date 202106032045 color os version V7.2 branch cph2127 branch version V0,5 build time 2021/06/03 20:45 ota version CPH2127PU_11_A_81_0810_202106032045 MORDEM VERSION 4 REGEN OPRATOR LK FACTORY VERSION CPH2127PU_11_A_81_210603_6e75a156 |
09-24-2021, 09:27 | #12 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good again, 1.Be careful with multiple and repeated threads, it can be considered spam and the moderators or Smod will attract your attention. 2. For the information provided, it has android version 10 and the latest security patch, it is not supported, it can only be done through isp pinout or by extracting the UFS memory or through the official oppo software with username and password. Greetings. |
The Following User Says Thank You to Franky_36 For This Useful Post: |
