10-13-2021, 15:32 | #1 (permalink) |
Junior Member Join Date: Jun 2017
Member: 2729868 Status: Offline Thanks Meter: 7 | Honor 8a jat-al00 id done but still active BootMode : BootRom[COM3] USBDriver : wdm_usb:ver:10.0.19041.1202:06/21/2006 ● Chipset MT6765 {8A00_CA00}(Helio P35) BRom::SecLib:000000E5{SBC:Yes:SLA:NoAA:Yes} ● BR_MEID:0x752DFC036BA0726C50473D6D8B9ABC33 ● SOCID:0x3AA087FDA68E44434873A768C387FF10 ● SOCID:0xE4514935A2E1774FA297CEEA289FEC67 Sending certificate file... Sending usb control data... Dumping Bloader info from sram... ● Chipset MT6765 {8A00_CA00}(Helio P35) Sending download agent... Executing download agent... Wiat for 1st DA sync cahr... Successfully received DA sync cahr Setup device enviroment... Setup device parametres... Successfully received 1nd DA sync signal Start init ext_ram... Booting DA and get RamInfo... ● SRAM Type:None(Size:224.00KB) ● DRAM Type:GENERAL_DRAM(Size:3.00GB) Sync with DA... ● Storage eMMC ===== wait for DA H/W detection report ===== ● CID 90014A68423861503E0142A719ACC683 ● eMMCID hB8aP> ● Boot1 4.00MB ● Boot1 4.00MB ● Rpmb 16.00MB ● Userarea 29.12GB Removing Huawei ID... RPMB Key data block found at {0x00000003} Remove Huawei ID succes Rebooting device... Done operation finished in : [00:min:28:sec] Log file saved to : |
10-14-2021, 07:37 | #2 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
1. You check by model and search huawei for the model. 2. section one click and tick remove huawei id that I think what you will have done. The other way to do it the same as in section 1 and then we go to the huawei box or section, you can give read info and so you can know what firmware you have in case you have to downgrade security, then remove huawei id and finally fix huawei id data, post complete logs and screenshots and if you have found it satisfactory. In the event that you will not have to downgrade security and then it will let you do the baypass. BR | |
The Following 2 Users Say Thank You to Franky_36 For This Useful Post: |
10-15-2021, 20:01 | #3 (permalink) |
Member: 2729868 Status: Offline Thanks Meter: 7 | DONE SUCCESSFULLY USING SECOND METHOD Waiting for bootrom usb device... ok BootMode : BootRom[COM3] USBDriver : wdm_usb:ver:10.0.19041.1202:06/21/2006 Downloading BootRom Da data... BootRom successfully connected! Receiving boot Information... ChipID : MT6765 Storage : EMMC UA Size : 29.12 GB DRAM : 3.00 GB SRAM : 512.00 KB Boot1 : 4.00 MB Boot2 : 4.00 MB Rpmb : 16.00 MB RNID : 216DDD5D5A921A4972418F1B54CEF32B Emmc Cid : 90014A68423861503E0142A719ACC683 Emmc Oem : hB8aP> Emmc Vid : SKHYNIX Reading PMT Information ... PMT Read OK [Type:64Bit] [Part Count:50] EMI Info : preloader_k62v1_64_mexico_V35 CUST : JAT-AL00-CUST 9.1.0.106(C00) PRELOAD : JAT-AL00-PRELOAD 9.0.1.2(C00R2) SYSTEM : JAT-LGRP1-CHN 9.1.0.246 Removing Huawei ID ... OK wait until phone power on set password screenlock reboot your phone and do Fix Huawei ID Rebooting phone ... OK |
The Following User Says Thank You to humbo For This Useful Post: |
10-16-2021, 06:36 | #4 (permalink) | |
BR | |
The Following User Says Thank You to Franky_36 For This Useful Post: |
