New iccid remove turbo sim method !!! Activation by NEW ICCID REMOVE TURBO SIM METHOD iPhone 6, 6+ and 5s 1.We take the phone, put the jail checkrain 0.12.2 2. THEN INSTALL Apple File Conduit “2” 3.THEN OPEN 3utools info check IOS VERSION AND NOTE EXAMPLE FOR IPHONE 6 PLUS YOU SEE IOS VERSION 12.5 (16H20) 4.THEN OPEN FILES 5.FILES OPEN JAILBREAK 6. THEN OPEN 3uTools path System / Librares / Coreservices/SystemVersion.plist file 7. Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion to 18C66. Then we return and in ProductVersion we change the value to 14.3 Click save and done. 8. We reboot the device with the buttons. The download will be long, with a running status bar. 9. After loading the device, insert the TURBO SIM and enter the current ICCID 89014104279605339274 in the drop-down menu. We go through the activation and we have a fully functioning device. AND REMOVE TURBO AND INSERT ANY SIM YOU WANT WORKING WITH SIGNAL ENJOY!! ------------------------------------------------------------------------------------------------------------------------------------------------- ------------------------------------------------------------------------------------------------------------------------------------------------- Now return the firmware version:THIS IS FOR APP NOT WORKING SOLUTION IS HERE ENJOY !! 1. We take the phone, again we put the jail checkrain 0.12.2 2. Thanks to the Apple File Conduit “2” tweak installed earlier, we connect the phone to any program 3Utools and go to the “File System” section. path System / Libraries / Coreservices/SystemVersion.plist file and Open SystemVersion.plist, find ProductBuildVersion. Change the value of ProductBuildVersion BACK to 16H20 Then we return and in ProductVersion we change the value BACK to 12.5 Click save and done 3. We reboot the device with the buttons. The download will be long, with a running status bar!! That's all 4.The phoneone remains on the old firmware 12.5 and works as a non-wizard. After all the manipulations, all applications work stably ------------------------------------------------------------------------------------------------------------------------------------------------------ ------------------------------------------------------------------------------------------------------------------------------------------------------ last step remove jailbreak icon from phone!! SIMPLE 1. We take the phone, again we put the jail checkrain 0.12.2 2. INSTALL CYDIA AND DO THE LAST STEP REMOVE JAILBREAK THEN ENJOY SIM WORKING WITHOUT TURBO SIM ALL APPS WORKING WITHOUT CYDIA ICON !!! |
Hi Team, Any video?? Regards Sent from my iPhone using Tapatalk |
