04-13-2022, 20:18 | #1 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | 12 pro max stuck on 91 or 96 % i tried another cable same issue latest update itunes and 3utools same issue [CODE]٢٢:٠١:٣٣.٣٥٠: computer disk space Analyzing… ٢٢:٠١:٣٣.٣٥٩: C disk: free space 43.03 GB, Computer firmware cache E: Free space of disk:131.57 GB ٢٢:٠١:٣٣.٣٥٩: Firmware is unpacking ٢٢:٠٣:١٣.٣٠٦: Checking required files ٢٢:٠٣:١٣.٣٢٩: Run the flash program of iTunes ٢٢:٠٣:١٦.١٢٣: restore library built Feb 25 2022 at 14:45:14 ٢٢:٠٣:١٦.١٢٤: WinAMRestore::StartRestoreLog: GetModuleHandleA failed ٢٢:٠٣:١٦.١٢٤: WinAMRestore::AddAppleDeviceToDeviceList: \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB# VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:0 3_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3D#MU X1#175ce5dc ٢٢:٠٣:١٦.١٢٤: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:١٦.١٢٤: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:١٦.١٢٤: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:١٦.١٢٤: AppleDevice::SetNotification: CONNECT, interface type: 1, id: \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C1 4FA8C54}\USB#VID_05AC&PID_1281#SDOM:01_CPID:8101_C PRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C245A0AB900 3A_IBFL:3D#MUX 1#175ce5dc, inst: 0x6fb058 ٢٢:٠٣:١٦.١٢٤: WinAMRestore::AddAppleDeviceToDeviceList, empty list, new device ٢٢:٠٣:١٦.١٢٤: WinAMRestore::AddAppleDeviceToDeviceList: \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\USB# VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:0 3_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3D#MU X1#175ce5dc ٢٢:٠٣:١٦.١٢٥: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:١٦.١٢٥: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:١٦.١٢٥: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:١٦.١٢٥: WinAMRestore::AddAppleDeviceToDeviceList, device already connected, new interface ٢٢:٠٣:١٦.١٢٥: AppleDevice::SetDeviceID: AMD_INTERFACE_IBOOT \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576} \USB#VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_C PFM:03_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL: 3D#MUX1#175ce5 dc, inst: 0x6fb058 ٢٢:٠٣:١٦.١٢٥: AppleDevice::SetNotification: CONNECT, interface type: 1, id: \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E5 2236C576}\USB#VID_05AC&PID_1281#SDOM:01_CPID:8101_ CPRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C245A0AB90 03A_IBFL:3D#MU X1#175ce5dc, inst: 0x6fb058 ٢٢:٠٣:١٦.١٢٥: WinAMRestore::ProcessDevNodesChanges: device: 0x006fb058, notify: 1, connected: 0 ٢٢:٠٣:١٦.١٢٥: AppleDevice::NotifyConnect: Device type: 2, Interfaces total: 2, arrived: 2 ٢٢:٠٣:١٦.١٢٥: AppleDevice::NotifyConnect: IBOOT, IBOOT \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\USB#V ID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:03 _SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3D#MUX 1#175ce5dc, inst : 0x6fb058 ٢٢:٠٣:١٦.١٢٥: IBOOT, DFU \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB#VID_05AC&PID_1281#SDOM:01_C PID:8101_CPRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C 245A0AB9003A_IBFL:3D#MUX1#175ce5dc, inst: 0x6fb058 ٢٢:٠٣:١٦.١٢٥: Recovery mode device connected with ECID: 0xAB9003A ٢٢:٠٣:١٦.١٢٥: Found new device. ٢٢:٠٣:١٦.١٢٥: Found a device with an unknown registration class. ٢٢:٠٣:١٦.١٢٥: Successfully registered new client ٢٢:٠٣:١٦.١٢٥: Registered device change listening service succeeded ٢٢:٠٣:١٦.١٢٥: Searching iDevice, if not connected, please plug in the device again ٢٢:٠٣:١٦.١٢٥: Now tracking 1 clients ٢٢:٠٣:١٦.١٢٥: iTunesVersion: '' ٢٢:٠٣:١٦.١٢٥: Created state machine for device with ECID=0xAB9003A ٢٢:٠٣:١٦.١٢٥: State Machine Dump, status:RUNNING - [state:Recovery remaining-cycles:2 (current state)] -> [state:RestoreOS remaining-cycles:1] ٢٢:٠٣:١٦.١٢٥: Can't get board config with NULL device map ٢٢:٠٣:١٦.١٢٥: requested restore behavior: Erase ٢٢:٠٣:١٦.١٢٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:١٦.١٢٦: Automatically set FormatForAPFS => True and FormatForLwVM => False. ٢٢:٠٣:١٦.١٢٦: Found a device with an unknown registration class. ٢٢:٠٣:١٦.١٢٦: Changing state from '(null)' to 'Restoring' ٢٢:٠٣:١٦.١٢٦: Starting flashing ٢٢:٠٣:١٦.١٢٦: requested restore behavior: Erase ٢٢:٠٣:١٦.١٢٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:١٦.٢٢٨: no override trust object found ٢٢:٠٣:١٦.٢٢٨: requested restore behavior: Erase ٢٢:٠٣:١٦.٢٢٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:١٦.٢٢٨: requested restore behavior: Erase ٢٢:٠٣:١٦.٢٢٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:١٦.٢٢٨: requested variant: Erase ٢٢:٠٣:١٦.٢٢٨: requested restore behavior: Erase ٢٢:٠٣:١٦.٢٢٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:١٦.٢٢٨: amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device ٢٢:٠٣:١٦.٢٢٨: personalizing: <AMAuthInstall 0072DB58>{ap=(personalize=YES d54pap ecid=0x1c245a0ab9003a, chipid=0x8101, boardid=0x8, secDom =1, isProduction=YES, EPRO=YES, isSecure=YES, ESEC=YES, img4=YES, demotionPolicy=, managedBaaCert=NO, slowRollBaaCert=NO , nonce=0xe91b173d62d1305d7a1c2fa3bdc4c8df658f33c062 36d694fe16cab2c510c233, sepNonce=0xd6b8471b4c5386c9c5590a924ffd72a b9de6c9f1), bp=(personalize=YES), UserAuth=NO, iTunes=YES, server="http://gs.apple.com:80", locale=Zh_cn, version="libauthinstall_ Win-851.102.1.100.4", platform=win/6.2(9200) } ٢٢:٠٣:١٦.٢٢٨: amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes ٢٢:٠٣:١٦.٢٢٨: amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes ٢٢:٠٣:١٦.٢٧٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreLogo to Manifest to personalize later ٢٢:٠٣:١٦.٢٧٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDeviceTree to Manifest to personalize later ٢٢:٠٣:١٦.٥٨٥: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreKernelCache to Manifest to personalize later ٢٢:٠٣:١٩.٤٩٠: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreRamDisk to Manifest to personalize later ٢٢:٠٣:١٩.٤٩٠: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBEC to Manifest to personalize later ٢٢:٠٣:١٩.٤٩٠: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBSS to Manifest to personalize later ٢٢:٠٣:١٩.٨٤٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting KernelCache to Manifest to personalize later ٢٢:٠٣:١٩.٨٤٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftap to Manifest to personalize later ٢٢:٠٣:١٩.٨٤٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfta to Manifest to personalize later ٢٢:٠٣:١٩.٨٤٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftsp to Manifest to personalize later ٢٢:٠٣:١٩.٨٤٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfts to Manifest to personalize later ٢٢:٠٣:٢٠.٥٠٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Ap,SystemVolumeCanonicalMetadata to Manifest to personalize late r ٢٢:٠٣:٢٠.٥٠٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SystemVolume to Manifest to personalize later ٢٢:٠٣:٢٠.٥٠٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting OS to Manifest to personalize later ٢٢:٠٣:٢٠.٦٦٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SEP to Manifest to personalize later ٢٢:٠٣:٢٠.٧٦٤: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DCP to Manifest to personalize later ٢٢:٠٣:٢٠.٧٦٤: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LLB to Manifest to personalize later ٢٢:٠٣:٢١.٠١٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Multitouch to Manifest to personalize later ٢٢:٠٣:٢١.٠١٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting WCHFirmwareUpdater to Manifest to personalize later ٢٢:٠٣:٢١.٠١٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RecoveryMode to Manifest to personalize later ٢٢:٠٣:٢١.٠١٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LeapHaptics to Manifest to personalize later ٢٢:٠٣:٢١.٠٧٠: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting GFX to Manifest to personalize later ٢٢:٠٣:٢١.١٢١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AudioCodecFirmware to Manifest to personalize later ٢٢:٠٣:٢١.١٢١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow0 to Manifest to personalize later ٢٢:٠٣:٢١.١٢١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBoot to Manifest to personalize later ٢٢:٠٣:٢١.١٢١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Ap,HapticAssets to Manifest to personalize later ٢٢:٠٣:٢١.١٢١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AppleLogo to Manifest to personalize later ٢٢:٠٣:٢١.١٢١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow1 to Manifest to personalize later ٢٢:٠٣:٢١.١٧٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AVE to Manifest to personalize later ٢٢:٠٣:٢١.١٧٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreTrustCache to Manifest to personalize later ٢٢:٠٣:٢١.١٧٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryFull to Manifest to personalize later ٢٢:٠٣:٢١.٢٢٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreANS to Manifest to personalize later ٢٢:٠٣:٢١.٦٣٠: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ISP to Manifest to personalize later ٢٢:٠٣:٢١.٦٨١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ANS to Manifest to personalize later ٢٢:٠٣:٢١.٧٣٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AOP to Manifest to personalize later ٢٢:٠٣:٢١.٨٣٤: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ANE to Manifest to personalize later ٢٢:٠٣:٢١.٨٣٤: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting StaticTrustCache to Manifest to personalize later ٢٢:٠٣:٢١.٨٣٤: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LowPowerWallet0 to Manifest to personalize later ٢٢:٠٣:٢١.٨٣٤: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LowPowerWallet1 to Manifest to personalize later ٢٢:٠٣:٢١.٨٨٥: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Liquid to Manifest to personalize later ٢٢:٠٣:٢١.٨٨٥: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SIO to Manifest to personalize later ٢٢:٠٣:٢١.٩٣٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting PMP to Manifest to personalize later ٢٢:٠٣:٢١.٩٣٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DeviceTree to Manifest to personalize later ٢٢:٠٣:٢١.٩٣٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBootData to Manifest to personalize later ٢٢:٠٣:٢١.٩٣٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryPlugin to Manifest to personalize later ٢٢:٠٣:٢١.٩٣٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging0 to Manifest to personalize later ٢٢:٠٣:٢١.٩٣٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging1 to Manifest to personalize later ٢٢:٠٣:٢٢.٠٨٩: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreSEP to Manifest to personalize later ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDCP to Manifest to personalize later ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: ticketPath amai/apimg4ticket.der , withApTicket is True, (!False && ( True | | False)) ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreLogo" Digest = "<CFData 00734440 [6419506C]>{leng th = 48, capacity = 48, bytes = 0x91c33272bc181c9a9a30f714b9926115 ... acfab37a06b49a39}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDeviceTree" Digest = "<CFData 00733BB8 [6419506C] >{length = 48, capacity = 48, bytes = 0x28261dd6158076fdf1315d4bee76f3e7 ... b5907f0b7d19d7f5}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreKernelCache" Digest = "<CFData 00733FC8 [6419506 C]>{length = 48, capacity = 48, bytes = 0x7bd527b1fe161b31bfc464f6e76c62d6 ... 232e20184d60f2e6}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreRamDisk" Digest = "<CFData 00734370 [6419506C]>{ length = 48, capacity = 48, bytes = 0xc8a61c2dab9c6cfbd4f904c2e12b60b2 ... 09acb7b67a0d6fe7}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "OSRamdisk" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBEC" Digest = "<CFData 00734238 [6419506C]>{length = 48 , capacity = 48, bytes = 0xfa0eaee47b3bc6da323abf9f435d607f ... 34053004a14839d4}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBSS" Digest = "<CFData 007345E0 [6419506C]>{length = 48 , capacity = 48, bytes = 0xe127b50ca00f4ab6ddce229b17870802 ... a4b03ba3d103381b}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "KernelCache" Digest = "<CFData 00734030 [6419506C]>{len gth = 48, capacity = 48, bytes = 0x6048b53e9d8abe89b02bf117e72c2a35 ... 5daac00578f309bc}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ftap" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "rfta" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ftsp" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "rfts" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "Ap,SystemVolumeCanonicalMetadata" Digest = "<CFData 0 0733DC0 [6419506C]>{length = 48, capacity = 48, bytes = 0x7f5885e1d072a8b8215e45e20a6d4d8d ... 3ef381cd7bd8d8fe}" ٢٢:٠٣:٢٢.١٩١: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "x86,SystemVolumeCanonicalMetadata" not part of manifest, skippin g ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "BaseSystemVolume" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "x86,BaseSystemVolume" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "SystemVolume" Digest = "<CFData 00734100 [6419506C]>{l ength = 48, capacity = 48, bytes = 0x522c403cead547947926c3327c091d34 ... b8f88819c2d37712}" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "x86,SystemVolume" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Ap,BaseSystemTrustCache" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Diags" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "CFELoader" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "RBM" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PHLEET" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PERTOS" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "PEHammer" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: entry "Alamo" not part of manifest, skipping ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "OS" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "SEP" Digest = "<CFData 00734308 [6419506C]>{length = 48 , capacity = 48, bytes = 0xa9b8897d9e08633a5bcb2c585785e4a0 ... ee012ff681f5ce87}" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DCP" Digest = "<CFData 00733C20 [6419506C]>{length = 4 8, capacity = 48, bytes = 0xf93dc4c233e30e42bfcfb67d55c56255 ... 47b3d9480a3d6504}" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LLB" Digest = "<CFData 007344A8 [6419506C]>{length = 48 , capacity = 48, bytes = 0xb0077ef2b49d3aaa25cbda6439c026b8 ... a97170ce1bc05f12}" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "Multitouch" Digest = "<CFData 00734510 [6419506C]>{leng th = 48, capacity = 48, bytes = 0x76ea18578d2d1fc6de88f9a0cf8be97f ... ee0ece1b59f39c80}" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "WCHFirmwareUpdater" Digest = "<CFData 00734648 [64195 06C]>{length = 48, capacity = 48, bytes = 0x650095f58c854aa2a792eaa2091f1210 ... 73c5cf810a5a75f7}" ٢٢:٠٣:٢٢.١٩٢: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RecoveryMode" Digest = "<CFData 00733EF8 [6419506C]>{l ength = 48, capacity = 48, bytes = 0x29ad5d9a5462d79a711d0ab7ed7147a9 ... 54133b512a3dfdd4}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LeapHaptics" Digest = "<CFData 00733F60 [6419506C]>{len gth = 48, capacity = 48, bytes = 0xfa85cffef18ae59e53bfc05e8e47f11e ... f345668bd4639559}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "GFX" Digest = "<CFData 00734578 [6419506C]>{length = 48 , capacity = 48, bytes = 0x58226221329badd195373361b6267348 ... c6236b8c10c06994}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AudioCodecFirmware" Digest = "<CFData 00734850 [64195 06C]>{length = 48, capacity = 48, bytes = 0xe2c82ac4b9824a25d2784f7688e8cc2d ... 2d6f2933d6ac1f37}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow0" Digest = "<CFData 00734AC0 [6419506C]>{len gth = 48, capacity = 48, bytes = 0xa6f3490d2d22afaf2405a91c4bdd2383 ... bbf63e14760f6ce0}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBoot" Digest = "<CFData 00734920 [6419506C]>{length = 4 8, capacity = 48, bytes = 0x34642c73b3491182909e0a9e72f3bbd2 ... 080c029dbe4b7b6f}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "Ap,HapticAssets" Digest = "<CFData 007349F0 [6419506C]> {length = 48, capacity = 48, bytes = 0x0de6b07dfdabe3b51904cc4933115292 ... 2859a7871c7aaafc}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AppleLogo" Digest = "<CFData 007348B8 [6419506C]>{leng th = 48, capacity = 48, bytes = 0xc2fcf1dc492a1f6e4b2f84750570f1b8 ... 03a3f48e2af29378}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryLow1" Digest = "<CFData 00734988 [6419506C]>{len gth = 48, capacity = 48, bytes = 0x0d96a358e28b5300f6de52582e152253 ... 33068c460c12f8c7}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AVE" Digest = "<CFData 00734A58 [6419506C]>{length = 48 , capacity = 48, bytes = 0x0fc291b94aa2b3b4490b464d1956b672 ... 48cdb81a45b0c150}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreTrustCache" Digest = "<CFData 006F8048 [6419506C ]>{length = 48, capacity = 48, bytes = 0xa98fccb034c0661ebad6bc62bfe33671 ... 717fbb94dd2912fc}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryFull" Digest = "<CFData 03127C70 [6419506C]>{leng th = 48, capacity = 48, bytes = 0x527ef8b58abfd876304d314301315591 ... 038af914b937f1df}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreANS" Digest = "<CFData 03127B38 [6419506C]>{len gth = 48, capacity = 48, bytes = 0xd456a11b54087b722916babdb19ca8e7 ... 01e2378a5cbb7dd5}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ISP" Digest = "<CFData 03127A68 [6419506C]>{length = 48 , capacity = 48, bytes = 0x9556a7dd4e04bf8685436688a46f4609 ... 4397df829bebbd91}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ANS" Digest = "<CFData 03127A00 [6419506C]>{length = 4 8, capacity = 48, bytes = 0xd10bd1815ab0ac33c0ec565ce919eda4 ... 7f8a5ce1005f7b35}" ٢٢:٠٣:٢٢.١٩٣: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "AOP" Digest = "<CFData 03127C08 [6419506C]>{length = 4 8, capacity = 48, bytes = 0xb7f5c72491ad06d2dc2cecbb0b989da1 ... 31b28d138769716a}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "ANE" Digest = "<CFData 03127790 [6419506C]>{length = 48 , capacity = 48, bytes = 0x9e915d8f2e41cfff61998990452ae710 ... f0c50461078fe663}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "StaticTrustCache" Digest = "<CFData 031274B8 [6419506C]> {length = 48, capacity = 48, bytes = 0x52c57c73b943a0ac39dd491522d51185 ... 5839a82dd9528361}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LowPowerWallet0" Digest = "<CFData 03127BA0 [6419506C ]>{length = 48, capacity = 48, bytes = 0xe94bace7787207d22a12bfb05446edf0 ... c414995bb59ba35c}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "LowPowerWallet1" Digest = "<CFData 031273E8 [6419506C] >{length = 48, capacity = 48, bytes = 0xaf6bf136938145bf81740990c2da8b80 ... bcc437cb93f90bfe}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "Liquid" Digest = "<CFData 03126FD8 [6419506C]>{length = 48, capacity = 48, bytes = 0x5bf7f85f6706b34733b2498ffa4008ca ... 7316dd2d6ff9ed2f}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "SIO" Digest = "<CFData 03126DD0 [6419506C]>{length = 48 , capacity = 48, bytes = 0xbfdfb668b0d0f445f3fba5e3796fd5e3 ... 93a4be7689daaff9}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "PMP" Digest = "<CFData 03126D00 [6419506C]>{length = 4 8, capacity = 48, bytes = 0x80002acde6978883831047a5d66a09d1 ... 1a68fe23e44fca9f}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "DeviceTree" Digest = "<CFData 03127728 [6419506C]>{lengt h = 48, capacity = 48, bytes = 0xc0fec7aef30b1055953aae3fd1c4dbdb ... 3e6012f8f9e8e3fa}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "iBootData" Digest = "<CFData 03127380 [6419506C]>{length = 48, capacity = 48, bytes = 0x1ca295468a1032602c3efd492364b690 ... 859cee4dbbdbca3b}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryPlugin" Digest = "<CFData 031270A8 [6419506C]>{le ngth = 48, capacity = 48, bytes = 0x54a171898d7ae9e3e36bf97e7614e0c2 ... 6c2a15d2dfa48661}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging0" Digest = "<CFData 03127520 [6419506C] >{length = 48, capacity = 48, bytes = 0x21bc59369270a242a93e5ffffe428dd8 ... 670b129d835fc67a}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "BatteryCharging1" Digest = "<CFData 03127588 [6419506C] >{length = 48, capacity = 48, bytes = 0x298e5977818b132b2033b9d4cf048506 ... da19e46e599940c1}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreSEP" Digest = "<CFData 03127AD0 [6419506C]>{leng th = 48, capacity = 48, bytes = 0xdd66295eab6b7da8436fe0776a351b9f ... 535eb809556cbf56}" ٢٢:٠٣:٢٢.١٩٤: amai: _AMAuthInstallBundleCreateServerRequestDictionary: personalizing "RestoreDCP" Digest = "<CFData 03127318 [6419506C]>{leng th = 48, capacity = 48, bytes = 0x3e51fdc3290077ce664ef913d89ab597 ... 781c7569bce2c1b9}" ٢٢:٠٣:٢٢.١٩٤: amai: AMAuthInstallApCopyDeviceEntryFromDeviceMap: Failed to read devicemap from %2Fusr%2Flocal%2Fstandalone%2Ffirmware% 2Fdevice_map.plist -- file://localhost/C:/Program%20Files%20(x86)/3uTools/ ٢٢:٠٣:٢٢.١٩٤: amai: AMAuthInstallApImg4ServerRequestAddUIDMode: WARNING: Could not apply UID mode from device map. ٢٢:٠٣:٢٢.١٩٥: amai: _AMAuthInstallBundlePopulateManifestProperties: Copying manifest property UniqueBuildID into request ٢٢:٠٣:٢٢.١٩٥: amai: _AMAuthInstallBundlePopulateManifestProperties: Copying manifest property PearlCertificationRootPub into request ٢٢:٠٣:٢٢.٢٤٦: amai: AMAuthInstallRequestSendSync: SSO function returned NULL and no SSO token was provided, SSO disabled. ٢٢:٠٣:٢٢.٢٤٦: amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/0430~1/AppData/Local/Temp/Per17B4.tmp/am ai/debug/tss-request.plist ٢٢:٠٣:٢٢.٢٤٦: amai: tss_submit_job_with_retry: TSS Connection attempt 1 of 3. (Will retry if TSS_ERR_SERVER_NOT_REACHABLE.) ٢٢:٠٣:٢٣.٢١٤: amai: tss_submit_job: HttpQueryInfo returned 200 ٢٢:٠٣:٢٣.٤٦٩: amai: AMAuthInstallRequestSendSync: received tss response (server version: 2.1.0) ٢٢:٠٣:٢٣.٤٦٩: amai: AMAuthInstallDebugWriteObject: debug object written: file://localhost/C:/Users/0430~1/AppData/Local/Temp/Per17B4.tmp/am ai/debug/tss-response.plist ٢٢:٠٣:٢٤.١٨٣: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "OSRamdisk" ٢٢:٠٣:٢٥.١٥١: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "ftap" does not require personalization; skipping it ٢٢:٠٣:٢٥.١٥١: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "rfta" does not require personalization; skipping it ٢٢:٠٣:٢٥.١٥١: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "ftsp" does not require personalization; skipping it ٢٢:٠٣:٢٥.١٥١: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "rfts" does not require personalization; skipping it ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "x86,SystemVolumeCanonicalMetadata" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "BaseSystemVolume" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "x86,BaseSystemVolume" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "x86,SystemVolume" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Ap,BaseSystemTrustCache" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Diags" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "CFELoader" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "RBM" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PHLEET" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PERTOS" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "PEHammer" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundlePopulatePersonalizedBundle: no entry in manifest found for "Alamo" ٢٢:٠٣:٢٧.٣٥٠: amai: _AMAuthInstallBundleInstallPersonalizedEntry: entry "OS" does not require personalization; skipping it ٢٢:٠٣:٣١.٢٤٥: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣١.٢٤٥: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣١.٧٥٥: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣١.٧٥٥: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٢.٢٦٥: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٢.٢٦٥: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٢.٧٧٤: USBControlTransfer: error 2, usbd status 00000000 ٢٢:٠٣:٣٢.٧٧٤: command device request for 'getenv ota-uuid' failed: 2009 ٢٢:٠٣:٣٢.٧٧٤: Failed to copy env variable, error:2009 ٢٢:٠٣:٣٢.٧٧٤: interface has 1 endpoints, file pipe = 1 ٢٢:٠٣:٣٢.٧٧٤: iBoot build-version = iBoot-7459.102.5 ٢٢:٠٣:٣٢.٧٧٤: iBoot build-style = RELEASE ٢٢:٠٣:٣٢.٧٧٤: <Recovery Mode Device 006CAFD8>: operation 4 progress -1 ٢٢:٠٣:٣٢.٨٢٥: unable to open device_map.txt: No such file or directory ٢٢:٠٣:٣٢.٨٢٥: found device map entry for 0x00008101 0x00000008 0x00000001. boardConfig=d54pap platform=t8101 ٢٢:٠٣:٣٢.٨٢٥: _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options ٢٢:٠٣:٣٢.٨٢٥: requested restore behavior: Erase ٢٢:٠٣:٣٢.٨٢٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٢.٨٢٥: requested restore behavior: Erase ٢٢:٠٣:٣٢.٨٢٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٢.٨٢٥: unable to open device_map.txt: No such file or directory ٢٢:٠٣:٣٢.٨٢٥: found device map entry for 0x00008101 0x00000008 0x00000001. boardConfig=d54pap platform=t8101 ٢٢:٠٣:٣٢.٨٢٥: _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options ٢٢:٠٣:٣٢.٨٢٥: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٢.٨٢٥: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٣.٣٣٥: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٣.٣٣٥: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٣.٨٤٥: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٣.٨٤٥: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٤.٣٥٤: USBControlTransfer: error 2, usbd status 00000000 ٢٢:٠٣:٣٤.٣٥٤: command device request for 'getenv radio-error' failed: 2009 ٢٢:٠٣:٣٤.٣٥٤: radio-error not set ٢٢:٠٣:٣٤.٣٥٤: unable to open device_map.txt: No such file or directory ٢٢:٠٣:٣٤.٣٥٤: <Recovery Mode Device 006CAFD8>: production fused device ٢٢:٠٣:٣٤.٣٥٤: unable to open device_map.txt: No such file or directory ٢٢:٠٣:٣٤.٣٥٤: found device map entry for 0x00008101 0x00000008 0x00000001. boardConfig=d54pap platform=t8101 ٢٢:٠٣:٣٤.٣٥٥: _AMRestoreCopyDeviceMapPlistEntryForHardware: firmwareDirectory not in options ٢٢:٠٣:٣٤.٣٥٥: requested restore behavior: Erase ٢٢:٠٣:٣٤.٣٥٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٤.٣٥٥: requested restore behavior: Erase ٢٢:٠٣:٣٤.٣٥٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٤.٤٠٦: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٤.٤٠٦: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٤.٩١٦: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٤.٩١٦: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٥.٤٢٦: AMDeviceIoControl: GetOverlappedResult failed ٢٢:٠٣:٣٥.٤٢٦: AMDeviceIoControl: failed, error 2, usbd status 00000000 ٢٢:٠٣:٣٥.٩٣٥: USBControlTransfer: error 2, usbd status 00000000 ٢٢:٠٣:٣٥.٩٣٥: command device request for 'getenv boot-stage' failed: 2009 ٢٢:٠٣:٣٥.٩٣٥: bootstrapping restore with iBEC ٢٢:٠٣:٣٥.٩٣٥: requested restore behavior: Erase ٢٢:٠٣:٣٥.٩٣٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٥.٩٣٥: Max file size is: 536870912 ٢٢:٠٣:٣٥.٩٣٥: sending file: C:\Users\0430~1\AppData\Local\Temp\Per17B4.tmp\Fir mware\dfu\iBEC_iBEC.d54p.RELEASE.img4 ٢٢:٠٣:٣٥.٩٣٥: Sending iBEC ٢٢:٠٣:٣٥.٩٣٥: The iDevice will switch to black screen recovery mode ٢٢:٠٣:٣٥.٩٨٦: <Recovery Mode Device 006CAFD8>: operation 31 progress -1 ٢٢:٠٣:٣٦.٩٥٥: <Recovery Mode Device 006CAFD8>: Recovery mode succeeded ٢٢:٠٣:٣٦.٩٥٥: Finished Recovery Restore Phase: Successful ٢٢:٠٣:٣٧.٧١٩: WinAMRestore::OnInterfaceRemoval: \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\USB#VID_05 AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:03_SCEP :01_BDID:08_ECID:001C245A0AB9003A_IBFL:3D#MUX1#175 ce5dc ٢٢:٠٣:٣٧.٧١٩: WinAMRestore::ProcessDevNodesChanges: device: 0x006fb058, notify: 2, connected: 1 ٢٢:٠٣:٣٧.٧١٩: AppleDevice::NotifyDisconnect: IBOOT, IBOOT \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\US B#VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM :03_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3D# MUX1#175ce5dc, inst: 0x6fb058 ٢٢:٠٣:٣٧.٧١٩: IBOOT, DFU \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB#VID_05AC&PID_1281#SDOM:01_C PID:8101_CPRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C 245A0AB9003A_IBFL:3D#MUX1#175ce5dc, inst: 0x6fb058 ٢٢:٠٣:٣٧.٧١٩: Recovery mode device disconnected with ECID: 0xAB9003A ٢٢:٠٣:٣٧.٧١٩: WinAMRestore::OnInterfaceRemoval: \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB#VID_05A C&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:03_SCEP: 01_BDID:08_ECID:001C245A0AB9003A_IBFL:3D#MUX1#175c e5dc ٢٢:٠٣:٣٧.٧١٩: Recovery mode device disconnected ٢٢:٠٣:٣٧.٧١٩: Device removed when in state Restoring, moving device to transition state ٢٢:٠٣:٣٧.٧١٩: Changing state from 'Restoring' to 'Transitioning' ٢٢:٠٣:٣٧.٧١٩: Waiting for the iDevice to reconnect after switch mode completed. The maximum waiting time is 10 minutes. ٢٢:٠٣:٣٧.٧١٩: Creating timer to monitor transition ٢٢:٠٣:٣٧.٧١٩: Creating a timer for 10 minutes ٢٢:٠٣:٣٧.٧٢٠: WinAMRestore::ProcessDevNodesChanges: device: 0x006fb058, notify: 2, connected: 0 ٢٢:٠٣:٣٨.٧٨٧: WinAMRestore::OnInterfaceArrival: \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB#VID_05A C&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:03_SCEP: 01_BDID:08_ECID:001C245A0AB9003A_IBFL:3C#MUX1#e2ac 480f ٢٢:٠٣:٣٨.٧٨٧: WinAMRestore::AddAppleDeviceToDeviceList: \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\US B#VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM :03_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3C# MUX1#e2ac480f ٢٢:٠٣:٣٨.٨٨٩: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:٣٨.٩٣٩: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:٣٨.٩٣٩: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:٣٩.٠٤١: AppleDevice::SetNotification: CONNECT, interface type: 1, id: \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C1 4FA8C54}\USB#VID_05AC&PID_1281#SDOM:01_CPID:8101_C PRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C245A0AB900 3A_IBFL:3C#MUX 1#e2ac480f, inst: 0x762a70 ٢٢:٠٣:٣٩.٠٤١: WinAMRestore::AddAppleDeviceToDeviceList, new device ٢٢:٠٣:٣٩.٠٤١: WinAMRestore::ProcessDevNodesChanges: device: 0x006fb058, notify: 2, connected: 0 ٢٢:٠٣:٣٩.٠٤١: WinAMRestore::ProcessDevNodesChanges: device: 0x00762a70, notify: 1, connected: 0 ٢٢:٠٣:٣٩.٠٤١: AppleDevice::NotifyConnect: Device type: 2, Interfaces total: 2, arrived: 1 ٢٢:٠٣:٣٩.٠٤١: AppleDevice::NotifyConnect: Interfaces total != arrived, no notification ٢٢:٠٣:٣٩.٠٤١: WinAMRestore::OnInterfaceArrival: \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\USB#VID_05AC &PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:03_SCEP:0 1_BDID:08_ECID:001C245A0AB9003A_IBFL:3C#MUX1#e2ac4 80f ٢٢:٠٣:٣٩.٠٤١: WinAMRestore::AddAppleDeviceToDeviceList: \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\USB #VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM: 03_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3C#M UX1#e2ac480f ٢٢:٠٣:٣٩.٠٩٢: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:٣٩.١٩٤: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:٣٩.١٩٤: AppleDevice::EnumerateHubPorts: DoesDriverNameMatchDeviceID failed ٢٢:٠٣:٣٩.٢٤٥: WinAMRestore::AddAppleDeviceToDeviceList, device already connected, new interface ٢٢:٠٣:٣٩.٢٤٥: AppleDevice::SetDeviceID: AMD_INTERFACE_IBOOT \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576 }\USB#VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_ CPFM:03_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL :3C#MUX1#e2ac4 80f, inst: 0x762a70 ٢٢:٠٣:٣٩.٢٤٥: AppleDevice::SetNotification: CONNECT, interface type: 1, id: \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E 52236C576}\USB#VID_05AC&PID_1281#SDOM:01_CPID:8101 _CPRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C245A0AB9 003A_IBFL:3C#M UX1#e2ac480f, inst: 0x762a70 ٢٢:٠٣:٣٩.٢٤٥: WinAMRestore::ProcessDevNodesChanges: device: 0x006fb058, notify: 2, connected: 0 ٢٢:٠٣:٣٩.٢٤٥: WinAMRestore::ProcessDevNodesChanges: device: 0x00762a70, notify: 1, connected: 1 ٢٢:٠٣:٣٩.٢٤٥: AppleDevice::NotifyConnect: Device type: 2, Interfaces total: 2, arrived: 2 ٢٢:٠٣:٣٩.٢٤٥: AppleDevice::NotifyConnect: IBOOT, IBOOT \\?\USB#VID_05AC&PID_1281&MI_00#{ED82A167-D61A-4AF6-9AB6-11E52236C576}\USB# VID_05AC&PID_1281#SDOM:01_CPID:8101_CPRV:11_CPFM:0 3_SCEP:01_BDID:08_ECID:001C245A0AB9003A_IBFL:3C#MU X1#e2ac480f, ins t: 0x762a70 ٢٢:٠٣:٣٩.٢٤٥: IBOOT, DFU \\?\USB#VID_05AC&PID_1281&MI_01#{B8085869-FEB9-404B-8CB1-1E5C14FA8C54}\USB#VID_05AC&PID_1281#SDOM:01_C PID:8101_CPRV:11_CPFM:03_SCEP:01_BDID:08_ECID:001C 245A0AB9003A_IBFL:3C#MUX1#e2ac480f, inst: 0x762a70 ٢٢:٠٣:٣٩.٢٤٥: Recovery mode device connected with ECID: 0xAB9003A ٢٢:٠٣:٣٩.٢٤٥: Found known device, nudging state machine. ٢٢:٠٣:٣٩.٢٤٥: _AMRecoveryModeDeviceFinalize: 006CAFD8 ٢٢:٠٣:٣٩.٢٤٥: Recovery mode device connected ٢٢:٠٣:٣٩.٢٤٥: Transitioning device returned, continuing restore. ٢٢:٠٣:٣٩.٢٤٥: Canceling timer ٢٢:٠٣:٣٩.٢٤٥: Changing state from 'Transitioning' to 'Restoring' ٢٢:٠٣:٣٩.٢٤٥: switch mode succeeds, continue flashing ٢٢:٠٣:٣٩.٢٤٥: requested restore behavior: Erase ٢٢:٠٣:٣٩.٢٤٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٩.٢٤٥: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: searching for variant Erase (0 recovery) ٢٢:٠٣:٣٩.٢٩٦: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: No baseband chipid reported. Will match Build Identity based on ap chipid, b oardid, and secdomain only. ٢٢:٠٣:٣٩.٢٩٦: amai: AMAuthInstallBundleCopyBuildIdentityForVariant: AMAuthInstallBundleCopyBuildIdentityForVariant: Found variant: Customer E rase Install (IPSW) ٢٢:٠٣:٣٩.٢٩٦: amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device ٢٢:٠٣:٣٩.٢٩٦: no override trust object found ٢٢:٠٣:٣٩.٢٩٦: requested restore behavior: Erase ٢٢:٠٣:٣٩.٢٩٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٩.٢٩٦: requested restore behavior: Erase ٢٢:٠٣:٣٩.٢٩٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٩.٢٩٦: requested variant: Erase ٢٢:٠٣:٣٩.٢٩٦: requested restore behavior: Erase ٢٢:٠٣:٣٩.٢٩٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٣:٣٩.٢٩٦: amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device ٢٢:٠٣:٣٩.٢٩٦: personalizing: <AMAuthInstall 031530C0>{ap=(personalize=YES d54pap ecid=0x1c245a0ab9003a, chipid=0x8101, boardid=0x8, secDo m=1, isProduction=YES, EPRO=YES, isSecure=YES, ESEC=YES, img4=YES, demotionPolicy=, managedBaaCert=NO, slowRollBaaCert=N O, nonce=0xe91b173d62d1305d7a1c2fa3bdc4c8df658f33c062 36d694fe16cab2c510c233, sepNonce=0xd6b8471b4c5386c9c5590a924ffd72 ab9de6c9f1), bp=(personalize=YES), UserAuth=NO, iTunes=YES, server="http://gs.apple.com:80", locale=Zh_cn, version="libauthinstal l_Win-851.102.1.100.4", platform=win/6.2(9200) } ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreLogo to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDeviceTree to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreKernelCache to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreRamDisk to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBEC to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBSS to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting KernelCache to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٦: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftap to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfta to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftsp to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfts to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Ap,SystemVolumeCanonicalMetadata to Manifest to personalize late r ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SystemVolume to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting OS to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SEP to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DCP to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LLB to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Multitouch to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting WCHFirmwareUpdater to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RecoveryMode to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LeapHaptics to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting GFX to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AudioCodecFirmware to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow0 to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBoot to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Ap,HapticAssets to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AppleLogo to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow1 to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AVE to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreTrustCache to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryFull to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreANS to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ISP to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ANS to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AOP to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ANE to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting StaticTrustCache to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LowPowerWallet0 to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LowPowerWallet1 to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Liquid to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SIO to Manifest to personalize later ٢٢:٠٣:٣٩.٢٩٨: |
04-13-2022, 20:18 | #2 (permalink) |
Member: 2371500 Status: Offline Thanks Meter: 5,801 | ٢٢:٠٦:٣٩.٠٨٠: Sending file system via ASR 43% ٢٢:٠٦:٣٩.٠٨٠: ASR progress: Sending payload ٢٢:٠٦:٤١.٨٣٣: <Restore Device 0072AA00>: operation 13 progress 44 ٢٢:٠٦:٤١.٨٣٣: Sending file system via ASR 44% ٢٢:٠٦:٤١.٨٣٣: ASR progress: Sending payload ٢٢:٠٦:٤٤.٦٨٧: <Restore Device 0072AA00>: operation 13 progress 45 ٢٢:٠٦:٤٤.٦٨٧: Sending file system via ASR 45% ٢٢:٠٦:٤٤.٦٨٧: ASR progress: Sending payload ٢٢:٠٦:٤٧.٥٩٢: <Restore Device 0072AA00>: operation 13 progress 46 ٢٢:٠٦:٤٧.٥٩٢: Sending file system via ASR 46% ٢٢:٠٦:٤٧.٥٩٢: ASR progress: Sending payload ٢٢:٠٦:٥٠.٤٤٦: <Restore Device 0072AA00>: operation 13 progress 47 ٢٢:٠٦:٥٠.٤٤٦: Sending file system via ASR 47% ٢٢:٠٦:٥٠.٤٤٦: ASR progress: Sending payload ٢٢:٠٦:٥٣.٢٩٩: <Restore Device 0072AA00>: operation 13 progress 48 ٢٢:٠٦:٥٣.٢٩٩: Sending file system via ASR 48% ٢٢:٠٦:٥٣.٢٩٩: ASR progress: Sending payload ٢٢:٠٦:٥٦.٢٠٥: <Restore Device 0072AA00>: operation 13 progress 49 ٢٢:٠٦:٥٦.٢٠٥: Sending file system via ASR 49% ٢٢:٠٦:٥٦.٢٠٥: ASR progress: Sending payload ٢٢:٠٦:٥٩.١٦١: <Restore Device 0072AA00>: operation 13 progress 50 ٢٢:٠٦:٥٩.١٦١: Sending file system via ASR 50% ٢٢:٠٦:٥٩.١٦١: ASR progress: Sending payload ٢٢:٠٧:٠٢.٠٦٦: <Restore Device 0072AA00>: operation 13 progress 51 ٢٢:٠٧:٠٢.٠٦٦: Sending file system via ASR 51% ٢٢:٠٧:٠٢.٠٦٦: ASR progress: Sending payload ٢٢:٠٧:٠٤.٩٧١: <Restore Device 0072AA00>: operation 13 progress 52 ٢٢:٠٧:٠٤.٩٧١: Sending file system via ASR 52% ٢٢:٠٧:٠٤.٩٧١: ASR progress: Sending payload ٢٢:٠٧:٠٧.٨٩٦: <Restore Device 0072AA00>: operation 13 progress 53 ٢٢:٠٧:٠٧.٨٩٦: Sending file system via ASR 53% ٢٢:٠٧:٠٧.٨٩٦: ASR progress: Sending payload ٢٢:٠٧:١٠.٧٥٠: <Restore Device 0072AA00>: operation 13 progress 54 ٢٢:٠٧:١٠.٧٥٠: Sending file system via ASR 54% ٢٢:٠٧:١٠.٧٥٠: ASR progress: Sending payload ٢٢:٠٧:١٣.٦٠٥: <Restore Device 0072AA00>: operation 13 progress 55 ٢٢:٠٧:١٣.٦٠٥: Sending file system via ASR 55% ٢٢:٠٧:١٣.٦٠٥: ASR progress: Sending payload ٢٢:٠٧:١٦.٤٥٨: <Restore Device 0072AA00>: operation 13 progress 56 ٢٢:٠٧:١٦.٤٥٨: Sending file system via ASR 56% ٢٢:٠٧:١٦.٤٥٨: ASR progress: Sending payload ٢٢:٠٧:١٩.٣١٢: <Restore Device 0072AA00>: operation 13 progress 57 ٢٢:٠٧:١٩.٣١٢: Sending file system via ASR 57% ٢٢:٠٧:١٩.٣١٢: ASR progress: Sending payload ٢٢:٠٧:٢٢.٢١٧: <Restore Device 0072AA00>: operation 13 progress 58 ٢٢:٠٧:٢٢.٢١٧: Sending file system via ASR 58% ٢٢:٠٧:٢٢.٢١٧: ASR progress: Sending payload ٢٢:٠٧:٢٥.٠٧١: <Restore Device 0072AA00>: operation 13 progress 59 ٢٢:٠٧:٢٥.٠٧١: Sending file system via ASR 59% ٢٢:٠٧:٢٥.٠٧١: ASR progress: Sending payload ٢٢:٠٧:٢٨.٠٢٨: <Restore Device 0072AA00>: operation 13 progress 60 ٢٢:٠٧:٢٨.٠٢٨: Sending file system via ASR 60% ٢٢:٠٧:٢٨.٠٢٨: ASR progress: Sending payload ٢٢:٠٧:٣٠.٨٨٢: <Restore Device 0072AA00>: operation 13 progress 61 ٢٢:٠٧:٣٠.٨٨٢: Sending file system via ASR 61% ٢٢:٠٧:٣٠.٨٨٢: ASR progress: Sending payload ٢٢:٠٧:٣٣.٧٨٧: <Restore Device 0072AA00>: operation 13 progress 62 ٢٢:٠٧:٣٣.٧٨٧: Sending file system via ASR 62% ٢٢:٠٧:٣٣.٧٨٧: ASR progress: Sending payload ٢٢:٠٧:٣٦.٦٤١: <Restore Device 0072AA00>: operation 13 progress 63 ٢٢:٠٧:٣٦.٦٤١: Sending file system via ASR 63% ٢٢:٠٧:٣٦.٦٤١: ASR progress: Sending payload ٢٢:٠٧:٣٩.٥٤٦: <Restore Device 0072AA00>: operation 13 progress 64 ٢٢:٠٧:٣٩.٥٤٦: Sending file system via ASR 64% ٢٢:٠٧:٣٩.٥٤٦: ASR progress: Sending payload ٢٢:٠٧:٤٢.٤٥١: <Restore Device 0072AA00>: operation 13 progress 65 ٢٢:٠٧:٤٢.٤٥١: Sending file system via ASR 65% ٢٢:٠٧:٤٢.٤٥١: ASR progress: Sending payload ٢٢:٠٧:٤٥.٧٦٤: <Restore Device 0072AA00>: operation 13 progress 66 ٢٢:٠٧:٤٥.٧٦٤: Sending file system via ASR 66% ٢٢:٠٧:٤٥.٧٦٤: ASR progress: Sending payload ٢٢:٠٧:٤٨.٥٦٨: <Restore Device 0072AA00>: operation 13 progress 67 ٢٢:٠٧:٤٨.٥٦٨: Sending file system via ASR 67% ٢٢:٠٧:٤٨.٥٦٨: ASR progress: Sending payload ٢٢:٠٧:٥١.٤٢٢: <Restore Device 0072AA00>: operation 13 progress 68 ٢٢:٠٧:٥١.٤٢٢: Sending file system via ASR 68% ٢٢:٠٧:٥١.٤٢٢: ASR progress: Sending payload ٢٢:٠٧:٥٤.٣٢٧: <Restore Device 0072AA00>: operation 13 progress 69 ٢٢:٠٧:٥٤.٣٢٧: Sending file system via ASR 69% ٢٢:٠٧:٥٤.٣٢٧: ASR progress: Sending payload ٢٢:٠٧:٥٧.٢٣١: <Restore Device 0072AA00>: operation 13 progress 70 ٢٢:٠٧:٥٧.٢٣١: Sending file system via ASR 70% ٢٢:٠٧:٥٧.٢٣١: ASR progress: Sending payload ٢٢:٠٨:٠٠.١٣٦: <Restore Device 0072AA00>: operation 13 progress 71 ٢٢:٠٨:٠٠.١٣٩: Sending file system via ASR 71% ٢٢:٠٨:٠٠.١٣٩: ASR progress: Sending payload ٢٢:٠٨:٠٢.٩٩٤: <Restore Device 0072AA00>: operation 13 progress 72 ٢٢:٠٨:٠٢.٩٩٤: Sending file system via ASR 72% ٢٢:٠٨:٠٢.٩٩٤: ASR progress: Sending payload ٢٢:٠٨:٠٥.٨٤٨: <Restore Device 0072AA00>: operation 13 progress 73 ٢٢:٠٨:٠٥.٨٤٨: Sending file system via ASR 73% ٢٢:٠٨:٠٥.٨٤٨: ASR progress: Sending payload ٢٢:٠٨:٠٨.٧٠٢: <Restore Device 0072AA00>: operation 13 progress 74 ٢٢:٠٨:٠٨.٧٠٢: Sending file system via ASR 74% ٢٢:٠٨:٠٨.٧٠٢: ASR progress: Sending payload ٢٢:٠٨:١١.٦٠٧: <Restore Device 0072AA00>: operation 13 progress 75 ٢٢:٠٨:١١.٦٠٧: Sending file system via ASR 75% ٢٢:٠٨:١١.٦٠٧: ASR progress: Sending payload ٢٢:٠٨:١٤.٥١١: <Restore Device 0072AA00>: operation 13 progress 76 ٢٢:٠٨:١٤.٥١١: Sending file system via ASR 76% ٢٢:٠٨:١٤.٥١١: ASR progress: Sending payload ٢٢:٠٨:١٧.٣٦٦: <Restore Device 0072AA00>: operation 13 progress 77 ٢٢:٠٨:١٧.٣٦٦: Sending file system via ASR 77% ٢٢:٠٨:١٧.٣٦٦: ASR progress: Sending payload ٢٢:٠٨:٢٠.٢٢٠: <Restore Device 0072AA00>: operation 13 progress 78 ٢٢:٠٨:٢٠.٢٢٠: Sending file system via ASR 78% ٢٢:٠٨:٢٠.٢٢٠: ASR progress: Sending payload ٢٢:٠٨:٢٢.٩٧٢: <Restore Device 0072AA00>: operation 13 progress 79 ٢٢:٠٨:٢٢.٩٧٢: Sending file system via ASR 79% ٢٢:٠٨:٢٢.٩٧٢: ASR progress: Sending payload ٢٢:٠٨:٢٥.٧٧٥: <Restore Device 0072AA00>: operation 13 progress 80 ٢٢:٠٨:٢٥.٧٧٥: Sending file system via ASR 80% ٢٢:٠٨:٢٥.٧٧٥: ASR progress: Sending payload ٢٢:٠٨:٢٨.٦٢٩: <Restore Device 0072AA00>: operation 13 progress 81 ٢٢:٠٨:٢٨.٦٢٩: Sending file system via ASR 81% ٢٢:٠٨:٢٨.٦٢٩: ASR progress: Sending payload ٢٢:٠٨:٣١.٥٨٦: <Restore Device 0072AA00>: operation 13 progress 82 ٢٢:٠٨:٣١.٥٨٦: Sending file system via ASR 82% ٢٢:٠٨:٣١.٥٨٦: ASR progress: Sending payload ٢٢:٠٨:٣٤.٤٩١: <Restore Device 0072AA00>: operation 13 progress 83 ٢٢:٠٨:٣٤.٤٩١: Sending file system via ASR 83% ٢٢:٠٨:٣٤.٤٩١: ASR progress: Sending payload ٢٢:٠٨:٣٧.٣٩٦: <Restore Device 0072AA00>: operation 13 progress 84 ٢٢:٠٨:٣٧.٣٩٦: Sending file system via ASR 84% ٢٢:٠٨:٣٧.٣٩٦: ASR progress: Sending payload ٢٢:٠٨:٤٠.٢٥١: <Restore Device 0072AA00>: operation 13 progress 85 ٢٢:٠٨:٤٠.٢٥١: Sending file system via ASR 85% ٢٢:٠٨:٤٠.٢٥١: ASR progress: Sending payload ٢٢:٠٨:٤٣.٢٠٧: <Restore Device 0072AA00>: operation 13 progress 86 ٢٢:٠٨:٤٣.٢٠٧: Sending file system via ASR 86% ٢٢:٠٨:٤٣.٢٠٧: ASR progress: Sending payload ٢٢:٠٨:٤٦.٥٢٠: <Restore Device 0072AA00>: operation 13 progress 87 ٢٢:٠٨:٤٦.٥٢٠: Sending file system via ASR 87% ٢٢:٠٨:٤٦.٥٢٠: ASR progress: Sending payload ٢٢:٠٨:٤٩.٢٧٢: <Restore Device 0072AA00>: operation 13 progress 88 ٢٢:٠٨:٤٩.٢٧٢: Sending file system via ASR 88% ٢٢:٠٨:٤٩.٢٧٢: ASR progress: Sending payload ٢٢:٠٨:٥٢.١٧٨: <Restore Device 0072AA00>: operation 13 progress 89 ٢٢:٠٨:٥٢.١٧٨: Sending file system via ASR 89% ٢٢:٠٨:٥٢.١٧٨: ASR progress: Sending payload ٢٢:٠٨:٥٥.١٣٤: <Restore Device 0072AA00>: operation 13 progress 90 ٢٢:٠٨:٥٥.١٣٤: Sending file system via ASR 90% ٢٢:٠٨:٥٥.١٣٤: ASR progress: Sending payload ٢٢:٠٨:٥٧.٩٨٨: <Restore Device 0072AA00>: operation 13 progress 91 ٢٢:٠٨:٥٧.٩٨٨: Sending file system via ASR 91% ٢٢:٠٨:٥٧.٩٨٨: ASR progress: Sending payload ٢٢:٠٩:٠٠.٨٩٣: <Restore Device 0072AA00>: operation 13 progress 92 ٢٢:٠٩:٠٠.٨٩٣: Sending file system via ASR 92% ٢٢:٠٩:٠٠.٨٩٣: ASR progress: Sending payload ٢٢:٠٩:٠٣.٧٤٧: <Restore Device 0072AA00>: operation 13 progress 93 ٢٢:٠٩:٠٣.٧٤٧: Sending file system via ASR 93% ٢٢:٠٩:٠٣.٧٤٧: ASR progress: Sending payload ٢٢:٠٩:٠٦.٦٠٢: <Restore Device 0072AA00>: operation 13 progress 94 ٢٢:٠٩:٠٦.٦٠٢: Sending file system via ASR 94% ٢٢:٠٩:٠٦.٦٠٢: ASR progress: Sending payload ٢٢:٠٩:٠٩.٥٠٧: <Restore Device 0072AA00>: operation 13 progress 95 ٢٢:٠٩:٠٩.٥٠٧: Sending file system via ASR 95% ٢٢:٠٩:٠٩.٥٠٧: ASR progress: Sending payload ٢٢:٠٩:١٢.٤١٢: <Restore Device 0072AA00>: operation 13 progress 96 ٢٢:٠٩:١٢.٤١٢: Sending file system via ASR 96% ٢٢:٠٩:١٢.٤١٢: ASR progress: Sending payload ٢٢:٠٩:١٥.٢١٥: <Restore Device 0072AA00>: operation 13 progress 97 ٢٢:٠٩:١٥.٢١٥: Sending file system via ASR 97% ٢٢:٠٩:١٥.٢١٥: ASR progress: Sending payload ٢٢:٠٩:١٨.١٢٠: <Restore Device 0072AA00>: operation 13 progress 98 ٢٢:٠٩:١٨.١٢٠: Sending file system via ASR 98% ٢٢:٠٩:١٨.١٢٠: ASR progress: Sending payload ٢٢:٠٩:٢٤.٤٤٠: <Restore Device 0072AA00>: operation 13 progress 100 ٢٢:٠٩:٢٤.٤٤٠: Sending file system via ASR 100% ٢٢:٠٩:٢٤.٤٤٠: ASR progress: Finished ٢٢:٠٩:٢٤.٥٤٢: <Restore Device 0072AA00>: operation 14 progress 2 ٢٢:٠٩:٢٤.٥٤٢: Verifying file system via ASR 2% ٢٢:٠٩:٢٤.٦٤٤: <Restore Device 0072AA00>: operation 14 progress 4 ٢٢:٠٩:٢٤.٦٤٤: Verifying file system via ASR 4% ٢٢:٠٩:٢٤.٧٤٦: <Restore Device 0072AA00>: operation 14 progress 6 ٢٢:٠٩:٢٤.٧٤٦: Verifying file system via ASR 6% ٢٢:٠٩:٢٤.٨٤٨: <Restore Device 0072AA00>: operation 14 progress 8 ٢٢:٠٩:٢٤.٨٤٨: Verifying file system via ASR 8% ٢٢:٠٩:٢٤.٩٥٠: <Restore Device 0072AA00>: operation 14 progress 10 ٢٢:٠٩:٢٤.٩٥٠: Verifying file system via ASR 10% ٢٢:٠٩:٢٥.٠٥٢: <Restore Device 0072AA00>: operation 14 progress 12 ٢٢:٠٩:٢٥.٠٥٢: Verifying file system via ASR 12% ٢٢:٠٩:٢٥.١٥٤: <Restore Device 0072AA00>: operation 14 progress 14 ٢٢:٠٩:٢٥.١٥٤: Verifying file system via ASR 14% ٢٢:٠٩:٢٥.٢٥٦: <Restore Device 0072AA00>: operation 14 progress 16 ٢٢:٠٩:٢٥.٢٥٦: Verifying file system via ASR 16% ٢٢:٠٩:٢٥.٣٥٨: <Restore Device 0072AA00>: operation 14 progress 18 ٢٢:٠٩:٢٥.٣٥٨: Verifying file system via ASR 18% ٢٢:٠٩:٢٥.٤٦٠: <Restore Device 0072AA00>: operation 14 progress 20 ٢٢:٠٩:٢٥.٤٦٠: Verifying file system via ASR 20% ٢٢:٠٩:٢٥.٥٦٢: <Restore Device 0072AA00>: operation 14 progress 22 ٢٢:٠٩:٢٥.٥٦٢: Verifying file system via ASR 22% ٢٢:٠٩:٢٥.٦٦٤: <Restore Device 0072AA00>: operation 14 progress 24 ٢٢:٠٩:٢٥.٦٦٤: Verifying file system via ASR 24% ٢٢:٠٩:٢٥.٧٦٦: <Restore Device 0072AA00>: operation 14 progress 26 ٢٢:٠٩:٢٥.٧٦٦: Verifying file system via ASR 26% ٢٢:٠٩:٢٥.٨٦٧: <Restore Device 0072AA00>: operation 14 progress 28 ٢٢:٠٩:٢٥.٨٦٧: Verifying file system via ASR 28% ٢٢:٠٩:٢٥.٩٦٩: <Restore Device 0072AA00>: operation 14 progress 30 ٢٢:٠٩:٢٥.٩٦٩: Verifying file system via ASR 30% ٢٢:٠٩:٢٦.٠٧١: <Restore Device 0072AA00>: operation 14 progress 32 ٢٢:٠٩:٢٦.٠٧١: Verifying file system via ASR 32% ٢٢:٠٩:٢٦.١٧٣: <Restore Device 0072AA00>: operation 14 progress 34 ٢٢:٠٩:٢٦.١٧٣: Verifying file system via ASR 34% ٢٢:٠٩:٢٦.٢٧٥: <Restore Device 0072AA00>: operation 14 progress 36 ٢٢:٠٩:٢٦.٢٧٥: Verifying file system via ASR 36% ٢٢:٠٩:٢٦.٣٧٧: <Restore Device 0072AA00>: operation 14 progress 38 ٢٢:٠٩:٢٦.٣٧٧: Verifying file system via ASR 38% ٢٢:٠٩:٢٦.٤٧٩: <Restore Device 0072AA00>: operation 14 progress 40 ٢٢:٠٩:٢٦.٤٧٩: Verifying file system via ASR 40% ٢٢:٠٩:٢٦.٥٨١: <Restore Device 0072AA00>: operation 14 progress 42 ٢٢:٠٩:٢٦.٥٨١: Verifying file system via ASR 42% ٢٢:٠٩:٢٦.٦٨٣: <Restore Device 0072AA00>: operation 14 progress 44 ٢٢:٠٩:٢٦.٦٨٣: Verifying file system via ASR 44% ٢٢:٠٩:٢٦.٧٨٥: <Restore Device 0072AA00>: operation 14 progress 46 ٢٢:٠٩:٢٦.٧٨٥: Verifying file system via ASR 46% ٢٢:٠٩:٢٦.٨٨٧: <Restore Device 0072AA00>: operation 14 progress 48 ٢٢:٠٩:٢٦.٨٨٧: Verifying file system via ASR 48% ٢٢:٠٩:٢٦.٩٨٩: <Restore Device 0072AA00>: operation 14 progress 50 ٢٢:٠٩:٢٦.٩٨٩: Verifying file system via ASR 50% ٢٢:٠٩:٢٧.٠٩١: <Restore Device 0072AA00>: operation 14 progress 52 ٢٢:٠٩:٢٧.٠٩١: Verifying file system via ASR 52% ٢٢:٠٩:٢٧.١٩٣: <Restore Device 0072AA00>: operation 14 progress 54 ٢٢:٠٩:٢٧.١٩٣: Verifying file system via ASR 54% ٢٢:٠٩:٢٧.٢٩٥: <Restore Device 0072AA00>: operation 14 progress 56 ٢٢:٠٩:٢٧.٢٩٥: Verifying file system via ASR 56% ٢٢:٠٩:٢٧.٣٩٦: <Restore Device 0072AA00>: operation 14 progress 58 ٢٢:٠٩:٢٧.٣٩٦: Verifying file system via ASR 58% ٢٢:٠٩:٢٧.٥٤٨: <Restore Device 0072AA00>: operation 14 progress 60 ٢٢:٠٩:٢٧.٥٤٨: Verifying file system via ASR 60% ٢٢:٠٩:٢٧.٦٥٠: <Restore Device 0072AA00>: operation 14 progress 62 ٢٢:٠٩:٢٧.٦٥٠: Verifying file system via ASR 62% ٢٢:٠٩:٢٧.٧٥٢: <Restore Device 0072AA00>: operation 14 progress 64 ٢٢:٠٩:٢٧.٧٥٢: Verifying file system via ASR 64% ٢٢:٠٩:٢٧.٨٥٤: <Restore Device 0072AA00>: operation 14 progress 66 ٢٢:٠٩:٢٧.٨٥٤: Verifying file system via ASR 66% ٢٢:٠٩:٢٧.٩٥٦: <Restore Device 0072AA00>: operation 14 progress 68 ٢٢:٠٩:٢٧.٩٥٦: Verifying file system via ASR 68% ٢٢:٠٩:٢٨.٠٥٨: <Restore Device 0072AA00>: operation 14 progress 70 ٢٢:٠٩:٢٨.٠٥٨: Verifying file system via ASR 70% ٢٢:٠٩:٢٨.١٦٠: <Restore Device 0072AA00>: operation 14 progress 72 ٢٢:٠٩:٢٨.١٦٠: Verifying file system via ASR 72% ٢٢:٠٩:٢٨.٢٦٢: <Restore Device 0072AA00>: operation 14 progress 74 ٢٢:٠٩:٢٨.٢٦٢: Verifying file system via ASR 74% ٢٢:٠٩:٢٨.٣٦٤: <Restore Device 0072AA00>: operation 14 progress 76 ٢٢:٠٩:٢٨.٣٦٤: Verifying file system via ASR 76% ٢٢:٠٩:٢٨.٤٦٦: <Restore Device 0072AA00>: operation 14 progress 78 ٢٢:٠٩:٢٨.٤٦٦: Verifying file system via ASR 78% ٢٢:٠٩:٢٨.٥٦٨: <Restore Device 0072AA00>: operation 14 progress 80 ٢٢:٠٩:٢٨.٥٦٨: Verifying file system via ASR 80% ٢٢:٠٩:٢٨.٦٧٠: <Restore Device 0072AA00>: operation 14 progress 82 ٢٢:٠٩:٢٨.٦٧٠: Verifying file system via ASR 82% ٢٢:٠٩:٢٨.٧٧٢: <Restore Device 0072AA00>: operation 14 progress 84 ٢٢:٠٩:٢٨.٧٧٢: Verifying file system via ASR 84% ٢٢:٠٩:٢٨.٨٧٤: <Restore Device 0072AA00>: operation 14 progress 86 ٢٢:٠٩:٢٨.٨٧٤: Verifying file system via ASR 86% ٢٢:٠٩:٢٨.٩٧٦: <Restore Device 0072AA00>: operation 14 progress 88 ٢٢:٠٩:٢٨.٩٧٦: Verifying file system via ASR 88% ٢٢:٠٩:٢٩.٠٧٧: <Restore Device 0072AA00>: operation 14 progress 90 ٢٢:٠٩:٢٩.٠٧٧: Verifying file system via ASR 90% ٢٢:٠٩:٢٩.١٧٩: <Restore Device 0072AA00>: operation 14 progress 92 ٢٢:٠٩:٢٩.١٧٩: Verifying file system via ASR 92% ٢٢:٠٩:٢٩.٢٨١: <Restore Device 0072AA00>: operation 14 progress 94 ٢٢:٠٩:٢٩.٢٨١: Verifying file system via ASR 94% ٢٢:٠٩:٢٩.٣٨٣: <Restore Device 0072AA00>: operation 14 progress 96 ٢٢:٠٩:٢٩.٣٨٣: Verifying file system via ASR 96% ٢٢:٠٩:٢٩.٤٨٥: <Restore Device 0072AA00>: operation 14 progress 98 ٢٢:٠٩:٢٩.٤٨٥: Verifying file system via ASR 98% ٢٢:٠٩:٢٩.٥٨٧: <Restore Device 0072AA00>: operation 14 progress 100 ٢٢:٠٩:٢٩.٥٨٧: Verifying file system via ASR 100% ٢٢:٠٩:٣٣.١٥٥: Completed checkpoint id: 0x65B ٢٢:٠٩:٣٣.١٥٥: Started checkpoint id: 0x680 ٢٢:٠٩:٣٣.١٥٥: Completed checkpoint id: 0x680 ٢٢:٠٩:٣٣.١٥٥: Started checkpoint id: 0x675 ٢٢:٠٩:٣٣.٨٦٨: Completed checkpoint id: 0x675 ٢٢:٠٩:٣٣.٨٦٨: Started checkpoint id: 0x68C ٢٢:٠٩:٣٣.٨٦٨: Completed checkpoint id: 0x68C ٢٢:٠٩:٣٣.٨٦٨: Started checkpoint id: 0x626 ٢٢:٠٩:٣٣.٨٦٨: <Restore Device 0072AA00>: operation 29 progress -1 ٢٢:٠٩:٣٣.٨٦٨: Closing the mounting of the drive ٢٢:٠٩:٣٣.٨٦٨: <Restore Device 0072AA00>: operation 29 progress -1 ٢٢:٠٩:٣٣.٨٦٨: Closing the mounting of the drive ٢٢:٠٩:٣٣.٨٦٨: <Restore Device 0072AA00>: operation 29 progress -1 ٢٢:٠٩:٣٣.٨٦٩: Closing the mounting of the drive ٢٢:٠٩:٣٣.٨٦٩: <Restore Device 0072AA00>: operation 29 progress -1 ٢٢:٠٩:٣٣.٨٦٩: Closing the mounting of the drive ٢٢:٠٩:٣٣.٨٦٩: <Restore Device 0072AA00>: operation 29 progress -1 ٢٢:٠٩:٣٣.٨٦٩: Closing the mounting of the drive ٢٢:٠٩:٣٣.٩٧١: <Restore Device 0072AA00>: operation 29 progress -1 ٢٢:٠٩:٣٣.٩٧١: Closing the mounting of the drive ٢٢:٠٩:٣٤.٠٢٢: <Restore Device 0072AA00>: operation 15 progress -1 ٢٢:٠٩:٣٤.٠٢٢: Checking file system ٢٢:٠٩:٤٠.٣٩٣: <Restore Device 0072AA00>: operation 15 progress -1 ٢٢:٠٩:٤٠.٣٩٣: Checking file system ٢٢:٠٩:٤٠.٦٩٩: <Restore Device 0072AA00>: operation 15 progress -1 ٢٢:٠٩:٤٠.٦٩٩: Checking file system ٢٢:٠٩:٤١.٤٦٤: <Restore Device 0072AA00>: operation 16 progress -1 ٢٢:٠٩:٤١.٤٦٤: Mounting file system ٢٢:٠٩:٤١.٤٦٤: <Restore Device 0072AA00>: operation 16 progress -1 ٢٢:٠٩:٤١.٤٦٤: Mounting file system ٢٢:٠٩:٤١.٤٦٤: <Restore Device 0072AA00>: operation 16 progress -1 ٢٢:٠٩:٤١.٤٦٤: Mounting file system ٢٢:٠٩:٤١.٥١٥: <Restore Device 0072AA00>: operation 16 progress -1 ٢٢:٠٩:٤١.٥١٥: Mounting file system ٢٢:٠٩:٤١.٥٦٦: Completed checkpoint id: 0x626 ٢٢:٠٩:٤١.٥٦٦: Started checkpoint id: 0x662 ٢٢:٠٩:٤١.٥٦٦: Completed checkpoint id: 0x662 ٢٢:٠٩:٤١.٥٦٦: Completed checkpoint id: 0x677 ٢٢:٠٩:٤١.٥٦٦: Started checkpoint id: 0x67A ٢٢:٠٩:٤١.٥٦٦: Completed checkpoint id: 0x67A ٢٢:٠٩:٤١.٥٦٦: Started checkpoint id: 0x627 ٢٢:٠٩:٤١.٥٦٦: Completed checkpoint id: 0x627 ٢٢:٠٩:٤١.٥٦٦: Started checkpoint id: 0x69B ٢٢:٠٩:٤١.٧٦٩: Completed checkpoint id: 0x69B ٢٢:٠٩:٤١.٧٦٩: Started checkpoint id: 0x652 ٢٢:٠٩:٤١.٧٦٩: Completed checkpoint id: 0x652 ٢٢:٠٩:٤١.٨٢٠: Started checkpoint id: 0x635 ٢٢:٠٩:٤١.٨٢٠: Started checkpoint id: 0x1300 ٢٢:٠٩:٤١.٨٢٠: <Restore Device 0072AA00>: operation 80 progress 1 ٢٢:٠٩:٤١.٨٢٠: requested restore behavior: Erase ٢٢:٠٩:٤١.٨٢٠: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤١.٨٧١: requested restore behavior: Erase ٢٢:٠٩:٤١.٨٧١: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٢.١٢٦: <Restore Device 0072AA00>: operation 80 progress 100 ٢٢:٠٩:٤٢.٢٧٩: <Restore Device 0072AA00>: operation 80 progress 1 ٢٢:٠٩:٤٢.٢٧٩: requested restore behavior: Erase ٢٢:٠٩:٤٢.٢٧٩: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٥.٣٣٧: <Restore Device 0072AA00>: operation 18 progress 0 ٢٢:٠٩:٤٦.٠٠٠: <Restore Device 0072AA00>: operation 18 progress 100 ٢٢:٠٩:٤٦.٠٠٠: Completed checkpoint id: 0x1300 ٢٢:٠٩:٤٦.٠٠٠: <Restore Device 0072AA00>: operation 80 progress 1 ٢٢:٠٩:٤٦.٠٠٠: requested restore behavior: Erase ٢٢:٠٩:٤٦.٠٠٠: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٠٥١: <Restore Device 0072AA00>: operation 80 progress 1 ٢٢:٠٩:٤٦.٠٥١: requested restore behavior: Erase ٢٢:٠٩:٤٦.٠٥١: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٠٥١: requested restore behavior: Erase ٢٢:٠٩:٤٦.٠٥١: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٢٥٥: <Restore Device 0072AA00>: operation 80 progress 100 ٢٢:٠٩:٤٦.٢٥٥: <Restore Device 0072AA00>: operation 80 progress 1 ٢٢:٠٩:٤٦.٢٥٥: requested restore behavior: Erase ٢٢:٠٩:٤٦.٢٥٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٢٥٥: Started checkpoint id: 0x130A ٢٢:٠٩:٤٦.٢٥٥: <Restore Device 0072AA00>: operation 36 progress 1 ٢٢:٠٩:٤٦.٢٥٥: Sending FUD sub-firmware ٢٢:٠٩:٤٦.٢٥٥: requested restore behavior: Erase ٢٢:٠٩:٤٦.٢٥٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٣٥٧: requested restore behavior: Erase ٢٢:٠٩:٤٦.٣٥٧: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٤٥٩: <Restore Device 0072AA00>: operation 36 progress 5 ٢٢:٠٩:٤٦.٤٥٩: Sending FUD sub-firmware ٢٢:٠٩:٤٦.٤٥٩: requested restore behavior: Erase ٢٢:٠٩:٤٦.٤٥٩: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٧١٣: <Restore Device 0072AA00>: operation 36 progress 11 ٢٢:٠٩:٤٦.٧١٣: Sending FUD sub-firmware ٢٢:٠٩:٤٦.٧١٣: requested restore behavior: Erase ٢٢:٠٩:٤٦.٧١٣: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٨١٥: <Restore Device 0072AA00>: operation 36 progress 17 ٢٢:٠٩:٤٦.٨١٥: Sending FUD sub-firmware ٢٢:٠٩:٤٦.٨١٥: requested restore behavior: Erase ٢٢:٠٩:٤٦.٨١٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٦.٩١٧: <Restore Device 0072AA00>: operation 36 progress 23 ٢٢:٠٩:٤٦.٩١٧: Sending FUD sub-firmware ٢٢:٠٩:٤٦.٩١٧: requested restore behavior: Erase ٢٢:٠٩:٤٦.٩١٧: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٧.٢٧٤: <Restore Device 0072AA00>: operation 36 progress 29 ٢٢:٠٩:٤٧.٢٧٤: Sending FUD sub-firmware ٢٢:٠٩:٤٧.٢٧٤: requested restore behavior: Erase ٢٢:٠٩:٤٧.٢٧٤: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٧.٣٧٦: <Restore Device 0072AA00>: operation 36 progress 35 ٢٢:٠٩:٤٧.٣٧٦: Sending FUD sub-firmware ٢٢:٠٩:٤٧.٣٧٦: requested restore behavior: Erase ٢٢:٠٩:٤٧.٣٧٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٨.٧٠١: <Restore Device 0072AA00>: operation 36 progress 41 ٢٢:٠٩:٤٨.٧٠١: Sending FUD sub-firmware ٢٢:٠٩:٤٨.٧٠١: requested restore behavior: Erase ٢٢:٠٩:٤٨.٧٠١: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٩.٤١٥: <Restore Device 0072AA00>: operation 36 progress 47 ٢٢:٠٩:٤٩.٤١٥: Sending FUD sub-firmware ٢٢:٠٩:٤٩.٤١٥: requested restore behavior: Erase ٢٢:٠٩:٤٩.٤١٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٩.٥١٧: <Restore Device 0072AA00>: operation 36 progress 52 ٢٢:٠٩:٤٩.٥١٧: Sending FUD sub-firmware ٢٢:٠٩:٤٩.٥١٧: requested restore behavior: Erase ٢٢:٠٩:٤٩.٥١٧: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٩.٦١٨: <Restore Device 0072AA00>: operation 36 progress 58 ٢٢:٠٩:٤٩.٦١٨: Sending FUD sub-firmware ٢٢:٠٩:٤٩.٦١٨: requested restore behavior: Erase ٢٢:٠٩:٤٩.٦١٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٩.٨٢٢: <Restore Device 0072AA00>: operation 36 progress 64 ٢٢:٠٩:٤٩.٨٢٢: Sending FUD sub-firmware ٢٢:٠٩:٤٩.٨٢٢: requested restore behavior: Erase ٢٢:٠٩:٤٩.٨٢٢: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٤٩.٩٧٥: <Restore Device 0072AA00>: operation 36 progress 70 ٢٢:٠٩:٤٩.٩٧٥: Sending FUD sub-firmware ٢٢:٠٩:٤٩.٩٧٥: requested restore behavior: Erase ٢٢:٠٩:٤٩.٩٧٥: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٠.١٢٨: <Restore Device 0072AA00>: operation 36 progress 76 ٢٢:٠٩:٥٠.١٢٨: Sending FUD sub-firmware ٢٢:٠٩:٥٠.١٢٨: requested restore behavior: Erase ٢٢:٠٩:٥٠.١٢٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٠.٢٣٠: <Restore Device 0072AA00>: operation 36 progress 82 ٢٢:٠٩:٥٠.٢٣٠: Sending FUD sub-firmware ٢٢:٠٩:٥٠.٢٣٠: requested restore behavior: Erase ٢٢:٠٩:٥٠.٢٣٠: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٠.٥٣٦: <Restore Device 0072AA00>: operation 36 progress 88 ٢٢:٠٩:٥٠.٥٣٦: Sending FUD sub-firmware ٢٢:٠٩:٥٠.٥٣٦: requested restore behavior: Erase ٢٢:٠٩:٥٠.٥٣٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٢.٣٧١: <Restore Device 0072AA00>: operation 36 progress 94 ٢٢:٠٩:٥٢.٣٧١: Sending FUD sub-firmware ٢٢:٠٩:٥٢.٣٧١: requested restore behavior: Erase ٢٢:٠٩:٥٢.٣٧١: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٢.٥٧٥: <Restore Device 0072AA00>: operation 36 progress 100 ٢٢:٠٩:٥٢.٥٧٥: Sending FUD sub-firmware ٢٢:٠٩:٥٢.٥٧٥: Completed checkpoint id: 0x130A ٢٢:٠٩:٥٢.٥٧٥: <Restore Device 0072AA00>: operation 47 progress -1 ٢٢:٠٩:٥٢.٥٧٥: Started checkpoint id: 0x1302 ٢٢:٠٩:٥٢.٥٧٥: <Restore Device 0072AA00>: operation 47 progress -1 ٢٢:٠٩:٥٢.٥٧٥: Completed checkpoint id: 0x1302 ٢٢:٠٩:٥٢.٥٧٥: Started checkpoint id: 0x1304 ٢٢:٠٩:٥٢.٥٧٥: <Restore Device 0072AA00>: operation 55 progress 0 ٢٢:٠٩:٥٩.٠٤٨: Completed checkpoint id: 0x1304 ٢٢:٠٩:٥٩.٠٤٨: <Restore Device 0072AA00>: operation 36 progress 1 ٢٢:٠٩:٥٩.٠٤٨: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٠٤٨: requested restore behavior: Erase ٢٢:٠٩:٥٩.٠٤٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٩.٢٠٠: <Restore Device 0072AA00>: operation 36 progress 5 ٢٢:٠٩:٥٩.٢٠٠: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٢٠٠: <Restore Device 0072AA00>: operation 36 progress 11 ٢٢:٠٩:٥٩.٢٠٠: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٢٠٠: requested restore behavior: Erase ٢٢:٠٩:٥٩.٢٠٠: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٩.٣٠٢: <Restore Device 0072AA00>: operation 36 progress 17 ٢٢:٠٩:٥٩.٣٠٢: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٠٢: <Restore Device 0072AA00>: operation 36 progress 23 ٢٢:٠٩:٥٩.٣٠٢: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٠٢: <Restore Device 0072AA00>: operation 36 progress 29 ٢٢:٠٩:٥٩.٣٠٢: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٠٢: <Restore Device 0072AA00>: operation 36 progress 35 ٢٢:٠٩:٥٩.٣٠٢: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٥٣: <Restore Device 0072AA00>: operation 36 progress 41 ٢٢:٠٩:٥٩.٣٥٣: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٥٣: <Restore Device 0072AA00>: operation 36 progress 47 ٢٢:٠٩:٥٩.٣٥٣: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٥٣: <Restore Device 0072AA00>: operation 36 progress 52 ٢٢:٠٩:٥٩.٣٥٣: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٥٣: <Restore Device 0072AA00>: operation 36 progress 58 ٢٢:٠٩:٥٩.٣٥٣: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٥٣: <Restore Device 0072AA00>: operation 36 progress 64 ٢٢:٠٩:٥٩.٣٥٣: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٣٥٣: requested restore behavior: Erase ٢٢:٠٩:٥٩.٣٥٣: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٩.٥٠٦: <Restore Device 0072AA00>: operation 36 progress 70 ٢٢:٠٩:٥٩.٥٠٦: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٥٠٦: <Restore Device 0072AA00>: operation 36 progress 76 ٢٢:٠٩:٥٩.٥٠٦: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٥٠٦: requested restore behavior: Erase ٢٢:٠٩:٥٩.٥٠٦: Flash mode: Don't Retain User's Data While Flashing ٢٢:٠٩:٥٩.٦٠٨: <Restore Device 0072AA00>: operation 36 progress 82 ٢٢:٠٩:٥٩.٦٠٨: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٦٠٨: <Restore Device 0072AA00>: operation 36 progress 88 ٢٢:٠٩:٥٩.٦٠٨: Sending FUD sub-firmware ٢٢:٠٩:٥٩.٦٠٨: requested restore behavior: Erase ٢٢:٠٩:٥٩.٦٠٨: Flash mode: Don't Retain User's Data While Flashing ٢٢:١٠:٠١.٤٩٤: <Restore Device 0072AA00>: operation 36 progress 94 ٢٢:١٠:٠١.٤٩٤: Sending FUD sub-firmware ٢٢:١٠:٠١.٤٩٤: <Restore Device 0072AA00>: operation 36 progress 100 ٢٢:١٠:٠١.٤٩٤: Sending FUD sub-firmware ٢٢:١٠:٠١.٦٤٧: Started checkpoint id: 0x1306 ٢٢:١٠:٠١.٦٤٧: Completed checkpoint id: 0x1306 ٢٢:١٠:٠١.٦٤٧: Started checkpoint id: 0x1307 ٢٢:١٠:٠١.٦٤٧: Completed checkpoint id: 0x1307 ٢٢:١٠:١٥.٠٥٢: Started checkpoint id: 0x1303 ٢٢:١٠:١٥.٠٥٢: <Restore Device 0072AA00>: operation 19 progress -1 ٢٢:١٠:١٥.٠٥٢: Updating baseband ٢٢:١٠:١٥.٠٥٢: requested restore behavior: Erase ٢٢:١٠:١٥.٠٥٢: Flash mode: Don't Retain User's Data While Flashing ٢٢:١٠:١٥.١٠٢: amai: AMAuthInstallBasebandSetParametersWithUpdaterOutpu t: baseband updater output: <CFBasicHash 036B36E8 [6419506C]>{type = immutable dict, count = 8, ٢٢:١٠:١٥.١٠٢: entries => ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: ٢٢:١٠:١٥.١٠٢: } ٢٢:١٠:١٥.١٠٢: amai: AMAuthInstallBasebandSetParametersWithUpdaterOutpu t: manifest dict not found ٢٢:١٠:١٥.١٠٢: amai: _AMAuthInstallBasebandCheckForParameterChange: bbParameters is now non-NULL ٢٢:١٠:١٥.١٠٢: requested restore behavior: Erase ٢٢:١٠:١٥.١٠٢: Flash mode: Don't Retain User's Data While Flashing ٢٢:١٠:١٥.١٠٢: requested variant: Erase ٢٢:١٠:١٥.١٠٢: requested restore behavior: Erase ٢٢:١٠:١٥.١٠٢: Flash mode: Don't Retain User's Data While Flashing ٢٢:١٠:١٥.١٠٢: amai: AMAuthInstallBundleFDRSupported: FDR is supported for this device ٢٢:١٠:١٥.١٠٢: personalizing: <AMAuthInstall 03152880>{ap=(personalize=YES d54pap ecid=0x1c245a0ab9003a, chipid=0x8101, boardid=0x8, secDom= 1, isProduction=YES, EPRO=YES, isSecure=YES, ESEC=YES, img4=YES, demotionPolicy=, managedBaaCert=NO, slowRollBaaCert=NO), bp=(personalize=YES, snum=0x2ec794ad, chipid=0xe50e1, certid=0xb87d0555), UserAuth=NO, iTunes=YES, server="http://gs.apple.co m:80", locale=Zh_cn, version="libauthinstall_Win-851.102.1.100.4", platform=win/6.2(9200) } ٢٢:١٠:١٥.١٠٢: amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes ٢٢:١٠:١٥.١٠٢: amai: _AMAuthInstallBundleShouldPersonalizeOS: Personalize OS = Yes ٢٢:١٠:١٥.١٠٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreLogo to Manifest to personalize later ٢٢:١٠:١٥.١٠٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDeviceTree to Manifest to personalize later ٢٢:١٠:١٥.١٠٢: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreKernelCache to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreRamDisk to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBEC to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBSS to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting KernelCache to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftap to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfta to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ftsp to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting rfts to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Ap,SystemVolumeCanonicalMetadata to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SystemVolume to Manifest to personalize later ٢٢:١٠:١٥.١٠٣: amai: AMAuthInstallBasebandCreateMeasurements: Using set ChipID 0x000E50E1 to measure ٢٢:١٠:١٥.١٠٣: Requesting baseband SHSH via network ٢٢:١٠:١٦.٨٨٧: amai: BbfwReaderFindAndCopyFileData: failed to find bbfw item "vinyl/update/main/signedprofile.der": File error ٢٢:١٠:١٦.٨٨٧: amai: BbfwReaderFindAndCopyFileData: failed to find bbfw item "vinyl/update/gold/signedprofile.der": File error ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BasebandFirmware to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting OS to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SEP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DCP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LLB to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Multitouch to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting WCHFirmwareUpdater to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RecoveryMode to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LeapHaptics to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting GFX to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AudioCodecFirmware to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow0 to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBoot to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Ap,HapticAssets to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AppleLogo to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryLow1 to Manifest to personalize later ٢٢:١٠:١٦.٨٨٧: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AVE to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreTrustCache to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryFull to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreANS to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ISP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ANS to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting AOP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting ANE to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting StaticTrustCache to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LowPowerWallet0 to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting LowPowerWallet1 to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting Liquid to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting SIO to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting PMP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting DeviceTree to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting iBootData to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryPlugin to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging0 to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting BatteryCharging1 to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreSEP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleCopyOverrideBuildIdentity: Inserting RestoreDCP to Manifest to personalize later ٢٢:١٠:١٦.٨٨٨: amai: _AMAuthInstallBundleSetBasebandKeyHashes: setting (from build manifest): BbProvisioningManifestKeyHash = <CFData 031A01 08 [6419506C]>{length = 48, capacity = 48, bytes = 0x238c5118db979840969fb4dba3ab2db3 ... 1629e2a30e1df392} ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleSetBasebandKeyHashes: setting (from build manifest): BbActivationManifestKeyHash = <CFData 031A0158 [6419506C]>{length = 48, capacity = 48, bytes = 0x1b41607650ebf11c6b39f41cb267dc64 ... 055803e1ef81c870} ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleSetBasebandKeyHashes: setting (from build manifest): BbFDRSecurityKeyHash = <CFData 0319FFC8 [64195 06C]>{length = 0, capacity = 0, bytes = 0x} ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleCreateServerRequestDictionary: ticketPath amai/apimg4ticket.der , withApTicket is False, (!True && ( False || False)) ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreLogo" ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreDeviceTree" ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreKernelCache" ٢٢:١٠:١٦.٨٨٩: amai: _AMAuthInstallBundleCreateServerRequestDictionary: not personalizing "RestoreRamDisk"  |
