09-04-2022, 20:46 | #1 (permalink) |
Freak Poster Join Date: Dec 2013 Location: nador maroc
Member: 2093958 Status: Offline Thanks Meter: 81 | apple iphone 13 disassembly motherboard schematic diagram service ways ic solution up device part Other solutions contact softrif photo HTB1b5FfaIrrK1RjSspaq6AREXXa4.jpg HTB1CephaPzuK1RjSsppq6xz0XXaL.jpg iPhone 13 AP PCB Teardown.pdf iphone 13 battery conn.jpg iphone 13 display touch conn.jpg iphone 13 dock conn.jpg iphone 13 front camera conn.jpg iphone 13 infra camera conn.jpg iphone 13 power key conn battery conn.jpg iphone 13 power point trigger.jpg iPhone 13 RF PCB Teardown.pdf iphone 13 sidekey wireless charging coil conn.jpg iphone 13 sim conn.jpg iphone 13 strobe conn.jpg iphone 13 tele super wide camera conn.jpg iphone 13 up antenna conn .jpg iphone 13 up antenna conn.jpg iphone 13 wide camera conn.jpg iphone 13 wifi nfc ant conn.jpg Other solutions contact softrif\iPhone 13 Power Botton On.Off Points.jpg device part\Loud Speaker for iPhone 13 6.1 Ori.jpg device part\2E4B Charging IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 .jpg device part\2E4B Charging IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7.jpg device part\338S00537 Small Audio IC for iPhone 1212 Mini12 Pro13 6.113 Mini 5.413 Pro 6.1 .jpg device part\338S00537 Small Audio IC for iPhone 1212 Mini12 Pro13 6.113 Mini 5.413 Pro 6.1.jpg device part\338S00739 Main Audio IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max .jpg device part\338S00739 Main Audio IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max.jpg device part\338S00762 Camera IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 .jpg device part\338S00762 Camera IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7.jpg device part\343S00511 Big Power IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 Ori .jpg device part\343S00511 Big Power IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 Ori.jpg device part\600V NFC IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 .jpg device part\600V NFC IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7.jpg device part\1616A0 IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 .jpg device part\1616A0 IC for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7.jpg device part\Back Camera for iPhone 13 6.1 Ori R.jpg device part\Back Camera FPC Connector Port Onboard for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 Ori 22Pin.jpg device part\Back Camera Testing Cable for iPhone 13 Mini 5.413 6.1 HQ 2pcs in one set.jpg device part\Battery FPC Connector Port Onboard for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7.jpg device part\Battery Testing Flex Cable for iPhone 13 6.113 Mini 5.4 HQ.jpg device part\Big Power Amplifier IC for iPhone 13 6.1 Ori.jpg device part\Bluetooth Antenna Flex Cable for iPhone 13 6.1 Ori R.jpg device part\Bobina del Inductor for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 .jpg device part\Bobina del Inductor for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7.jpg device part\Charging Port Flex Cable for iPhone 13 6.1 White HQ .jpg device part\Charging Port Flex Cable for iPhone 13 6.1 White HQ.jpg device part\Charging Port for iPhone 13 6.113 Mini 5.413 Pro 6.113 Pro Max 6.7 Blue.jpg device part\Dot Matrix FPC Connector Port Onboard for iPhone 13 6.1 Ori 24Pin.jpg device part\Ear Speaker Flex Cable for iPhone 13 6.1 Ori.jpg device part\Ear Speaker for iPhone 13 6.1 Ori.jpg device part\Ear Speaker FPC Connector Port Onboard for iPhone 13 6.113 Pro 6.113 Pro Max 6.7 Ori 16Pin.jpg device part\Flash Light Sensor Flex Cable for iPhone 13 6.1 Ori.jpg device part\Front Camera FPC Connector Port Onboard for iPhone 13 6.113 Pro 6.113 Pro Max 6.7 Ori 16Pin.jpg device part\Front Camera with IR Camera for iPhone 13 6.1 Ori R .jpg device part\Front Camera with IR Camera for iPhone 13 6.1 Ori R.jpg device part\GPS Antenna Flex Cable for iPhone 13 6.1 USA Version Ori.jpg device part\IR Camera for iPhone 13 6.1 Ori .jpg device part\IR Camera for iPhone 13 6.1 Ori.jpg device part\LCD FPC Connector Port Onboard for iPhone 13 6.113 Mini 5.4 Ori 52Pin.jpg device part\LCD Testing Flex Cable for iPhone 13 6.113 Mini 5.4 HQ.jpg https://www.youtube.com/watch?v=7PF8...hannel=softrif |
