EME Mobile Tool (EMT) Official Support Section by EmeGSM Team |
04-27-2021, 08:47 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: việt nam
Member: 1327392 Status: Offline Thanks Meter: 409 | how to flash Note 9 Pro ( joyeuse ) [ANSWERED] how to flash Note 9 Pro ( joyeuse ) [Read/Reset/Reset&Backup/Restore Screenlocks] 1.Reading the help, Enter Qualcomm EDL/9008 mode, Connect USB Cable (install drivers) 2.Go to Screenlock Tab, Click buttons TIPS: These function working for android unencrypted devices. TIPS: Read screenlocks function not working for Android 6.0 and above version [Disable Screenlock/Enable Screenlock] 1.Reading the help, Enter Qualcomm EDL/9008 mode, Connect USB Cable (install drivers) 2.Go to Screenlock Tab, Click buttons TIPS: Support reset screenlock without data loss for android encrypted and unencrypted devices [Factory Reset (Sideload)/Lookup Model (Sideload)] 1.Reading the help, Enter Recovery mode, Connect USB Cable (install drivers) 2.Click function buttons TIPS: The Sideload function requires the screen to be on the "Connect USB Cable" interface (please select "Connect Mobile Assistant") TIPS: The Sideload function unsupport Mi-Recovery 1.0/2.0 low version and third-party recovery [Read Userdata] 1.Reading the help, Enter Qualcomm EDL/9008 mode, Connect USB Cable (install drivers) 2.Go to Userdata Tab, Click "Read Userdata" button TIPS: These function working for android unencrypted devices. [Read Partition/Write Partition/Erase Partition] 1.Reading the help, Enter Qualcomm EDL/9008 mode, Connect USB Cable (install drivers) 2.Go to Partition Tab, Click Read GPT 3.Go to Partition Tab, Click buttons TIPS: If the partition is encrypted, the mirror files also encrypted Operation: Write Partition Selected Model: JOYEUSE Platform: QUALCOMM Waiting to Emergency mode device connect: Failed Operation: Finished Operation: Write Partition Selected Model: JOYEUSE Platform: QUALCOMM Waiting to Emergency mode device connect: OK Port: COM117 Connect to device ... OK Sending loader ... OK Connecting to Sahara ... OK Reading configuration ... Failed, Authentication needed (or Flash IC damaged)! Operation: Finished Operation: Write Partition Selected Model: JOYEUSE Platform: QUALCOMM Waiting to Emergency mode device connect: OK Port: COM117 Connect to device ... OK Sending loader ... OK Connecting to Sahara ... OK Reading configuration ... Failed, Authentication needed (or Flash IC damaged)! Operation: Finished Operation: Write Partition Selected Model: JOYEUSE Platform: QUALCOMM Waiting to Emergency mode device connect: OK Port: COM117 Connect to device ... OK Sending loader ... OK Connecting to Sahara ... OK Reading configuration ... Failed, Authentication needed (or Flash IC damaged)! Operation: Finished thank |
04-27-2021, 08:51 | #2 (permalink) |
Member: 1327392 Status: Offline Thanks Meter: 409 | (bootloader) product:joyeuse (bootloader) is-userspace:no (bootloader) max-download-size:805306368 (bootloader) kernel:uefi all: finished. total time: 0.016s ... (bootloader) Verity mode: true (bootloader) Device unlocked: false (bootloader) Device critical unlocked: false (bootloader) Charger screen enabled: true OKAY [ 0.000s] finished. total time: 0.000s |
04-27-2021, 16:17 | #3 (permalink) |
Product Manager Join Date: Apr 2005 Location: China
Member: 133050 Status: Online Thanks Meter: 6,491 | Hi, Get Phone imei or sn (12 digit, beside qr-code on the main board) send to my skype, we will confirm phone find device status is off and then enable auth service for you. 1. auth service 2. flash firmware Best Regards EmeGSM Team |
The Following 2 Users Say Thank You to EmeGSM-Wei For This Useful Post: |
