EME Mobile Tool (EMT) Official Support Section by EmeGSM Team |
12-14-2022, 23:05 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2192372 Status: Offline Thanks Meter: 0 | Redmi Note 9 Pro Joyeuse enable auth Thank you!! Operation: Write Partition Selected Model: JOYEUSE Platform: QUALCOMM ----------------------- EDL/9008: View testpoint, Short-connect testpoint and connect USB Cable EDL/9008: Power off, Connect EDL cable and press power button for 10s, Connect USB Cable EDL/9008: Enter Adb or Fastboot mode, click the "Boot into EDL" button ----------------------- Waiting for EDL connect: OK Port: COM10 Connect to device ... OK Sending loader ... OK Connecting to Sahara ... OK Reading configuration ... Failed, Need enable authentication service first (or Flash IC damaged), contact us if you need authentication service! Operation: Finished Board: QUALCOMM Platform: SM7125 Factory Code: Joyeuse Label Model: M2003J6B2G Last edited by roxu31; 12-14-2022 at 23:06. Reason: Wrong model. |
12-30-2022, 04:54 | #2 (permalink) | |
Junior Member Join Date: Aug 2018 Location: Chile Age: 39
Member: 2859078 Status: Offline Thanks Meter: 2 | Quote:
en estos momentos el servidor está en mantención, se puede solicitar servicio de auth cuando el servidor vuelva a trabajar, saludos. | |
