A02F SM-A022F Reset (Samsung KG) MTN LOCK [RPMB] Done! by Pandora's Box A02F SM-A022F Reset (Samsung KG) MTN LOCK [RPMB] Done! by Pandora's Box How Do The Do it !! Selected model: Samsung SM-A022F (Galaxy A02) Operation: Remove KG Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM26 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7926B3AC, 0x3F27662D, 0x7EEBFB23, 0x218EF2B6 Get Chip ID... [MT6739] Get SOC ID... [A6DFDD96F50399C59525E8695524054336550057DF0BEB1DC6 8B171DAE410874] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010051583633414200B7D006943885 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x15010051583633414200B7D006943885 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x0000020000 (128,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read Write Counter[WC][MAX=0xFFFFFFFF]... 4456 OK Backup RPMB... OK Searching RPMB key... found! [3] WC not incremented if data of page in rpmb same as in file Format RPMB 0x100 bytes (0x1 pages)... OK Format RPMB 0x100 bytes (0x1 pages)... OK Read Write Counter[WC][MAX=0xFFFFFFFF]... 4456 OK Reset (Samsung KG) RPMB done! |
