01-28-2023, 14:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: under pross
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | Advanced Bypass Security... error [Answered] Selected model: Xiaomi Redmi Note 10 5G (China) (Camellia) Operation: Read Flash Info Software version: 4.4 Work ID: 270275 Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM0 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Advanced Bypass Security... error |
The Following User Says Thank You to Pastime_GSM For This Useful Post: |
02-11-2023, 15:12 | #7 (permalink) |
Member: 1798174 Status: Offline Sonork: 100.114149 Thanks Meter: 1,048 | problem solved after change model to A15s Selected model: OPPO CPH2179 (Oppo A15s) Operation: Repair Software version: 4.6 Work ID: 449411 Connect phone in BROM Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Advanced Bypass Security... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM3 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0A581CFE, 0xABA97D0F, 0x173ACDAB, 0x0D508511 Get Chip ID... [MT6765] Get SOC ID... [4B03E6F90AD96717B793EB48379FB2394F3162E3E698E65B42 7D756C3910E4F2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445836384D4209BE3ECCA57897 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_CNAME: DX68MB EMMC_ID : 0x150100445836384D4209BE3ECCA57897 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232,00Kb) EXT_RAM : 0x00C0000000 (3,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK Read product info... OK Product Board : oppo6765 Board Platform : MT6765 Build ID : QP1A.190711.020 Build Date : Thu Dec 29 18:39:57 CST 2022 Display ID : QP1A.190711.020 release-keys Security Patch : 2023-01-05 Version SDK : 29 Version Release : 10 Version Codename : REL Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 862xxxxxxxxxxxxx IMEI 2: 862xxxxxxxxxxxxx Write IMEI [NVDATA]... OK Checking patch type... [2] Load partiton for patching... OK Patching CERT... OK Save patched partiton... OK Read partitions info from phone... OK Checking A/B state... OK Read security partition from phone... OK Decrypting security data... OK Encrypt security data... OK Write security partition to phone... OK Checking additional lock... [DISABLED] Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. |
