12-20-2021, 22:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Georgetown
Member: 455304 Status: Offline Thanks Meter: 417 | tcl d507dl fail to unlock [Solved] Operation: Unlock network Software version: 2.8 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM104 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM104 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x95764FC2, 0x3AD8EEA3, 0x78679843, 0x14C604D9 Get Chip ID... [MT6761] Get SOC ID... [0C1D2936D248C5E19943EDF00285D7C85E2B3F7D101095D351 26D0F1F021A488] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x15010047583642414209044B06DF18EF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x15010047583642414209044B06DF18EF EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : TCL Product Manufacturer : TCL Product Model : A507DL Product Name : A507DL Product Device : Seoul_TF Product Board : Seoul_TF Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Tue Mar 9 17:34:12 CST 2021 Display ID : QP1A.190711.020 release-keys Security Patch : 2021-03-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : vD7X-0 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(1) |
12-21-2021, 01:53 | #3 (permalink) | |
Member: 455304 Status: Offline Thanks Meter: 417 | Quote:
01-14-2022, 19:55 | #6 (permalink) |
Member: 455304 Status: Offline Thanks Meter: 417 | Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM131 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x8CFEA687, 0xA63146D8, 0x6FD6187F, 0x280689C5 Get Chip ID... [MT6761] Get SOC ID... [E755B3B0A1D9AB6CBEB67EE14291E7229BBAA2BEEAB4FFD6E3 019ECDF0EF12D2] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x1501004758364241420971649607C7A9 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x1501004758364241420971649607C7A9 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : TCL Product Manufacturer : TCL Product Model : A507DL Product Name : A507DL Product Device : Seoul_TF Product Board : Seoul_TF Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Thu May 6 18:39:01 CST 2021 Display ID : QP1A.190711.020 release-keys Security Patch : 2021-05-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : vD83-0 Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Write lock info... OK Write security partition to phone... OK Network Unlock done! work 100% |
