05-31-2022, 17:40 | #1 (permalink) |
Freak Poster Join Date: Mar 2011 Location: I`m From Cancun Age: 34
Member: 1538766 Status: Online Sonork: 1626907 Thanks Meter: 18 | cph2205 imei repair failed [Solved] Selected model: OPPO CPH2205 (Oppo Reno5 Lite) Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0725 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6779] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xC8D49C58, 0x6C9B75E6, 0x91987B88, 0x5D509FF9 Get Chip ID... [MT6779] Get SOC ID... [04281E97D2CD9FF69AB19154E4EDDCD49D8F905056D526EDA1 0854E3D5FDDCFC] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [10] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AECMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AECMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6779 Board Platform : MT6779 Build ID : RP1A.200720.011 Build Date : Sat Sep 18 23:07:36 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-09-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1631976954541 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: 863351056335584 IMEI 2: 863351056335584 Write IMEI [NVDATA]... OK Load partiton for patching... patch impossible |
06-01-2022, 17:05 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: in the web Age: 41
Member: 630907 Status: Offline Thanks Meter: 127 | Quote:
****************************/file/e8i1s...r.txt.rar/file | |
The Following 2 Users Say Thank You to erocelmaster For This Useful Post: |
06-03-2022, 18:40 | #8 (permalink) |
Member: 1538766 Status: Online Sonork: 1626907 Thanks Meter: 18 | Hi, try with this firmware, worck for me https://forum.gsmhosting.com/vbb/****************************/file/e8i1s...r.txt.rar/file thanks work for me too, but only one tip is necessary flashing this file in upgrade mode or phone only vibrate after flashing |
The Following 3 Users Say Thank You to josepuc For This Useful Post: |
