06-15-2021, 13:42 | #166 (permalink) |
Insane Poster Join Date: Dec 2015 Location: 5starxmobile
Member: 2496311 Status: Offline Sonork: 100.1670672 Thanks Meter: 26 | vivo y90 vivo y90 repair done but not change backup with pandora https://drive.google.com/u/0/uc?id=1...xport=download |
06-15-2021, 17:27 | #168 (permalink) |
Freak Poster Join Date: Apr 2012 Location: KU.mahabad
Member: 1744310 Status: Offline Sonork: 100.1617232 Thanks Meter: 43 | all products from z3x team always is the best ,but this box only support mtk cpu? or in futur add other cpu like qualcomm? many many boxes already supported some or more operation for mtk pandora box need support more cpu for different, like king jtag easyjtag. Sent from my Redmi K30 Pro using Tapatalk |
06-17-2021, 10:06 | #169 (permalink) |
Freak Poster Join Date: May 2004 Location: Slovakia Age: 45
Member: 66497 Status: Offline Thanks Meter: 81 | Pleas ADD motorola XT2016-1 series Selected model: Mediatek Mediatek Operation: Read Flash Info Software version: 1.14 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x26774D08, 0xF3EDD8DC, 0xDFC807D4, 0x13B027EA Get Chip ID... [MT6771] Get SOC ID... [27445B8177218F2A9DE8EBA06F84D2DE3A76E81A855D5F768F 09596ACEDC74A1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [20] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E53304A394B381011CA6DEB76D9 Load EMI config from database [DB VER: 124 DB DATE: 06-13-2021] OK [0] Trying EMI [] Init EXT RAM... error(STATUS_EMI_CONTAINER_FILE_NOT_FOUND) |
06-20-2021, 19:36 | #171 (permalink) |
Major Poster Join Date: Jan 2019
Member: 2887504 Status: Offline Thanks Meter: 7 | add blue view 1 model B100DL Selected model: BLU UNKNOWN Operation: Unlock network Software version: 1.14 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM178 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xCCFA2E7A, 0xF09740AE, 0xFFEEB287, 0xA53BE751 Get Chip ID... [MT6739] Get SOC ID... [C40D86AD3D1A1AFA8F080F6DCA2BA0391F255637E68E707D52 DD4FDD7D29E3F6] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514536334D420366A468D05745 Load EMI config from database [DB VER: 124 DB DATE: 06-13-2021] OK [1] Trying EMI [A04CDABF] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514536334D420366A468D05745 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x03A3E00000 (14.56Gb) RAM INFO: INT_SRAM: 0x0000020000 (128.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read lock info... error(3) |
The Following User Says Thank You to nued94 For This Useful Post: |
06-21-2021, 20:39 | #172 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
then we will add to supported. | |
The Following User Says Thank You to blang For This Useful Post: |
06-23-2021, 21:44 | #173 (permalink) |
Crazy Poster Join Date: Feb 2014
Member: 2121390 Status: Offline Thanks Meter: 12 | please add huawey y9A ,FRL L23 Android 10 Interface EMUI 10.1 Processor MediaTek Helio G80 Clock frequency: 2.00 GHz Number of cores: 8 GPU: ARM Mali-G52 MC2 Selected model: Huawei UNKNOWN Operation: Read Flash Info Software version: 1.15 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM111 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x19A91F90, 0xC4300B02, 0x85B52575, 0x85584424 Get Chip ID... [MT6768] Get SOC ID... [18C7DB15E8BCF1015355D139668BC3731D8365A714315443D9 9889FCE4ED61A1] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x1501004455544234320248BF4CD89703 Load EMI config from database [DB VER: 135 DB DATE: 06-21-2021] error(3) No compatible EMI found, select scatter for this model and try again |
06-28-2021, 21:34 | #176 (permalink) |
No Life Poster Join Date: Aug 2012 Location: Chile
Member: 1797183 Status: Offline Thanks Meter: 149 | Hello team. pls add for General mtk: 1-Dump Preloader Flash Init 2-List Partitiones 3-Dump Partitions 4-Format Partitons 5-Auto Backups parttiton before formating.. |
07-04-2021, 11:02 | #178 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Quote:
Working testpoint for A125F in attachment. | |
The Following User Says Thank You to KrzychuG For This Useful Post: |
07-05-2021, 07:41 | #180 (permalink) | |
this tread only for adding request. | |
