Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 10-22-2023, 02:41   #751 (permalink)
Member: 2597776
Sonork: theking_13
Thanks Meter: 40
plez add tecno PHANTOM X2 5G reset frp etc ..
Old 10-23-2023, 13:41   #752 (permalink)
Member: 2765662
Thanks Meter: 3
Pandora realme RMX3516 repair imei but phone dead.. restored nv item and phone ok
but imei still previous ...
Selected model: Realme RMX3516 (Realme Narzo 50A Prime)
Operation: Repair
Software version: 5.13
Work ID: 10681999
Connect phone in BROM mode. Use volume key buttons or testpoint.
Waiting for device... OK
Device found at COM15
Port: USB\VID_1782&PID_4D00\7&39F7DBC2&0&5
Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134]
Port type: BROM
Connecting to device... OK
Selected processor: Tiger_T612_64
Load files... (universal) OK
Connect preloader 1... OK
Connect preloader 2... OK
Connect loader 1... OK
Connect loader 2... OK
Serial Number: 0L02731X2000034F
Flash Type: UFS
Read partitions info... OK
Checking A/B state... OK [B]
Read product info... [EROFS] ... OK
Product Brand : realme
Product Manufacturer : realme
Product Model : ums9230_nico_Natv_vf
Product Name : RMX3516
Product Device : RE54D8L1
Product Board : ums9230_nico
Board Platform : ums9230
Build ID : TP1A.220624.014
Build Date : Mon Sep 25 23:12:15 CST 2023
Security Patch : 2023-09-05
Version SDK : 33
Version Release : 13
Version Codename : REL
Firmware Version : 270
Userdata FS Type : F2FS
Load NVD... OK
Read IMEI... OK
Current IMEI:
IMEI 1: 86xxxxxxxxxxx
IMEI 2: 86188xxxxxxxx
Repaired IMEI:
IMEI 1: 45xxxxxxxxxxxxxx
IMEI 2: 4578xxxxxxxxxxxxx
Check security state... OK [2]
Check patch state... OK
Read patch data... OK
Correct patch... OK
Patch cert... OK
Write IMEI... OK
Save NVD... OK
Done!
Operation: Restore From Backup
Work ID: 10682426
Port type: BROM
Flash Type: UFS
Version SDK : 33
Restore partition "l_fixnv1_b"... OK
Restore partition "l_modem_b"... OK
Restore partition "trustos_b"... OK
Done!
Old 11-11-2023, 15:44   #753 (permalink)
Member: 2651226
Thanks Meter: 8
Please Add Poco M5/Redmi 11 Prime (ROCK) G99 Repair And Patch Cert. Pandora Show Cpu Type 1208 Not Supported.
The Following User Says Thank You to Rednex For This Useful Post:
Old 11-12-2023, 14:27   #754 (permalink)
Member: 2124174
Thanks Meter: 19
Please Add, nv update and force update option to fix no service on unisoc and tiger cpu when flashing....
Old 11-12-2023, 14:44   #755 (permalink)
Member: 2124174
Thanks Meter: 19
Please Add, "save format" under flash option to fix dead after flashing, hang on logo, protect security, when performing flashing operation on MTK CPU....
Old 11-28-2023, 19:06   #756 (permalink)
Hotline4all's Avatar
Member: 1802683
Sonork: 100.1655083
Thanks Meter: 29
Please Add FRP service for
Honor X6
VNE-LX2
Chip MTK6765
Old 11-29-2023, 08:08   #757 (permalink)
Temporary banned !!
Member: 1806657
Sonork: Bolatito86
Thanks Meter: 7
Add MDM remove both mtk and spd
Old 11-30-2023, 17:41   #758 (permalink)
Member: 2474325
Thanks Meter: 171
please add xiaomi new MTK models 13 series note 13 redmi 13c
phones havnt brom mode! only preloader port detect
Old 12-02-2023, 18:30   #759 (permalink)
Member: 1825908
Sonork: juju
Thanks Meter: 60
TECNO CAMON 20 Pro bootloader unlock problem
Selected model: Tecno CK7n (Tecno Camon 20 Pro)
Operation: Unlock bootloader
Software version: 6.1
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to [BOX or PC] in PRELOADER Mode
Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1511.0]
You are using driver version 3.0.1511.0, we recommend using version 3.0.1504.0 for proper operation. You can install the correct driver from the program directory.
Device found at COM50 [PRELOADER]
Open port... OK
Send start cmd... OK
Get HW code from device... 1208
Get sec config... OK [00000005]
Active sec flags: [SBC DAA]
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6789]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Preloader exist. Skip connection verification.
Get ME ID... OK
ME_ID = 0x87C5AFDD, 0x668FFFE7, 0x390CC6B8, 0xC71BCCF8
Load DownloadAgent... OK
Search DA... OK [1]
Send bootloader... error(DA_INIT_KEY_FAIL). Secure DA agent not compatible for this preloader.
Try select other DA type.
Old 12-10-2023, 12:05   #760 (permalink)
Member: 2962001
Thanks Meter: 3
CPH2387 Preloader mode service add plz
Old 12-12-2023, 21:18   #761 (permalink)
Member: 3027651
Please Oneplus nord 2T IMEI repair .
Old 12-13-2023, 23:14   #762 (permalink)
Member: 2651226
Thanks Meter: 8
Still No Updates For Xiaomi Redmi 11/Poco M5 (Rock) G99 Cpu Patch Cert And Repair ��
Old 12-15-2023, 10:09   #763 (permalink)
Member: 1210289
Sonork: sajer
plss add Network unlock oppo Reno 10 5g(CPH2531)
Old 12-15-2023, 10:26   #764 (permalink)
Member: 2941618
Thanks Meter: 4
plzz add network unlock for VODACOM KICKA 6 4G
Old 12-15-2023, 19:49   #765 (permalink)
Member: 1327392
Thanks Meter: 423
please need EUB mode for samsung frp
and : add frp samsung mtk in download
The Following User Says Thank You to students For This Useful Post:
Page generated in 0.19961 seconds with 9 queries
