05-14-2021, 18:12 | #136 (permalink) |
No Life Poster Join Date: Dec 2016 Location: .
Member: 2659717 Status: Offline Thanks Meter: 487 | Brand: TCL Board: FERMI_TF Model: A501DL Name: A501DL Device: FERMI_TF Release: Android O Version: 8.1.0 Mediatek Version: alps-mp-o1.mp1-V1.197_k39tv1.bsp_P23 Branch: alps-trunk-o1.bsp Security Patch: 2019-06-05 Platform: MT6739 BaseBand CPU : MT6739 MODEM SW Version : MOLY.LR12A.R3.MP.V30.4.P24 MODEM HW Version : TK_MD_L4_HW IMEI location: OTP |
05-14-2021, 18:31 | #137 (permalink) | |
Member: 2659717 Status: Offline Thanks Meter: 487 | Quote:
firmware->>>> https://mega.nz/file/Ch9iELRL#N87uVW...NhVB6oYDeA-144 LOGS: Selected model: Alcatel UNKNOWN Operation: Unlock network Software version: 1.10 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM41 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xBE072B9C, 0x31CC8528, 0xD12AA7B9, 0xFE42B71D Get Chip ID... [MT6739] Get SOC ID... [757205BA9F87590AA85431A4A2A45EA3BDBA1DC4618F621D2D 72025EC260EB23] Get sec config... OK [000000E0] Can't recieve seed data! | |
05-15-2021, 10:42 | #138 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | Oppo A31 2020 CHP2015 not supported Quote:
Couldn't test it on 1.10 because i can't find setup file anywhere. Had to use other tool to work with this phone. | |
05-15-2021, 16:16 | #139 (permalink) |
Freak Poster Join Date: Sep 2017 Location: china
Member: 2758069 Status: Offline Thanks Meter: 40 | Selected model: Realme RMX2189 (Realme C12) Operation: Unlock bootloader Software version: 1.10 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM12 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6CC5207A, 0xF8C5B382, 0x70122855, 0x684E3123 Get Chip ID... [MT6765] Get SOC ID... [993CF8B63D3F842090B01AA78B9F4CFAA8DE9F5AF925D4746E 01C0DC0F4B8441] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [20] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445836384D4209ADE3E48C6749 Load EMI config from database [DB VER: 83 DB DATE: 05-08-2021] OK [1] Trying EMI [667E0B28] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445836384D4209ADE3E48C6749 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... error(8) realme C12 error.. |
The Following User Says Thank You to chenyongming For This Useful Post: |
05-20-2021, 16:18 | #140 (permalink) |
Member: 2758069 Status: Offline Thanks Meter: 40 | Selected model: OPPO CPH1938 (Oppo A9) Operation: Unlock bootloader Software version: 1.11 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x60AABC0B, 0x0011B9EB, 0xAD4C3C6D, 0xB6239CBF Get Chip ID... [MT6771] Get SOC ID... [A057680B46F0554ED02987DBC625451BC24FA30F32E63D6315 555526E7E7B232] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [18] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100335636434D4202519EDA7346A9 Load EMI config from database [DB VER: 102 DB DATE: 05-19-2021] OK [1] Trying EMI [A2B90D60, AF66D99A, 85DF9841, 506D69DA, 40F99738, 4C76F2A3, 9D039D93, F359AA15, F9AF717A, BBEAAF83, 99AF8506] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100335636434D4202519EDA7346A9 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... error(7) Exception: Access violation at address 03C5FEBC. Read of address FFFFFFFF |
05-20-2021, 16:18 | #141 (permalink) |
06-02-2021, 09:10 | #145 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Costa Rica
Member: 1790061 Status: Offline Thanks Meter: 63 | Selected model: Alcatel 5009A (1C) Operation: Repair Software version: 1.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7E108091, 0xF91FA8FE, 0xC1EC071E, 0xBCDFE344 Get Chip ID... [MT6739] Get SOC ID... [113C116225C8E04CAEEC20C3EB6D0B27859616553520BF674B 3F78F43361BC38] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100464536324D4203ABA7E10065FB Load EMI config from database [DB VER: 102 DB DATE: 05-19-2021] OK [1] Trying EMI [AA61426A, 43785860, D0653978, 6432CCDC, CC85EC35, CD1ABC09] Init EXT RAM... error(STATUS_EMI_SETTING_VERSION_ERROR) |
06-02-2021, 09:14 | #146 (permalink) |
Member: 1790061 Status: Offline Thanks Meter: 63 | Selected model: Alcatel 5009A (1C) Operation: Repair Software version: 1.12 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7E108091, 0xF91FA8FE, 0xC1EC071E, 0xBCDFE344 Get Chip ID... [MT6739] Get SOC ID... [113C116225C8E04CAEEC20C3EB6D0B27859616553520BF674B 3F78F43361BC38] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [0] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100464536324D4203ABA7E10065FB Load EMI config from database [DB VER: 113 DB DATE: 05-29-2021] OK [1] Trying EMI [AA61426A, 43785860, D0653978, 6432CCDC, CC85EC35, CD1ABC09] Init EXT RAM... error(STATUS_EMI_SETTING_VERSION_ERROR) |
06-02-2021, 09:40 | #147 (permalink) |
Member: 1790061 Status: Offline Thanks Meter: 63 | Selected model: Xiaomi M2003J15SS (Redmi Note 9) Operation: Unlock bootloader Software version: 1.11 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xFE29E2BF, 0x0BAAC35F, 0xD6C3BEC3, 0x1EA2F677 Get Chip ID... [MT6768] Get SOC ID... [D9FC6C1DBE284A6F243F9CB224A86A621D6B8BEF5F55E5F3C2 A37D20C52D20A8] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [26] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68444561503303103F75AF87D3 Load EMI config from database [DB VER: 102 DB DATE: 05-19-2021] OK [1] Trying EMI [1BB1F176, AF66D99A, 85DF9841, F359AA15, 4C76F2A3, 1A304479, F1ADA01B, 293BC252, 154C2947] Init EXT RAM... error(6) |
06-02-2021, 22:50 | #148 (permalink) |
Junior Member Join Date: May 2014 Location: Morocco
Member: 2191903 Status: Offline Thanks Meter: 0 | hello super team.. thank you so much.... i need to buy this box but we want to add all smart phones with mtk pross... and after that think to add other interface suport all phones with qualcom pross... and no probleme if you add new activation for qualcom with 50 or 70$ but we need the top services ...... so good luck z3x team..i m with you life time.... |
06-05-2021, 15:53 | #150 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1865419 Status: Offline Thanks Meter: 5 | add support please add support for lg mtk based phones 2019 till now for example lg stylo 6 lg Q730mm OS Android 10 Chipset Mediatek MT6765 Helio P35 (12nm) CPU Octa-core (4x2.3 GHz Cortex-A53 & 4x1.8 GHz Cortex-A53) GPU PowerVR GE8320 as you said all mtk phones but not supported for any purpuses.only a few mtk devices supported.thanks |
