Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | -= Z3X JTAG PLUS =- | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #335 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Aug 2016 Location: Peshawar Pakistan
Member: 2613197 Status: Offline Sonork: 100.1673396 Thanks Meter: 24 | Oppo F11 Pro CPH1969 Hy Pandora team i repaired f11 pro imei then its stuck on recovery so i decide to flash when i flashed it by OFP File By Pandora everything ok and then i repaired imei again so when i put the simcard now Its asking code means network lock then i unlock by Pndora box But no Luck Still asking For network Unlock now what i do for it if Network Unlock Not WOrk and After repair phone goes to stuck into recovery now what i do for it please |
![]() | #337 (permalink) |
Major Poster ![]() ![]() Join Date: Oct 2011
Member: 1666558 Status: Offline Thanks Meter: 5 | Selected model: Realme RMX2040 (Realme 6i/Narzo 10) Operation: Repair Software version: 2.10 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM10 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x962A3E81, 0x896F8E99, 0xE90B4CD5, 0xA21C8CC2 Get Chip ID... [MT6768] Get SOC ID... [F20D2EF3DA345EF074BFFE8DEF1E41B961E44969FC07B81E77 1582A8AB190179] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x4501004441343132380113066940C6DF Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x4501004441343132380113066940C6DF EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x1D1EC00000 (116,48Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6769 Board Platform : MT6768 Build ID : RP1A.200720.011 Build Date : Mon Oct 11 21:04:00 CST 2021 Display ID : RP1A.200720.011 release-keys Security Patch : 2021-09-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1607914664672 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI: 3522920xxxxxxxx Write IMEI [NVDATA]... OK Unknown OPPO model! |
![]() | #338 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2016 Location: ZIMBABWE
Member: 2534995 Status: Offline Thanks Meter: 76 ![]() | Samsung SM-A013G (Galaxy A01 Core) Operation: Remove KG Advanced Bypass Security... error Software version: 2.10 https://www.mediafire.com/file/1knls...error.png/file |
![]() | #341 (permalink) |
Member: 2613197 Status: Offline Sonork: 100.1673396 Thanks Meter: 24 | Dear Pandora Box #Z3X Your Working Hard And Very Ex*****ive Which other tool Cant be I Always Like Your Product But PLease Add Also report logs file Installation lacation |
