04-27-2023, 13:40 | #678 (permalink) |
Freak Poster Join Date: Oct 2020 Location: india
Member: 2970939 Status: Offline Thanks Meter: 50 | Emmc ufs health chack usb ADD [mmc_init] : msdc0 init done in DA, err=0 mmc partition[1], size : 0x400000 mmc partition[2], size : 0x400000 mmc partition[3], size : 0x400000 mmc partition[4], size : 0x0 mmc partition[5], size : 0x0 mmc partition[6], size : 0x0 mmc partition[7], size : 0x0 mmc partition[8], size : 0x747c00000 mmc cid : 0x484a0190 0x61344742 0xd504a532 0xf350591 mmc raw cid : 0x90014a48 0x42473461 0x32a504d5 0x9105350f fwid : 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 pre_eol_info 00000003 eMMC Pre EOL is Urgent 90% of reserved blocks are consumed. life_time_est_a 00000001 0%-10% SLC device life time used life_time_est_b 00000001 0%-10% MLC device life time used please press power button to disconnet device! Rebooting device... {}:{0x1} Last edited by .::BIG BOSS::.; 04-27-2023 at 13:45. |
04-27-2023, 15:30 | #679 (permalink) |
Freak Poster Join Date: Sep 2019 Location: sarbandar Age: 29
Member: 2927435 Status: Offline Sonork: valid Thanks Meter: 16 | Selected model: Xiaomi Poco M4 Pro 5G (Evergreen) Operation: Repair Software version: 5.0 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to [BOX] in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM102 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Release testpoint Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM102 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1A25BF0E, 0x08B04F1C, 0x17D284B4, 0x5E971E71 Get Chip ID... [MT6833] Get SOC ID... [73ED1941E7401DE71712FF7AE11F754B88D656248965E06808 31F8934D84496D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [14] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ15AECMBDAR (A043) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ15AECMBDAR UFS_FWVER : A043 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... OK Checking A/B state... OK [A] Read product info... [EXT4] ... OK Product Brand : POCO Product Manufacturer : Xiaomi Product Model : evergreen Product Name : evergreen_eea Product Device : evergreen Product Board : evergreen Board Platform : connac1x Build ID : SP1A.210812.016 Build Date : Tue Jul 12 22:06:38 CST 2022 Display ID : evergreen-user 12 SP1A.210812.01 Security Patch : 2022-07-01 Version SDK : 31 Version Release : 12 Version Codename : REL Firmware Version : V13.0.1.0.SGBEUXM Userdata FS Type : F2FS Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error Repairing IMEI... IMEI 1: 111111111111119 IMEI 2: 111111111111119 Patch CERT [NVDATA]... error(1) sadly not support yet poco m4 pro 5g |
04-27-2023, 17:13 | #680 (permalink) |
Freak Poster Join Date: Apr 2023 Location: Daira Dubai UAE
Member: 3036706 Status: Offline Sonork: Final Touch Thanks Meter: 18 | Please Add Xiaomi Redmi Note 11 Prime 5G, 11E & 11R Most Running Model's Please Add Repair & Patch & Fix Call With Erase NVDATA NVRAM |
04-27-2023, 22:56 | #682 (permalink) |
Member: 3036706 Status: Offline Sonork: Final Touch Thanks Meter: 18 | Please Update Samsung A037F KG Lock Remove Option like Disable and Check Option |
The Following User Says Thank You to Final_Touch For This Useful Post: |
04-27-2023, 23:10 | #683 (permalink) |
Member: 3036706 Status: Offline Sonork: Final Touch Thanks Meter: 18 | Tecno Pop 7 [BF6] SPD9863A Readig Supported But Writing not Supported i have Factory Pac File But Pandora not able to flash i check this model with tecno factory tool supported |
04-28-2023, 09:32 | #685 (permalink) |
Junior Member Join Date: Dec 2019 Location: Cape Town, South Africa
Member: 2941238 Status: Offline Thanks Meter: 1 | Bro, i did post all over Pandora box section no answer no reply, Box work on SPD phone but fail in all MTK phone, since i bough my box till now looking for help |
04-28-2023, 12:25 | #686 (permalink) | |
Junior Member Join Date: Mar 2020 Location: dar es salaam
Member: 2950155 Status: Offline Sonork: 100.1683933 Thanks Meter: 1 | Quote:
smart 6 x6511b verion 56 and up loader error spd tecno spark 8c kg5j no brom please update da file or preloader mode add option of costum da on mtk tab add option of costum loader spd tab thanks | |
05-02-2023, 04:19 | #689 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Hi team, please add pattren read add its good and bater add all mtk read pattren and code thanks advance |
05-02-2023, 09:36 | #690 (permalink) |
Freak Poster Join Date: Nov 2013 Location: zimbabwe
Member: 2075865 Status: Offline Thanks Meter: 99 | Connect phone in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM67 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0699 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CB00, SW VER: 0002, HW SUB CODE: 8A00 Detect chip [MT6739] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Brom disabled by Efuse[0x106] Selected model: Nokia Mediatek Operation: Unlock network Software version: 5.0 Work ID: 2024821 any solution to unlock network Nokia c2 2nd edition ta-1468 Report Post |
