Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 04-05-2021, 07:34   #91 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 147
Originally Posted by blang View Post
for you question can be 2 answer.
yes supported and not supported.
because if you want exactly answer - provide exactly details about device:
1 device model
2 device firmware
3 function
when i will send it to developers and they will answer about this device and function. supported or not.
for example, let it may be
redmi note 8 pro Begonia , on latest miui V12.0.7.0.QGGMIXM
can we repair both imei (tothe origional) without any nv crash or bootloop?
or , does this box save important data during flash process?
if accidently imei goes corrupted or null, can be solved by rewriting backup. and both imei are alive again without any nv error?
Old 04-05-2021, 08:27   #92 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,515
i will ask question developers, they will check and will answer. now sure how fast. if phone in hands, when fast. if not in hands, then only in theory.
Old 04-05-2021, 10:05   #93 (permalink)
Member: 2754448
Thanks Meter: 2
Originally Posted by icyme View Post
Selected model: Xiaomi Redmi 9A (M2006C3LC)
Operation: Unlock bootloader
Software version: 1.5
Host Power Off... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Send start cmd... OK
Get HW code from device... 0707
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6768]
Get sec config... OK [000000E7]
Active sec flags: [SBC SLA DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Connect Type-C to HUB... OK
Wait for device connecting... OK
Device found at COM3 [BROM]
Open port... OK
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0xEB4775B1, 0xF7A6B923, 0x8924ECC5, 0xC5D98FF4
Get Chip ID... [MT6768]
Get SOC ID... [FDCA1605638DAB022E94ED1C4C25A7D58B025898B906A1A201 1581335F29F407]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [31]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader...
it always stop here,no time out notice.......any issue?
I have the same problem
Selected model: Mediatek Mediatek
Host Power On... OK
Device found at COM6 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x6EFE8555, 0xDE866100, 0x91878FA5, 0x437CF260
Get SOC ID... [028D997D647413AF1A276053C8B02052B3F9FD046D929D4736 CE41CD03F3342A]
The model is redmi 9 (m2004j19c)
Old 04-05-2021, 21:15   #94 (permalink)
Member: 2754448
Thanks Meter: 2
Please add oppok7x (perm00) CPUimensity 720 , and Xiaomi redmi note9 (China 5g) dimension 800u
Old 04-07-2021, 13:26   #95 (permalink)
Member: 1610674
Sonork: 210921
Thanks Meter: 217
alcatel 5007u already on the supported list but not working
Selected model: Alcatel 5007U (1V (2020))
Operation: Read Flash Info
Software version: 1.6
Host Power On... OK
Get HW code from device... 0766
Detect chip [MT6765]
Device found at COM139 [BROM]
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
ME_ID = 0x63336E48, 0x0F1D2BFE, 0x9FE58F8A, 0x2DD7E720
Get Chip ID... [MT6765]
Get SOC ID... [3F347E0992B15D1EAC8A4C39CBF2F5C2E7BB768B15F40A2612 BBED3ECE53E50D]
Search DA... OK [29]
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
EMMC_ID: 0xF40122426977696E20100006BB66B733
Load EMI config from database [DB VER: 47 DB DATE: 04-02-2021] OK [0]
Trying EMI []
Init EXT RAM... error(STATUS_EMI_CONTAINER_FILE_NOT_FOUND)
Old 04-07-2021, 13:31   #96 (permalink)
Member: 1610674
Sonork: 210921
Thanks Meter: 217
also please addd direct memory tool where one can load all phone partions then
1. read selected partitions
2. browse and load partitions files
3. wipe selected partitions
4. write selected partitions
factory reset option both flash mode and meta mode
Old 04-08-2021, 01:26   #97 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Trying EMI []
will be fixed in next update.
The Following 2 Users Say Thank You to blang For This Useful Post:
Old 04-08-2021, 19:44   #98 (permalink)
Member: 2753245
Thanks Meter: 8
Hello. Tab Joy 2 (9032z) MetroPCS variant USA.
This model not yet supported for unlock by any box or software. Maybe pandora can be first? If need remote testing I am available to offer my device. (skype = [email protected] )
Old 04-08-2021, 20:26   #99 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
what firmware version what mcu type?
Old 04-09-2021, 18:46   #100 (permalink)
Member: 2346573
Thanks Meter: 6
Please Add
OPPO, Vivo and more repair imei please
Old 04-09-2021, 19:31   #101 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Originally Posted by farhanu View Post
Please Add
Do you have Pandora box?
Old 04-09-2021, 19:44   #102 (permalink)
Member: 2887504
Thanks Meter: 7
add free with out credits
lg stylo 6 and lg k51
both mtk MT6765 and MT6762
very popular models the developers must know this models
Old 04-10-2021, 20:15   #103 (permalink)
Member: 1610674
Sonork: 210921
Thanks Meter: 217
I would suggest you add Samsung Tab. and add Samsung MTK devices
Reset frp
Network unlock
IMEI repair
Patch cert
Since they are also MTK devices this would make this tool from another world
Also add oppo and vivo reset locks without data loss
Mi account reset option for Xiaomi devices
Auto backup of security partitions before repair IMEI option
Backup and restore nvram
Force phone to charging mode or reboot after failed operations
I know am asking a lot but that is because I believe you can DO IT
The Following 2 Users Say Thank You to okello For This Useful Post:
Old 04-10-2021, 21:49   #104 (permalink)
shazebmobile's Avatar
Member: 2135915
Thanks Meter: 50
add imei repair for this model
Brand : Oppo
Model : A31 (CPH2015)
Operation : Read Info
Connection Mode : BROM (Hold Key for BROM Mode)
Hold VOL UP + DOWN and connect USB Cable.
Some phone may have different key combination for BROM mode.
Waiting for device in BROM mode...
Port: COM24
Port Name: MediaTek USB Port (COM24)
Path: \\?\usb#vid_0e8d&pid_0003#6&25b4a8de&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73}
Chipset: 0x0766, [MT6765]
Hardware Info: 0x8A00, 0xCA00, 0x00
SecureBoot: True
SLA: False
DA Auth: True
Disabling WatchDog...
- Success
Sending Payload data...
- Payload sent
Initiating Control Transfer...
- Done
Waiting for result...
- Result: 0xA1A2A3A4
Disable Auth Success
Waiting for Phone in Flash Mode...
Connect Power Off phone within 30 secs...
Port : MediaTek USB Port (COM24)
Connected to BROM.
Sending Download Agent...
connect DA end stage: 2, enable DRAM in 1st DA: 0
Connected to Download Agent..
Syncing with Target...
Reading Partition Table...
Storage : eMMC
Reading Device Information...
Manufacturer : OPPO
Build Flavor : full_oppo6765_19581-user
Build Desc. : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20201217.223505 release-keys
Android Ver. : 9
Patch Level : 2021-01-05
Platform : MT6765
Board : oppo6765_19581
Platform : mt6765
Platform : MT6765
Platform : mt6765
Userdata is NOT ENCRYPTED
Old 04-12-2021, 07:01   #105 (permalink)
Member: 1610674
Sonork: 210921
Thanks Meter: 217
nokia 2.4 error 3 if possible add online minor updates to fix some bugs than waiting for updates many phones still giving error and working fine with other tools
Page generated in 0.11408 seconds with 9 queries
