Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 01-15-2022, 05:20   #1 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 284
G326W FRP Failed [Solved]
hi the Samsung G326W frp got failed.
Selected model: Samsung SM-A326W (Galaxy A32 5G)
Operation: Erase FRP
Software version: 2.10
Host Power Off... OK
Switch virtual port to NONE... OK
Connect Type-C to HUB... OK
Host Power On... OK
Connect phone to BOX in BROM/PRELOADER Mode
Wait for device connecting... OK
Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0]
Device found at COM30 [BROM]
Open port... OK
Send start cmd... OK
Get HW code from device... 0996
Get HW & SW version from device... OK
HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00
Detect chip [MT6853]
Library Version [2]
Select platform... OK
Init BROM... OK
Force Charge... OK
Disable WatchDog Timer... OK
Force switch to BROM... OK
Switch virtual port to USB... OK
Connect Type-C to BOX... OK
Host Power On... OK
Wait for device... OK
Read usbhost speed... HIGH
Read Device Descriptor...
Get VID/PID...0E8D/0003
Get sec config... OK [000000E5]
Active sec flags: [SBC DAA]
Advanced Bypass Security... OK
Disconnect virtual port... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Reopen port for libver2... OK
Get ME ID... OK
ME_ID = 0x54A24661, 0x79795FA4, 0xF34ED89E, 0x4923A7EA
Get Chip ID... [MT6853]
Get SOC ID... [4F1E7E044FD47B80D67D504E70C5634864BEEF6741C1044490 B8226EB5775942]
Get sec config... OK [000000E0]
Load DownloadAgent... OK
Search DA... OK [30]
Send preloader... OK
Start preloader... OK
Check preloader answer... OK
Send bootloader... OK
Start bootloader... OK
Wait for answer from bootloader... OK
Send SYNC signal... OK
Setup device enviroment... OK
Setup device parametres... OK
Receive DA SYNC signal... OK
Set DA parametres... OK
Get device connection agent... [BROM]
Get device info... OK
UFS CID (FW VER): KM5P8001DM-B424 (0002)
Load EMI from phone... OK
Parse EMI config... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_CID : KM5P8001DM-B424
UFS_FWVER : 0002
BLOCK_SIZE: 0x0000001000 (4.00Kb)
UFS_LU0 : 0x0000400000 (4.00Mb)
UFS_LU1 : 0x0000400000 (4.00Mb)
UFS_LU2 : 0x0EE5800000 (59.59Gb)
RAM INFO:
INT_SRAM: 0x0000070000 (448.00Kb)
EXT_RAM : 0x0100000000 (4.00Gb)
Check USB status... USB_HIGH_SPEED
Read partitions info from phone... OK
Check A/B state... OK
Read product info... OK
Product Brand : samsung
Product Manufacturer : samsung
Product Model : SM-A326W
Product Name : a32xcs
Product Device : a32x
Product Board : k6853v1_64_titan
Board Platform : MT6853
Build ID : RP1A.200720.012
Build Date : Thu Jun 3 18:52:40 KST 2021
Display ID : RP1A.200720.012.A326WVLU3AUF1
Security Patch : 2021-05-01
Version SDK : 30
Version Release : 11
Version Codename : REL
Firmware Version : A326WVLU3AUF1
Read partition "frp"... OK
Read partition "persistent"... OK
Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Samsung_SM-A326W%20(Galaxy%20A32%205G)/FRP_BACKUP_(2022-1-14_21-12-19)/"directory
Format "frp" partition... OK
Format "persistent" partition... OK
Writting FRP data... OK
Erase FRP done!
Old 01-15-2022, 09:47   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 1,665
Hello. Why failed? FRP still presents? Try erase manually in one operation this partitions: frp, persistent, userdata and cache. Post result.
Old 01-16-2022, 03:51   #3 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 284
You mean format right?
Old 01-16-2022, 04:05   #4 (permalink)
rasgula's Avatar
Member: 119464
Thanks Meter: 284
it worked for me thank you.
Erasing of partitions can damage your device.
Make sure that you have a backup created. Continue? YES
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Host Power On... OK
Open port... OK
Library Version [2]
Init BROM... OK
Force Charge... OK
Get ME ID... OK
Init EXT RAM... OK
Send 2nd DA... OK
UFS INFO:
UFS_FWVER : 0002
RAM INFO:
Version SDK : 30
Format "cache" partition... OK
Format "userdata" partition... OK
Format Partitions done!
The Following 2 Users Say Thank You to rasgula For This Useful Post:
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.09006 seconds with 7 queries
