03-14-2022, 07:06 | #3 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Indonesia Age: 44
Member: 132523 Status: Offline Thanks Meter: 10 | this [03-14-2022 12:48:27] Selected model: OPPO PECT30 (Oppo A53 5G) [03-14-2022 12:48:27] Operation: Flash (Format all + download) [03-14-2022 12:48:27] Software version: 3.0 [03-14-2022 12:48:27] [03-14-2022 12:48:27] Parse scatter file... OK [03-14-2022 12:48:27] Load Rom Images... OK [03-14-2022 12:48:27] Host Power Off... OK [03-14-2022 12:48:27] Switch virtual port to NONE... OK [03-14-2022 12:48:27] Connect Type-C to HUB... OK [03-14-2022 12:48:27] Host Power On... OK [03-14-2022 12:48:27] Connect phone to BOX in BROM/PRELOADER Mode [03-14-2022 12:48:27] Wait for device connecting... OK [03-14-2022 12:48:28] Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] [03-14-2022 12:48:28] Device found at COM4 [BROM] [03-14-2022 12:48:28] Open port... OK [03-14-2022 12:48:28] Send start cmd... OK [03-14-2022 12:48:28] Get HW code from device... 0996 [03-14-2022 12:48:28] Get HW & SW version from device... OK [03-14-2022 12:48:28] HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 [03-14-2022 12:48:28] Detect chip [MT6853] [03-14-2022 12:48:28] Library Version [2] [03-14-2022 12:48:28] Select platform... OK [03-14-2022 12:48:28] Init BROM... OK [03-14-2022 12:48:28] Force Charge... OK [03-14-2022 12:48:28] Disable WatchDog Timer... OK [03-14-2022 12:48:28] Force switch to BROM... OK [03-14-2022 12:48:28] Switch virtual port to USB... OK [03-14-2022 12:48:28] Connect Type-C to BOX... OK [03-14-2022 12:48:28] Host Power On... OK [03-14-2022 12:48:28] Wait for device... OK [03-14-2022 12:48:29] Read usbhost speed... HIGH [03-14-2022 12:48:29] Read Device Descriptor... [03-14-2022 12:48:29] Get VID/PID...0E8D/0003 [03-14-2022 12:48:29] Send start cmd... OK [03-14-2022 12:48:29] Get HW code from device... 0996 [03-14-2022 12:48:29] Get HW & SW version from device... OK [03-14-2022 12:48:29] HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 [03-14-2022 12:48:29] Detect chip [MT6853] [03-14-2022 12:48:29] Get sec config... OK [000000E5] [03-14-2022 12:48:29] Active sec flags: [SBC DAA] [03-14-2022 12:48:29] Advanced Bypass Security... OK [03-14-2022 12:48:30] Disconnect virtual port... OK [03-14-2022 12:48:30] Connect Type-C to HUB... OK [03-14-2022 12:48:30] Wait for device connecting... OK [03-14-2022 12:48:31] Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] [03-14-2022 12:48:31] Device found at COM4 [BROM] [03-14-2022 12:48:31] Open port... OK [03-14-2022 12:48:31] Send start cmd... OK [03-14-2022 12:48:31] Get HW code from device... 0996 [03-14-2022 12:48:31] Get HW & SW version from device... OK [03-14-2022 12:48:31] HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 [03-14-2022 12:48:31] Detect chip [MT6853] [03-14-2022 12:48:31] Library Version [2] [03-14-2022 12:48:31] Select platform... OK [03-14-2022 12:48:31] Init BROM... OK [03-14-2022 12:48:31] Force Charge... OK [03-14-2022 12:48:31] Disable WatchDog Timer... OK [03-14-2022 12:48:31] Reopen port for libver2... OK [03-14-2022 12:48:31] Get ME ID... OK [03-14-2022 12:48:31] ME_ID = 0x0D1026A9, 0x9441F4A2, 0xB8F0A5F5, 0x5235DA14 [03-14-2022 12:48:31] Get Chip ID... [MT6853] [03-14-2022 12:48:31] Get SOC ID... [B6BD54D507E769A1E3EE4ADD2E5AF87C2E48BD84989E2E619B D68988CEB65B7D] [03-14-2022 12:48:31] Get sec config... OK [000000E0] [03-14-2022 12:48:31] Load DownloadAgent... OK [03-14-2022 12:48:31] Search DA... OK [15] [03-14-2022 12:48:31] Send preloader... OK [03-14-2022 12:48:31] Start preloader... OK [03-14-2022 12:48:31] Check preloader answer... OK [03-14-2022 12:48:33] Send bootloader... OK [03-14-2022 12:48:36] Start bootloader... OK [03-14-2022 12:48:36] Wait for answer from bootloader... OK [03-14-2022 12:48:36] Send SYNC signal... OK [03-14-2022 12:48:36] Setup device enviroment... OK [03-14-2022 12:48:36] Setup device parametres... OK [03-14-2022 12:48:36] Receive DA SYNC signal... OK [03-14-2022 12:48:36] Set DA parametres... OK [03-14-2022 12:48:36] Get device connection agent... [BROM] [03-14-2022 12:48:36] Get device info... OK [03-14-2022 12:48:36] UFS CID (FW VER): H9HQ16AECMMDAR (A107) [03-14-2022 12:48:36] Load EMI config from preloader... OK [03-14-2022 12:48:36] Init EXT RAM... OK [03-14-2022 12:48:37] Send 2nd DA... OK [03-14-2022 12:48:38] Get device info... OK [03-14-2022 12:48:39] UFS INFO: [03-14-2022 12:48:39] UFS_CID : H9HQ16AECMMDAR [03-14-2022 12:48:39] UFS_FWVER : A107 [03-14-2022 12:48:39] BLOCK_SIZE: 0x0000001000 (4.00Kb) [03-14-2022 12:48:39] UFS_LU0 : 0x0000400000 (4.00Mb) [03-14-2022 12:48:39] UFS_LU1 : 0x0000400000 (4.00Mb) [03-14-2022 12:48:39] UFS_LU2 : 0x1DCB000000 (119.17Gb) [03-14-2022 12:48:39] RAM INFO: [03-14-2022 12:48:39] INT_SRAM: 0x0000070000 (448.00Kb) [03-14-2022 12:48:39] EXT_RAM : 0x0100000000 (4.00Gb) [03-14-2022 12:48:39] Get scatter info... OK [03-14-2022 12:48:39] Check USB status... USB_HIGH_SPEED [03-14-2022 12:48:39] Create autoformat settings... OK [03-14-2022 12:48:39] Format UFS_LU0 partition( 0x00000000..0x003FFFFF )... OK [03-14-2022 12:48:39] Format UFS_LU1 partition( 0x00000000..0x003FFFFF )... OK [03-14-2022 12:48:39] Format UFS_LU2 partition( 0x00000000..0x1DCAFFFFFF )... OK [03-14-2022 12:48:43] Get scatter info... OK [03-14-2022 12:48:43] Verify scatter file... OK [03-14-2022 12:48:43] Do NAND BMT remark... OK [03-14-2022 12:48:43] Setup download info... OK [03-14-2022 12:48:43] Get partition table catagory... OK [GPT] [03-14-2022 12:48:43] Read mirror partition table... OK [03-14-2022 12:48:43] Generate mirror partition table... OK [03-14-2022 12:48:43] Download mirror partition table... OK [03-14-2022 12:48:43] Read major partition table... OK [03-14-2022 12:48:43] Generate major partition table... OK [03-14-2022 12:48:43] Download major partition table... OK [03-14-2022 12:48:43] Download "preloader"... OK [03-14-2022 12:48:43] Download "recovery"... OK [03-14-2022 12:48:45] Download "opporeserve2"... OK [03-14-2022 12:48:46] Download "vbmeta"... OK [03-14-2022 12:48:46] Download "vbmeta_system"... OK [03-14-2022 12:48:46] Download "vbmeta_vendor"... OK [03-14-2022 12:48:46] Download "special_preload"... OK [03-14-2022 12:48:47] Download "my_custom"... OK [03-14-2022 12:48:55] Download "cdt_engineering"... OK [03-14-2022 12:48:55] Download "md1img"... OK [03-14-2022 12:48:57] Download "spmfw"... OK [03-14-2022 12:48:57] Download "audio_dsp"... OK [03-14-2022 12:48:57] Download "pi_img"... OK [03-14-2022 12:48:57] Download "dpm_1"... OK [03-14-2022 12:48:57] Download "dpm_2"... OK [03-14-2022 12:48:57] Download "scp1"... OK [03-14-2022 12:48:57] Download "scp2"... OK [03-14-2022 12:48:57] Download "sspm_1"... OK [03-14-2022 12:48:57] Download "sspm_2"... OK [03-14-2022 12:48:57] Download "mcupm_1"... OK [03-14-2022 12:48:57] Download "mcupm_2"... OK [03-14-2022 12:48:57] Download "cam_vpu1"... OK [03-14-2022 12:48:57] Download "cam_vpu2"... OK [03-14-2022 12:48:58] Download "cam_vpu3"... OK [03-14-2022 12:48:58] Download "gz1"... OK [03-14-2022 12:48:58] Download "gz2"... OK [03-14-2022 12:48:59] Download "lk"... OK [03-14-2022 12:48:59] Download "lk2"... OK [03-14-2022 12:48:59] Download "boot"... OK [03-14-2022 12:49:00] Download "logo"... OK [03-14-2022 12:49:00] Download "dtbo"... OK [03-14-2022 12:49:00] Download "tee1"... OK [03-14-2022 12:49:00] Download "tee2"... OK [03-14-2022 12:49:00] Download "super"... OK [03-14-2022 12:51:56] Download "cache"... OK [03-14-2022 12:51:57] Download "userdata"... OK [03-14-2022 12:52:29] Flashing done! [03-14-2022 12:52:30] |
