03-28-2022, 14:25 | #1 (permalink) |
Freak Poster Join Date: May 2019 Location: pakistan
Member: 2911786 Status: Offline Thanks Meter: 34 | mya-al10 flashing failed [Answered] Operation: Flash (Upgrade) Software version: 3.2 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0321 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0321 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Get sec config... OK [00000001] Active sec flags: [SBC] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM4 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0321 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6735] Library Version [1] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Load DownloadAgent... OK ME_ID = 0x63DFD0EF, 0xA9454E3E, 0xD7B27F9B, 0x79D49D21 Get sec config... OK [00000000] Get BROM version... OK Search DA... OK [30] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Check bootloader answer... OK Wait for answer from bootloader... OK Wait for hw detection... OK StorageType matched! Wait DA version... v4.2 Send BROM version... OK Send storage config... OK SyncBmtInfoWithDA... OK Set params... OK Read flash info... OK EMMC_ID: 0x90014A484247346132D434C194270901 Load EMI config from preloader... OK Init DRAM... OK Enable DRAM... error(15) |
