05-11-2021, 07:14 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: costa rica
Member: 917285 Status: Offline Sonork: damond Thanks Meter: 31 | How to manually instal drivers pandora box [Solution inside] |
05-11-2021, 17:31 | #2 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
you have to connect USB-mini connector side to pc. | |
05-12-2021, 14:23 | #7 (permalink) | |
Member: 917285 Status: Offline Sonork: damond Thanks Meter: 31 | Quote:
i can hear that the box is connected, there is nothing undetected https://ibb.co/0qvQ88S https://ibb.co/phtTW1c | |
05-12-2021, 17:15 | #8 (permalink) | |
Product Supporter Join Date: Jul 2009 Location: N/A
Member: 1078000 Status: Offline Thanks Meter: 5 | Quote:
05-12-2021, 17:31 | #9 (permalink) |
Member: 1078000 Status: Offline Thanks Meter: 5 | or try install USBDeview software and remove all devices with VID 1FC9 & PID 82B2 and VID 1FC9 & PID 82B3, then reconnect BOX https://www.nirsoft.net/utils/usb_devices_view.html |
05-12-2021, 23:01 | #10 (permalink) | |
i tried 3 different pcs, im also installing win 7 on another pc, il try usbdeview and post result | |
05-13-2021, 06:03 | #11 (permalink) | |
ok check to see i fthere is any device with VID 1FC9 & PID 82B2 and VID 1FC9 & PID 82B3, but theres nothing with thta, i also trie using fresh windows 7 instalation and got this error the driver package was not installed on any device because there are no matchoing devices in the device tree, ERROR CODE (0XE000020B) | |
05-20-2021, 18:57 | #12 (permalink) |
Member: 917285 Status: Offline Sonork: damond Thanks Meter: 31 | hi I've contatced gsmserver, and the box has to be replaced, but for me is almost impossible to ship it due shipping cost, ist almos $160 to ship the box to hon kon, id like to know if you con guide me on fixing it, because i cant afford to pay so much just for shipping |
08-10-2022, 18:25 | #13 (permalink) |
Insane Poster Join Date: Aug 2010 Location: City Dorohoi Country Romania Age: 59
Member: 1368264 Status: Offline Thanks Meter: 13 | This tutorial helped me. https://www.youtube.com/watch?v=BcKZBdHhZi0 |
The Following 2 Users Say Thank You to totalservice For This Useful Post: |
08-11-2022, 07:10 | #14 (permalink) |
Member: 1368264 Status: Offline Thanks Meter: 13 | I failed to install with windows 7. It only worked with windows 10. This video helped me. https://www.youtube.com/watch?v=BcKZBdHhZi0 |
08-13-2022, 17:16 | #15 (permalink) |
Member: 1368264 Status: Offline Thanks Meter: 13 | I'll come back with details. Pandora Box also works with windows 7 and 10. On a computer with windows 7 that didn't work, I tried all the USB ports in turn and finally found one that worked and the green led on the box stayed lit and it stopped blinking. It is very picky with USB ports. On another computer with Windows 10 where it was working, I took it out several times and put it in other USB ports and in the end it didn't go anywhere. P.S. I used a different quality cable as the connection cable to the PS and not the one from the box, and I did not use the adapter from the box with the power port. |
