12-26-2021, 20:03 | #1 (permalink) |
Junior Member Join Date: Nov 2021 Location: iRan Age: 29
Member: 3000862 Status: Offline Thanks Meter: 1 | Note 8 Pro NvData is Corrupted [Answered] Can you help ?? |
12-27-2021, 07:44 | #3 (permalink) |
Member: 3000862 Status: Offline Thanks Meter: 1 | Selected model: Xiaomi M1906G7E (Redmi Note 8 Pro) Operation: Repair Software version: 2.8 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM17 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x0AA7F545, 0xF17871B8, 0x9D70D75D, 0x9B33D43A Get Chip ID... [MT6785] Get SOC ID... [8BFB7F33E706FC07EEB493F4102729D0CE0CF7BF200EE816D4 D76C791B293413] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM2V8001CM-B707 (0600) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM2V8001CM-B707 UFS_FWVER : 0600 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : Redmi Note 8 Pro Product Name : begoniain Product Device : begoniain Product Board : begoniain Board Platform : MT6785 Build ID : RP1A.200720.011 Build Date : Sat Oct 16 16:22:57 CST 2021 Display ID : RP1A.200720.011 Security Patch : 2021-10-01 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : V12.5.5.0.RGGINXM Read partitions info from phone... OK Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: ############### IMEI 2: ############### Repairing IMEI... IMEI 1: ############### IMEI 2: ############### Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! |
12-28-2021, 10:51 | #12 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,058 | Oh, stop. This model not announced for dual sim repair. Currently not supported for such operation, so only hw solution the right way for you. |
The Following User Says Thank You to Z3X For This Useful Post: |
12-28-2021, 18:18 | #14 (permalink) |
Member: 3000862 Status: Offline Thanks Meter: 1 | Because the option of repairing dual SIM cards was active for this model, I also thought that it really has the ability to do this, but I did not know that I would have a problem. |
