04-26-2024, 12:57 | #1 (permalink) |
Freak Poster Join Date: Aug 2022 Location: ua Age: 39
Member: 3019648 Status: Online Sonork: uploads Thanks Meter: 85 | Infinix X6525 MDM ADD [Solution inside] Waiting for device... OK Device found at COM9 Port: USB\VID_1782&PID_4D00\6&260A8E58&0&1 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Port type: BROM Connecting to device... OK Selected processor: Tiger_T612_64 Load files... (universal) OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: 11286-------- Read partitions info... OK Checking A/B state... OK [B] Read product info... [EROFS] ... OK Product Brand : Infinix Product Manufacturer : INFINIX Product Model : Infinix X6525 Product Name : X6525 Product Device : Infinix-X6525 Board Platform : ums9230 Build ID : TP1A.220624.014 Build Date : Wed Feb 21 22:43:32 CST 2024 Display ID : X6525-F069CaCbCcGjGkGl-TGo-EU-240221V153 Security Patch : 2024-02-05 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : 127 Userdata FS Type : F2FS Selected model: Infinix X6525 (Infinix Smart 8) Operation: Restore From Backup Software version: 6.8 Work ID: 26490543 |
The Following User Says Thank You to uploads2022 For This Useful Post: |
04-26-2024, 14:33 | #3 (permalink) |
Freak Poster Join Date: Feb 2021 Location: San Francisco De Macoris Age: 30
Member: 2979877 Status: Online Thanks Meter: 85 | [QUOTE=uploads2022;14992081]Connect phone in BROM mode. Use volume key buttons or testpoint. Waiting for device... OK Device found at COM9 Port: USB\VID_1782&PID_4D00\6&260A8E58&0&1 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Port type: BROM Connecting to device... OK Selected processor: Tiger_T612_64 Load files... (universal) OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: 11286-------- Read partitions info... OK Checking A/B state... OK [B] Read product info... [EROFS] ... OK Product Brand : Infinix Product Manufacturer : INFINIX Product Model : Infinix X6525 Product Name : X6525 Product Device : Infinix-X6525 Board Platform : ums9230 Build ID : TP1A.220624.014 Build Date : Wed Feb 21 22:43:32 CST 2024 Display ID : X6525-F069CaCbCcGjGkGl-TGo-EU-240221V153 Security Patch : 2024-02-05 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : 127 Userdata FS Type : F2FS Selected model: Infinix X6525 (Infinix Smart 8) Operation: Restore From Backup Software version: 6.8 Work ID: 26490543[/oQUOTE] solution with pandora tool https://www.youtube.com/watch?v=25DkUPDxzJE |
04-26-2024, 16:14 | #4 (permalink) | |
Member: 3019648 Status: Online Sonork: uploads Thanks Meter: 85 | [QUOTE=darkherman;14992117] Quote:
04-26-2024, 19:28 | #5 (permalink) |
Member: 2979877 Status: Online Thanks Meter: 85 | well ya that case you would have to risk experimenting with firmware to remove MDM if you don't know what you're doing it's better not to do it, because it doesn't make you responsible wait for someone to confirm that this method worked for you and did not bricked your device |
04-26-2024, 19:50 | #6 (permalink) | |
Member: 3019648 Status: Online Sonork: uploads Thanks Meter: 85 | Quote:
04-26-2024, 21:42 | #7 (permalink) |
Member: 2979877 Status: Online Thanks Meter: 85 | just in case I will leave firmware ****************************/file/2oe4pn0iu4vsm3q/X6525-F069CaCbCc-TGo-EU-231120V97.zip/file mediafire |
04-30-2024, 14:48 | #10 (permalink) |
Member: 2979877 Status: Online Thanks Meter: 85 | |
05-01-2024, 15:47 | #12 (permalink) |
Member: 2979877 Status: Online Thanks Meter: 85 | did you see the video? because in the process you simply backup the security partitions and then format all partitions except PGPT (Partition Table) and restore backup of the security previously made as it says in the video and unlock bootloader and flash official firmware and then use a firmware from another region and just flash the super.img partition (before it was system.img) and after flashing unlock bootlader and boot with mdm removed. that's why I said: if I don't know what you're doing I'm not responsible. |
05-14-2024, 20:17 | #13 (permalink) |
Member: 3019648 Status: Online Sonork: uploads Thanks Meter: 85 | unlocked mdm X6525 Product Brand : Infinix Product Manufacturer : INFINIX Product Model : Infinix X6525 Product Name : X6525 Product Device : Infinix-X6525 Board Platform : ums9230 Build ID : TP1A.220624.014 Build Date : Wed Apr 17 16:34:57 CST 2024 Display ID : X6525-F069CaCbCcGjGkGl-TGo-EU-240417V180 Security Patch : 2024-04-05 Version SDK : 33 Version Release : 13 Version Codename : REL Firmware Version : 156 Userdata FS Type : F2FS |
