06-15-2022, 07:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2015
Member: 2489055 Status: Offline Thanks Meter: 71 | Information Oppo/Realme Why IMEI Null after repair Operation [Info] Lots of Threads I read where imei null imei repair not success imei vanish after repair.users complaint Question is Why this happens Answer Before repair operation.Click on Read IMEI function it will tell you whether your nvdata partition is good or damaged sceneraio 1.if nvdata partition is good then it will show imei and operation finish 2.If nvdata partition is damaged then software will tell damaged Users tries to repair imei on damaged nvdata partition.It will be in vain always.Software show success but imei will be null/blank always Remedy Restore nvdata partition from a good backup.It will be found on any site.Read it from good working phone and write on damaged phone and try repair .it will be success in one click Latest Oppo/Realme Firmware does not allow to repair imei successfully.In this case downgrade phone to lowest available firmware then try Hope this helps to new users BR HardnSoft |
The Following User Says Thank You to hardnsoft67 For This Useful Post: |
