03-09-2023, 23:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 457589 Status: Offline Thanks Meter: 23 | Init EXT RAM... error(6) The phone was flashed and then died A new and old version has been flashed Selected model: Realme RMX2180 (Realme C15) Operation: Unlock bootloader Software version: 4.6 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xC55D345C, 0x9E9F5CB1, 0x7A863FF1, 0x2576CE11 Get Chip ID... [MT6765] Get SOC ID... [6F3341BFC7B57C5E3488E56E8D789E958DDC79049E1C7D11E0 E34FB42539A84C] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100444836444142083E64CED0C78B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... error(6) |
03-10-2023, 09:06 | #3 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,035 | Hello. Try to choose firmware with compatible preloader and repeat operation. Also, you using testpoint? |
The Following User Says Thank You to Z3X For This Useful Post: |
03-10-2023, 14:56 | #5 (permalink) |
Member: 706257 Status: Offline Thanks Meter: 5,035 | According to log - emi loading from phone, not from firmware. Try choose different firmware and untick read emi from phone. Last edited by Z3X; 03-10-2023 at 15:11. |
