06-04-2022, 09:39 | #1 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | need help oppo f15 cph2001 dead after flash showing error ram 6 [Answered] Selected model: OPPO CPH2001 (Oppo F15) Operation: Flash (Download only) Software version: 3.5 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xCE6B82EE, 0xDA4154D9, 0x1A0FC70D, 0x776677FF Get Chip ID... [MT6765] Get SOC ID... [B8C7E7395B888B09229C0710A5D3231D076B62F9B370F67FB2 9767960A714CEF] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68444561503303007B3FAA78ED Load EMI config from preloader... OK Init EXT RAM... error(6) Selected model: OPPO CPH2001 (Oppo F15) Operation: Flash (Download only) Software version: 3.5 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xCE6B82EE, 0xDA4154D9, 0x1A0FC70D, 0x776677FF Get Chip ID... [MT6765] Get SOC ID... [B8C7E7395B888B09229C0710A5D3231D076B62F9B370F67FB2 9767960A714CEF] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68444561503303007B3FAA78ED Load EMI config from preloader... OK Init EXT RAM... error(6) |
06-09-2022, 11:54 | #4 (permalink) | |
Freak Poster Join Date: Jun 2014 Location: Pakistan
Member: 2206874 Status: Offline Sonork: 100.1584591 Thanks Meter: 36 | OPPO F15 imei repair failed Quote:
Selected model: OPPO CPH2001 (Oppo F15) Operation: Repair Software version: 3.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Get sec config... OK [000000E5] Active sec flags: [SBC DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1633,usb2ser.sys,3.0.1504.0] Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xFACA1F31, 0xCA433E45, 0xD8A2C28F, 0x02707216 Get Chip ID... [MT6771] Get SOC ID... [D0024270B09E09AB8DAE725744C822AB2E9581FF44AC9C54E8 80D758EB91542F] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [9] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): KM8V8001JM-B813 (1000) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8V8001JM-B813 UFS_FWVER : 1000 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : alps Product Manufacturer : alps Product Model : oplus_mssi_64_cn Product Name : sys_oplus_mssi_64_cn Product Device : oplus_mssi_64_cn Product Board : oppo6771 Board Platform : MT6771 Build ID : RP1A.200720.011 Build Date : Tue Mar 22 21:50:24 CST 2022 Display ID : RP1A.200720.011 release-keys Security Patch : 2022-04-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 1647956286159 Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Repairing IMEI... IMEI 1: XXXX3618XXXXXX0 IMEI 2: XXXX3618XXXXXX2 Write IMEI [NVDATA]... OK Load partiton for patching... patch impossible PLZ need tested Downgrad FLASH FILE and safe flashing Mehtod | |
