05-15-2021, 08:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2017 Location: china
Member: 2758069 Status: Offline Thanks Meter: 40 | need help oppo unlock bootloader error Operation: Relock bootloader Software version: 1.10 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x1E8703E4, 0xCA12FB6F, 0x14E8C891, 0x3B0A218D Get Chip ID... [MT6765] Get SOC ID... [42CF26BA498A0F4222960A58B2D50228D4BE55EE2438DF5C93 C1B27487217BB5] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [20] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x13014E47314A39533910066D94D3573F Load EMI config from database [DB VER: 83 DB DATE: 05-08-2021] OK [1] Trying EMI [F1ADA01B] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x13014E47314A39533910066D94D3573F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1F000000 (116.48Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... error(8) |
05-15-2021, 08:46 | #2 (permalink) |
Insane Poster Join Date: Oct 2010
Member: 1418749 Status: Offline Thanks Meter: 45 | you want to unlock or Relock , your logs show you are trying to relock bootloader . but you title unlock bootloader ? write full detials of device Model: Model Code : Android version : then only Team check what is the issue |
05-15-2021, 16:07 | #3 (permalink) | |
Member: 2758069 Status: Offline Thanks Meter: 40 | Quote:
Selected model: OPPO UNKNOWN Operation: Unlock bootloader Software version: 1.10 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM12 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0788 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6771] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x60AABC0B, 0x0011B9EB, 0xAD4C3C6D, 0xB6239CBF Get Chip ID... [MT6771] Get SOC ID... [A057680B46F0554ED02987DBC625451BC24FA30F32E63D6315 555526E7E7B232] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [18] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100335636434D4202519EDA7346A9 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100335636434D4202519EDA7346A9 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x1D1EC00000 (116.48Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0180000000 (6.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Decrypt security data... error(7) oppo a9 | |
