07-18-2022, 09:41 | #1 (permalink) |
Registered User Join Date: Mar 2010
Member: 1260168 Status: Offline Thanks Meter: 62 | Infinix X603 flashing failed [Answered] log is here : Selected model: Infinix X603 (Infinix Zero 5) Operation: Flash (Download only) Software version: 3.6 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM82 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0551 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6757] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... FULL Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0551 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6757] Get sec config... OK [00000000] Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM82 [BROM] Open port... OK Get HW code from device... 0551 Get HW & SW version from device... OK HW VER: CB00, SW VER: 0001, HW SUB CODE: 8A00 Detect chip [MT6757] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x66AF41A1, 0x0503FE96, 0x9EA1D07D, 0x3FAB97B8 Get Chip ID... [MT6757] Get sec config... OK [00000000] Load DownloadAgent... OK Search DA... OK [3] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A484347386134A20704EC60944F Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A484347386134A20704EC60944F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E8F800000 (58.24Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Get scatter info... OK Check USB status... USB_FULL_SPEED Switching to USB high speed... OK Wait for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek DA USB VCOM (Android),usb2ser.sys,3.0.1504.0] High Speed USB detected at COM102 Open port... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Infinix Product Manufacturer : Infinix Product Model : Infinix X603 Product Name : H575 Product Device : Infinix-X603 Board Platform : MT6757 Build ID : NRD90M Build Date : Mon Jun 10 20:01:47 CST 2019 Display ID : X603-H575A-N-IN-190610V247 Security Patch : 2019-04-05 Version SDK : 24 Version Release : 7.0 Version Codename : REL Firmware Version : X603-H575A-N-IN-190610V247 Get scatter info... OK Verify scatter file... OK Do NAND BMT remark... OK Setup download info... OK Get partition table catagory... OK [GPT] Read mirror partition table... OK Check partition table layout changed... OK Read major partition table... OK Check major partition table layout changed... OK Download "preloader"... OK Download "recovery"... error(STATUS_CHECKSUM_ERR) Flashing done! |
