Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2016 Location: iran tehran 021
Member: 2643931 Status: Offline Sonork: ****** Thanks Meter: 217 | nokia g10 format error [Answered] Operation: Format Flash Software version: 3.6 This procedure will erase all flash and can damage your device. Make sure that you have a backup created. Continue? YES Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [Sony Mobile Communications,usbser,MTK USB Port,usbser.sys,10.0.19041.1202] Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x31A4F200, 0xDDB29553, 0x6F01E1A3, 0xBB18562C Get Chip ID... [MT6765] Get SOC ID... [4532EFCA67FB4C3BFDBE04C98E2BEA78DF1850CBC250C5A28B ED86E1B0F7EA35] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x880103534C44363447605D0399B37849 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x880103534C44363447605D0399B37849 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0E67800000 (57.62Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0100000000 (4.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK [A] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G10 Product Name : Rogue_00WW Product Device : ROGA_sprout Product Board : MT6762 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Mar 10 02:36:45 CST 2022 Display ID : 00WW_1_260_SP05 Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_26E Read partition "preloader"... error(8), skip Read partition "pgpt"... error(STATUS_UNSUPPORT_CMD), skip Read partition "nvcfg"... error(8), skip Read partition "nvdata"... error(STATUS_UNSUPPORT_CMD), skip Read partition "protect1"... error(8), skip Read partition "protect2"... error(STATUS_UNSUPPORT_CMD), skip Read partition "persist"... error(8), skip Read partition "proinfo"... error(STATUS_UNSUPPORT_CMD), skip Read partition "efuse"... OK Read partition "nvram"... error(8), skip Read partition "oem"... error(STATUS_UNSUPPORT_CMD), skip Read partition "elabel"... error(8), skip Read partition "otp"... error(STATUS_UNSUPPORT_CMD), skip Read partition "flashinfo"... error(8), skip Backup saved to C:/Program%20Files%20(x86)/Z3X/Pandora/Backup/MTK/Nokia_TA-1334%20(Nokia%20G10)/FORMAT_BACKUP_(2022-6-22_15-50-52)/"directory Create autoformat settings... OK Format EMMC_BOOT_1 partition( 0x00000000..0x003FFFFF )... error(2) ![]() |
