Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: BASTI MALOOK ( MULTAN PKISTAN)
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | nokia g21 ta-1418 nv data saved error Connecting to device... OK Selected processor: Tiger_T616_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: P250403221003120 Flash Type: EMMC Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G21 Product Name : ShadowcatPlus_00WW Product Device : SCP_sprout Build ID : RP1A.201005.001 Build Date : Fri Jul 22 14:51:09 UTC 2022 Display ID : 00WW_1_520 Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_520 Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 35884710907 IMEI 2: 35884710907 Repaired IMEI: IMEI 1: 35884710907 IMEI 2: 35884710907 Write IMEI... OK Save NVD... error(1) Selected model: Nokia TA-1418 (Nokia G21) Operation: Repair Software version: 4.8 Work ID: 991117 |
The Following User Says Thank You to zaibmobile For This Useful Post: |
![]() | #5 (permalink) |
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | Selected model: Nokia TA-1418 (Nokia G21) Operation: Restore From Backup Software version: 4.8 Work ID: 992533 Waiting for device... OK Device found at COM41 Port: USB\VID_1782&PID_4D00\6&27C7CE02&0&5 Driver: [DriverCoding Corporation,sprdvcom,SPRD U2S Diag,sprdvcom.sys,2.0.0.114] Connecting to device... OK Selected processor: Tiger_T616_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: P250403221003120 Flash Type: EMMC Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G21 Product Name : ShadowcatPlus_00WW Product Device : SCP_sprout Build ID : RP1A.201005.001 Build Date : Fri Jul 22 14:51:09 UTC 2022 Display ID : 00WW_1_520 Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_520 Restore partition "l_fixnv1_b"... error |
![]() | #7 (permalink) |
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | Restore partition "l_fixnv1_b"... error but working ok now but i want repair imei . im upload backup and contact you as soon |
![]() | #9 (permalink) |
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | Selected model: Nokia TA-1418 (Nokia G21) Operation: Restore From Backup Software version: 4.8 Work ID: 992919 Waiting for device... OK Device found at COM41 Port: USB\VID_1782&PID_4D00\6&27C7CE02&0&5 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Connecting to device... OK Selected processor: Tiger_T616_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: P250403221003120 Flash Type: EMMC Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G21 Product Name : ShadowcatPlus_00WW Product Device : SCP_sprout Build ID : RP1A.201005.001 Build Date : Fri Jul 22 14:51:09 UTC 2022 Display ID : 00WW_1_520 Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_520 Restore partition "l_fixnv1_b"... OK Done! |
![]() | #10 (permalink) |
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | imei repair done but same problem mobile in fastboot mode and show data is corrupted it can be restored by device kit here is logs Connecting to device... OK Selected processor: Tiger_T616_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: P250403221003120 Flash Type: EMMC Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G21 Product Name : ShadowcatPlus_00WW Product Device : SCP_sprout Build ID : RP1A.201005.001 Build Date : Fri Jul 22 14:51:09 UTC 2022 Display ID : 00WW_1_520 Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_520 Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 35352218063 IMEI 2: 35352218068 Repaired IMEI: IMEI 1: 35884710907 IMEI 2: 35884710907 Write IMEI... OK Save NVD... OK Done! Selected model: Nokia TA-1418 (Nokia G21) Operation: Repair Software version: 4.8 Work ID: 992959 |
![]() | #11 (permalink) |
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | imei repair done but same problem mobile in fastboot mode and show data is corrupted it can be restored by device kit here is logs Connecting to device... OK Selected processor: Tiger_T616_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: P250403221003120 Flash Type: EMMC Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G21 Product Name : ShadowcatPlus_00WW Product Device : SCP_sprout Build ID : RP1A.201005.001 Build Date : Fri Jul 22 14:51:09 UTC 2022 Display ID : 00WW_1_520 Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_520 Load NVD... OK Read IMEI... OK Current IMEI: IMEI 1: 35352218063 IMEI 2: 35352218068 Repaired IMEI: IMEI 1: 35884710907 IMEI 2: 35884710907 Write IMEI... OK Save NVD... OK Done! Selected model: Nokia TA-1418 (Nokia G21) Operation: Repair Software version: 4.8 |
![]() | #12 (permalink) |
Member: 737489 Status: Offline Sonork: 100.1652367 Thanks Meter: 35 | dear team relock bootloader done but mobile show your device is corrupt. and after one minute mobile auto off problem here is log Waiting for device... OK Device found at COM41 Port: USB\VID_1782&PID_4D00\6&27C7CE02&0&5 Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134] Connecting to device... OK Selected processor: Tiger_T616_64 Load files... OK Connect preloader 1... OK Connect preloader 2... OK Connect loader 1... OK Connect loader 2... OK Serial Number: P250403221003120 Flash Type: EMMC Read partitions info... OK Checking A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G21 Product Name : ShadowcatPlus_00WW Product Device : SCP_sprout Build ID : RP1A.201005.001 Build Date : Fri Jul 22 14:51:09 UTC 2022 Display ID : 00WW_1_520 Security Patch : 2022-07-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_520 Relock bootloader... OK Done! If your phone after repair keeps rebooting - use wipe data option. Selected model: Nokia TA-1418 (Nokia G21) Operation: Relock bootloader Software version: 4.8 |
