06-06-2022, 11:17 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: turkey
Member: 1105442 Status: Offline Thanks Meter: 46 | Xiaomi M1906G7G (Redmi Note 8 Pro) Dual imei repair [Done] Operation: Repair Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x94A755B9, 0x430646D2, 0x84618164, 0x14745580 Get Chip ID... [MT6785] Get SOC ID... [F257B55F962F251AE07461AB845959A2FB461B61F620E81B11 24C218B37E8875] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ16AFAMMDAR (A108) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ16AFAMMDAR UFS_FWVER : A108 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : Redmi Note 8 Pro Product Name : begonia Product Device : begonia Product Board : begonia Board Platform : MT6785 Build ID : QP1A.190711.020 Build Date : Fri May 14 01:07:57 WIB 2021 Display ID : QP1A.190711.020 Security Patch : 2021-04-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : V12.0.8.0.QGGMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... OK IMEI 1: 868286048986141 IMEI 2: 868286048986158 Repairing IMEI... IMEI 1: 356xxxxxxxxxx05 IMEI 2: 356xxxxxxxxx497 Write IMEI [NVDATA]... OK Write IMEI [NVRAM]... OK Write partition "nvdata"... OK Write partition "nvram"... OK Repair Security done! If your phone after repair keeps rebooting - use wipe data option. Now use "Patch Cert" option to comlete repair. Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM7 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0813 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6785] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x94A755B9, 0x430646D2, 0x84618164, 0x14745580 Get Chip ID... [MT6785] Get SOC ID... [F257B55F962F251AE07461AB845959A2FB461B61F620E81B11 24C218B37E8875] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [12] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): H9HQ16AFAMMDAR (A108) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : H9HQ16AFAMMDAR UFS_FWVER : A108 BLOCK_SIZE: 0x0000001000 (4.00Kb) UFS_LU0 : 0x0000400000 (4.00Mb) UFS_LU1 : 0x0000400000 (4.00Mb) UFS_LU2 : 0x1DCB000000 (119.17Gb) RAM INFO: INT_SRAM: 0x0000080000 (512.00Kb) EXT_RAM : 0x0200000000 (8.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Redmi Product Manufacturer : Xiaomi Product Model : Redmi Note 8 Pro Product Name : begonia Product Device : begonia Product Board : begonia Board Platform : MT6785 Build ID : QP1A.190711.020 Build Date : Fri May 14 01:07:57 WIB 2021 Display ID : QP1A.190711.020 Security Patch : 2021-04-01 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : V12.0.8.0.QGGMIXM Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Load partiton for patching... OK Check boot patch possiblity... POSSIBLE WITH BOOT UNLOCK Patching CERT... OK Save patched partiton... OK Format "parameter" partition... OK Unlock bootloader... OK Write partition "nvdata"... OK Write partition "nvram"... OK Patch cert done! If your phone after repair keeps rebooting - use wipe data option. |
