08-07-2021, 23:35 | #1 (permalink) |
Crazy Poster Join Date: Mar 2008
Member: 734348 Status: Offline Thanks Meter: 1 | Nokia TA-1218 can't get unlocked [Answered] Hi, I was trying to unlock TA-1218 but I got an error, can you fix this please? Selected model: Nokia TA-1218 (Nokia 2V) Operation: Unlock network Software version: 2.3 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM225 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x5A2478DD, 0x16E26895, 0xE10158F4, 0xE5A35D48 Get Chip ID... [MT6761] Get SOC ID... [02953CC6FC20C8D867892C96A2DD1CE81E6DA67D1DFD47DA6C 70C7FAB4198A32] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D42011210BED42821 Load EMI config from database [DB VER: 164 DB DATE: 07-17-2021] OK [1] Trying EMI [1BB1F176, EB371E79, A29F3633, 92392267, 9C47C7D7, 0F6B3A76, A58FA23E, 4CA98027, C26ECB0F] Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D42011210BED42821 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0001000000 (16.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(ERR_NO_FILE) Thanks! BR. |
07-17-2022, 13:06 | #3 (permalink) |
Freak Poster Join Date: Nov 2007 Location: ukraine lviv
Member: 624189 Status: Offline Thanks Meter: 4 | Selected model: Nokia TA-1218 (Nokia 2V) Operation: Unlock network Software version: 3.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x64CF74FC, 0xDCEC0DB1, 0xFD5C54AE, 0xA1565022 Get Chip ID... [MT6761] Get SOC ID... [FFA8A46C170CB266633F9C93217013D1BEF57D5BD42AE05CC0 0668382FCB0F63] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4201E768E4B3A78B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D4201E768E4B3A78B EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A500 (233,25Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia C2 Tennen Product Model Display: TA Product Name : Armstrong_CUS Product Device : armstrong Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Wed Jan 20 16:24:02 IST 2021 Display ID : 00CUS_0_57S Security Patch : 2021-01-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00CUS_0_57S Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Unlock... OK [DF1, DF2, DF2] Write lock info... error(ERR_COMP) same problem |
07-17-2022, 13:23 | #4 (permalink) |
Member: 624189 Status: Offline Thanks Meter: 4 | https://mega.nz/file/c1IknbIJ#DM3RHf...uFFmi-fe-we6hk partitions dump |
07-19-2022, 13:07 | #9 (permalink) |
Member: 624189 Status: Offline Thanks Meter: 4 | Selected model: Nokia TA-1218 (Nokia 2V) Operation: Unlock network Software version: 3.8 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM5 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x64CF74FC, 0xDCEC0DB1, 0xFD5C54AE, 0xA1565022 Get Chip ID... [MT6761] Get SOC ID... [FFA8A46C170CB266633F9C93217013D1BEF57D5BD42AE05CC0 0668382FCB0F63] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [5] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100514436334D4201E768E4B3A78B Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100514436334D4201E768E4B3A78B EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0747C00000 (29,12Gb) RAM INFO: INT_SRAM: 0x000003A500 (233,25Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Check A/B state... OK Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia C2 Tennen Product Model Display: TA Product Name : Armstrong_CUS Product Device : armstrong Product Board : MT6761 Board Platform : MT6761 Build ID : QP1A.190711.020 Build Date : Wed Jan 20 16:24:02 IST 2021 Display ID : 00CUS_0_57S Security Patch : 2021-01-05 Version SDK : 29 Version Release : 10 Version Codename : REL Firmware Version : 00CUS_0_57S Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... OK Read partition "nvdata"... OK Read NVDATA files... OK Read IMEI... OK Unlock... OK [DF1, DF2, DF2] Write lock info... error(ERR_COMP) same error |
