12-14-2021, 20:59 | #1 (permalink) |
Insane Poster Join Date: Oct 2017 Location: México Age: 46
Member: 2763934 Status: Offline Thanks Meter: 17 | Alcatel Tab please read Pandora Team [Answered] i appreciate all your hard work for this great tool, but please help. a While ago i posted about alcatel joy tab 2 model 9032z you asked for logs and partitions to be uploaded. here is original thread: https://forum.gsmhosting.com/vbb/f11...wered-2989469/ you marked post as ANSWERED, but no solution. later someone else posted also, here is thread: https://forum.gsmhosting.com/vbb/f11...wered-2991040/ also marked as ANSWERED, but no solution. partitions were uploaded, logs were posted, tested with all models, all give same error as logs posted. , here is link for partitions: https://drive.google.com/file/d/1tB1...ew?usp=sharing here is log (any model selected gives same log error): Selected model: Mediatek Mediatek Operation: Unlock network Software version: 2.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM35 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x52FA82A7, 0x8253EFE3, 0x9A76253A, 0x82E0B9F3 Get Chip ID... [MT6761] Get SOC ID... [263ED76E8FECF3ECE8E94426F545768BBE1B6DA02F53DF1388 244F64FDDAA78F] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100445836384D420906F3CECA380F Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x150100445836384D420906F3CECA380F EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0747C00000 (29.12Gb) RAM INFO: INT_SRAM: 0x0000039000 (228.00Kb) EXT_RAM : 0x00C0000000 (3.00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read security files... OK Read lock info... error(4) |
