05-25-2022, 18:15 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: In front of my pc
Member: 586318 Status: Offline Thanks Meter: 112 | Nokia TA-1346 FRP issue [Solved] Code: Selected model: Nokia TA-1346 (Nokia G10) Operation: Erase FRP Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3837C1E0, 0x5B46F695, 0x11FA578E, 0x8AACFA97 Get Chip ID... [MT6765] Get SOC ID... [5DA3ADA0D73449F9243D99497E6D22107F4CCE80EC0B11C5472A9EDD1725D710] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1)Selected model: Nokia TA-1346 (Nokia G10) Operation: Erase FRP Software version: 3.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Connect phone to BOX in BROM mode Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM29 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x3837C1E0, 0x5B46F695, 0x11FA578E, 0x8AACFA97 Get Chip ID... [MT6765] Get SOC ID... [5DA3ADA0D73449F9243D99497E6D22107F4CCE80EC0B11C5472A9EDD1725D710] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1) |
05-25-2022, 20:31 | #4 (permalink) |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Online Thanks Meter: 5,053 | Doing via tp? With battery or without? Try svitch connection mode (without battery) and connect charged battery.. Also try add extra power via power adaptor. |
05-25-2022, 21:47 | #6 (permalink) |
Member: 586318 Status: Offline Thanks Meter: 112 | I used to use a switch for getting the phone into brom mode (one pin to ground and another to te tp itself). It seems the switch got damaged... I try with another switch and now it was possible: Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G10 Product Name : Rogue_00WW Product Device : ROGA_sprout Product Board : MT6762 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Mar 10 02:36:45 CST 2022 Display ID : 00WW_1_260_SP05 Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_26E Read partitions info from phone... OK Check A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G10 Product Name : Rogue_00WW Product Device : ROGA_sprout Product Board : MT6762 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Mar 10 02:36:45 CST 2022 Display ID : 00WW_1_260_SP05 Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_26E Format "userdata" partition... OK Format "metadata" partition... OK Format "md_udc" partition... OK Create default filesystems... OK Wipe data done!Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G10 Product Name : Rogue_00WW Product Device : ROGA_sprout Product Board : MT6762 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Mar 10 02:36:45 CST 2022 Display ID : 00WW_1_260_SP05 Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_26E Read partitions info from phone... OK Check A/B state... OK [B] Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia G10 Product Name : Rogue_00WW Product Device : ROGA_sprout Product Board : MT6762 Board Platform : MT6765 Build ID : RP1A.200720.011 Build Date : Thu Mar 10 02:36:45 CST 2022 Display ID : 00WW_1_260_SP05 Security Patch : 2022-03-05 Version SDK : 30 Version Release : 11 Version Codename : REL Firmware Version : 00WW_1_26E Format "userdata" partition... OK Format "metadata" partition... OK Format "md_udc" partition... OK Create default filesystems... OK Wipe data done! Selected model: Nokia TA-1346 (Nokia G10) Operation: Wipe Data Software version: 3.5 Thanks for assisting me... |
10-04-2022, 13:49 | #7 (permalink) |
Insane Poster Join Date: Oct 2010
Member: 1431853 Status: Offline Thanks Meter: 15 | Nokia G10 (TA-1346) Firmware (Flash File)/Preloader EMI | Hard Reset/Pattern Unlock Android 12 No Recovery Solution https://www.shakeelfile.com/2022/10/nokia-ta-1346.html |
The Following User Says Thank You to malikshakeel09 For This Useful Post: |
03-13-2023, 23:47 | #8 (permalink) |
No Life Poster Join Date: Jan 2014 Location: San Luis Potosi, Mexico
Member: 2109200 Status: Offline Thanks Meter: 40 | Selected model: Nokia TA-1346 (Nokia G10) Operation: Read Flash Info Software version: 4.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone to BOX in BROM/PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM40 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Force switch to BROM... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Waiting for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM36 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get sec config... OK [000000E0] Active sec flags: [] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x7E29E639, 0xFC8F5144, 0x8CD939DD, 0x766DDB75 Get Chip ID... [MT6765] Get SOC ID... [DB7CB839F818EBFE5E00FF7DFF1D5469BF823DB1903F4721B0 0F40DB44E04CB3] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [7] Send preloader... OK Start preloader... OK Checking preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... error(1) same issue .. extra power, withou battery, with baterry.. |
03-14-2023, 08:37 | #9 (permalink) | |
Member: 706257 Status: Online Thanks Meter: 5,053 | Quote:
