Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Pandora’s box
Old 10-26-2024, 10:20   #1 (permalink)
Member: 2080569
Thanks Meter: 7
Nokia TA-1369 Stuck On Fastboot After Network Unlock
Nokia TA-1369 stuck on Fastboot mode after network unlock. i have even wiped data, but still the same outcome.
Connect phone in BROM mode. Use volume key buttons or testpoint.
Waiting for device... OK
Device found at COM7
Port: USB\VID_1782&PID_4D00\5&320A61ED&0&1
Driver: [UNISOC Communications Inc.,sprdvcom,SPRD U2S Diag,sprdvcom.sys,4.19.38.134]
Port type: BROM
Connecting to device... OK
Selected processor: SC9863A_64
Load files... (universal) OK
Connect preloader 1... OK
Connect preloader 2... OK
Connect loader 1... OK
Connect loader 2... OK
Serial Number: E666941220800544
Read partitions info... OK
Checking A/B state... OK [A]
Read product info... [EXT4] ... OK
Product Brand : Nokia
Product Manufacturer : HMD Global
Product Model : MNR
Product Name : *******_00WW
Product Device : MNR
Product Board : *******
Board Platform : sp9863a
Build ID : RP1A.201005.001
Build Date : Mon Nov 27 06:47:47 UTC 2023
Security Patch : 2023-12-05
Version SDK : 30
Version Release : 11
Version Codename : REL
Firmware Version : 00WW_1_91C
Userdata FS Type : F2FS
Check security state... OK [1]
Unlock bootloader... OK
Patch modem check... OK OK
Patch data... OK
Load NVD... OK
Unlock... OK
Save NVD... OK
Done!
If your phone after this operation keeps rebooting - use wipe data option.
The Following User Says Thank You to Hamzilas For This Useful Post:
Old 10-26-2024, 10:49   #2 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,466
Hello. Read and upload partitions dump (except userdata and cache).
Old 10-27-2024, 08:17   #3 (permalink)
Member: 2080569
Thanks Meter: 7
Device is dead now after flash
Sent from my SM-S918U1 using Tapatalk
Old 10-27-2024, 10:55   #4 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,466
Where you see that im ask to reflash phone? Reflash latest firmware for unbrick now.
Old 10-27-2024, 12:15   #5 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 1,019
Did you take a backup of whole phone without userdata before flashing acording to rules.
If not then is little badluck.
But as team adviced to reflash using latest firmware we hope your phone will become on but not sure about unlock.
please give feedback after flashing
Old 10-27-2024, 15:21   #6 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,466
SPD nokia phones have arb. Cant flash older firmware, only same as before or newer.
Old 10-27-2024, 21:45   #7 (permalink)
Member: 2080569
Thanks Meter: 7
I've backed up and compressed all partitions except Cache and Userdata. The file size is 1.2GB.
Old 10-28-2024, 04:08   #8 (permalink)
Member: 2080569
Thanks Meter: 7
Partitions dump link
https://we.tl/t-S6nnhpDqmf
Old 10-31-2024, 05:25   #9 (permalink)
Member: 2080569
Thanks Meter: 7
No response from Team
Old 10-31-2024, 09:44   #10 (permalink)
Z3X
Member: 706257
Thanks Meter: 5,466
Your problem in que. We will check this and add fix if possible in some of updates. For unbrick - search firmware as was in phone or newer.
Page generated in 0.16976 seconds with 8 queries
