07-15-2021, 04:12 | #1 (permalink) |
Freak Poster Join Date: Jan 2017 Location: Nicaragua Age: 32
Member: 2674782 Status: Offline Thanks Meter: 12 | nokia ta1222 [Answered] Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E3] Active sec flags: [SBC SLA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM148 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x589CC3E0, 0xEFF8809A, 0xFAE3C93D, 0x01A91149 Get Chip ID... [MT6765] Get SOC ID... [AA6486EEEEC395978C979736361ADA869AC541D38FA9DF2831 2CA2A8D2DA7A77] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [23] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x150100475036424D4201FD0807A3872B Load EMI config from database [DB VER: 162 DB DATE: 07-09-2021] OK [1] Trying EMI [1BB1F176, EB371E79, A29F3633, 92392267, 9C47C7D7, 0F6B3A76, A58FA23E, 4CA98027, C26ECB0F] Init EXT RAM... error(STATUS_EMI_SETTING_VERSION_ERROR) |
07-15-2021, 21:31 | #3 (permalink) |
Member: 2674782 Status: Offline Thanks Meter: 12 | that's all the log showed because I didn't finish the process, I no longer have the equipment, I had to use another tool to free it, it took seconds |
